汽车专业英语四-六
汽车专业英语词汇(四)
加速性能 acceleration performance
动力性能 power performance
排放性能 emission performance
空转特性 no load characteristics
负荷特性 part throttle characteristics
调速特性 governor control characteristics
万有特性 mapping characteristics
稳定调速率 steady state speed governing rate
气缸体和气缸盖 cylinder block and head
气缸体 cylinder block
整体铸造 cast inblock (cast enblock)
发动机罩 engine bonnet
气缸体加强筋 engine block stiffening rib
气缸 cylinder
(转子机)缸体 stator
缸径 cylinder bore
气缸体机架 cylinder block frame
气缸盖 cylinder head
配气机构箱 valve mechanism casing
气缸体隔片 cylinder spacer
气缸盖密封环 cylinder head ring gasket
气缸盖垫片 cylinder head gasket
气缸套 cylinder liner(cylinder sleeve)
干式缸套 dry cylinder liner
湿式缸套 wet cylinder liner
气缸水套 water jacket
膨胀塞 expansion plug
防冻塞 freeze plug
气缸壁 cylinder wall
环脊 ring ridge
排气口 exhaust port
中间隔板 intermediate bottum
导板 guideway
创成半径(转子机) generating radius
缸体宽度(转子机) operating width
机柱 column
燃烧室 combustion chamber
主燃烧室 main combustion chamber
副燃烧室 subsidiary combustion chamber
预燃室 prechamber
涡流燃烧室` swirl combustion chamber
分开式燃烧室 divided combustion chamber
涡流式燃烧室 turbulence combustion chamber
半球形燃烧室 hemispherical combustion chamber
浴盆形燃烧室 bathtub section combustion chamber
L形燃烧室 L-combustion chamber
楔形燃烧室 wedge-section combustion chamber
开式燃烧室 open combustion chamber
封闭喷射室 closed spray chamber
活塞顶内燃烧室 piston chamber
爆发室 explosion chamber
燃烧室容积比 volume ratio of combustion cahmber
燃烧室口径比 surface-volume ratio of combustion chamber
通道面积比 area ratio of combustion chamber passage
曲轴箱通气口 crankcase breather
凸轮轴轴承座 camshaft bearing bush seat
定时齿轮室罩 camshaft drive(gear)cover
曲轴箱检查孔盖 crankcase door
曲轴箱防爆门 crankcase explosion proof door
主轴承盖 main bearing cap
气缸盖罩 valve mechanism cover
飞轮壳 flywheel cover
扫气储器 scavenging air receiver
活塞 piston
裙部开槽活塞 split skirt piston
U形槽活塞 U-slot piston
滚花修复活塞 knurled piston
圆顶活塞 dome head piston
汽车专业英语词汇(五)
平顶活塞 flat head piston
凸顶活塞 crown head piston(convex head piston)
凹顶活塞 concave head piston
阶梯顶活塞 step-head piston
筒形活塞 trunk piston
椭圆形活塞 oval piston
抗热变形活塞 autothermic piston
不变间隙活塞 constant clearance piston
镶因瓦钢片活塞 invar strut piston
直接冷却式活塞 direct-cooled piston
间接冷却式活塞 indirect cooled piston
滑裙活塞 slipper piston
活塞速度 piston speed
活塞顶部 piston head
活塞裙部 piston skirt
整体活塞裙 solid skirt
活塞裙扩大衬簧 piston skirt expander
滑履式活塞裙 slipper skirt
隔热槽 heat dam
活塞标记 piston mark
活塞销 piston pin
活塞销孔 piston pin boss
活塞销衬套 piston pin bushing
全浮式活塞销 full-floating piston pin
半浮式活塞销 semifloating piston pin
固定螺钉式活塞销 set screw piston pin
活塞环 piston ring
组合式活塞环 compound piston ring
同心活塞环 concentric piston ring
偏心活塞环 eccentric piston ring
自由环 free ring
闭合环 closed ring
梯形环 keystone ring
半梯形环 half keystone ring
矩形环 rectangular ring
油环 oil control ring
开槽油环 slotted oil control ring
螺旋弹簧加载双坡口油环 coil spring loaded slotted oil control ring
涨环 expander
双坡口油环 double bevelled oil control ring
内上坡口 internal bevel top
内下坡口 internal bevel bottom
边缘坡口油环 bevelled-ege oil control ring
刮油环 scrapper ring
钩形环 napier ring
镀铬活塞环 chrome plated piston ring
活塞衬环 piston ring expander
活塞环槽 piston ring groove
活塞环区 ring zone
活塞环岸 piston ring land
活塞环内表面 back of ring
曲柄连杆机构 connecting rod
中心曲柄连杆机构 central-located connecting rod
偏心曲柄连杆机构 offset connecting rod
铰接曲柄边杆机构 hinged connecting rod
连杆 connecting rod
连杆小头 connecting rod small end
连杆大头 connnecting rod big end
连杆杆身 connecting rod shank
副连杆 slave connecting rod
叉形连杆 fork-and-blade connecting rod
主连杆 main connecting rod
方形连杆 boxed rod
绞链式连杆 hinged type connecting rod
活节式连杆 articulated connecting rod
连杆盖 connecting rod cap
连杆轴承 connecting rod bearing
曲轴 crankshaft
整体式曲轴 one-piece crankshaft
组合式曲轴 assembled crankshaft
右侧曲轴 right-hand crankshaft
左侧曲轴 left-hand crankshaft
改变行程的曲轴 stroked crankshaft
曲轴前端 crankshaft front end
曲轴主轴颈 crankshaft main journal
轴颈重叠度 shaft journal overlap
圆角 fillet
主轴承 main bearing
曲轴止推轴承 crankshaft thrust bearing
薄臂轴瓦 thin wall bearing shell
曲轴油道 crankshaft oil passage
曲柄 crank
曲柄臂 crank arm
曲柄销 crank pin
轴套 bush
曲柄转角 crank angle
曲柄半径 crank radius
抛油圈 oil slander
角度轮 degree wheel
动平衡机 dynamic balancer
平衡重 balancer weight
汽车专业英语词汇(六)
扭振减振器 torshional vibration damper
扭振平衡器 torsion balancer
谐振平衡器 harmonic balancer
振动平衡器 vibration balancer
曲轴链轮 crankshaft sprocket
转子轴颈 rotor journal
偏心轴 eccentric shaft
曲轴箱 crankcase
闭式曲轴箱通风装置 closed-crankcase ventilating system
飞轮 flywheel
飞轮齿圈 flywheel ring gear
飞轮芯棒 cantilever
飞轮芯轴 flywheel spindle
飞轮的惯量矩 flywheel moment of inertia
飞轮标记 flywheel mark
当量系统 equivalent system
当量轴长 equivalent shaft length
一级往复惯性力 reciprocating inertia force,1st order
二级往复贯性力 reciprocating inertia force, 2nd order
离心惯性力 centrifugal inertia force
配气机构 valve gear
凸轮轴 camshaft
凸轮 cam
整体式凸轮轴 one-piece camshaft
组合式凸轮轴 assembled camshaft
凸轮轴驱动机构 camshaft drive
赛车用凸轮轴 race camshaft
凸轮轴轴颈 camshaft bearing journal
凸轮轴轴承 camshaft bearing
凸轮轴偏心轮 camshaft eccentric
凸轮轴链轮 camshaft sprocket
凸轮轴正时齿轮 camshaft timing gear
凸轮轴齿轮 camshaft gear wheel
进口凸轮 inlet cam
排气凸轮 exhaust cam
快升凸轮 quick lift cam
快升缓降凸轮 quick lift gradual clsing cam
凸轮轮廓 cam contour
凸轮包角 cam angle
凸轮升程 cam-lobe lift
凸轮尖 cam nose
凸轮从动件 cam follower
齿轮传动机构 gear drive
正时齿轮 timing gear
链传动机构 chain drive
链轮 sprocket wheel
链轮盘 chain sprocket
正时链条 timing chain
带齿皮带 toothed timing belt
链条张紧轮 chain tension gear
半速齿轮 half speed gear
正时齿轮刻印记号 timing gear punch mark
气门 valve
进气过程 intake process
换气过程 gas exchange process
扫气过程 scavenging process
给气比 delivery ratio
分层充气 stratified charge
充量系数 volumetric efficiency
涡流比 swirl rate
进气涡流 intake swirl
螺旋进气道进气 helical duct intake
导流屏式气门进气 masked valve intake
切向进气道进气 tangential duct intake
进气紊流 intake trubulence
进气提前角 intake advance angle
进气持续角 intake duration angle
进气迟后角 intake lag angle
进面值 time-area value
气门升程 valve lift
气门正时 valve timing
扫气口面积 scavenging port area
菌形气门 mashroom valve, poppet valve
钠冷却气门 sodium filled valve(natrium cooled valve)
双气门 dual valve
进气门 intake valve (suction valve,inlet valve)
排气门 exhaust valve
顶置气门 overhead valve
侧置气门 side valve
倾斜气门 inclined overhead valve
直立气门 vertical overhead valve
套筒式滑阀 sleeve valve
气门机构 valve gear
直接式气门驱动机构 direct valve gear
间接式气门驱动机构 indirect valve gear
气门杆 valve stem
加大气门杆 oversize valve stem
气门头 valve head
气门工作面 valve face
气门边限 valve margin
气门弹簧座 valve-spring retainer
气门锁片 valve key
气门间隙调节螺钉 valve lash adjusting screw
气门旋转器 valve rotator
气门室 valve cage
气门油封 valve oil seal
气门口 valve port
气门座 valve seat
气门座镶圈(嵌镶式气门座圈) valve seat insert(valve seat ring)
气门座锥角 valve seat angle
气门座宽度 valve seat width
气门挺杆 valve tappet(valve lifter)
液力挺杆 hydraulic tappet(lifter)
无间隙挺杆 zero-rush tappet (non-clearance tappet)
筒形挺杆 barrel type tappet
油压挺杆 ooil tappet
滚轮挺杆 roller tappet(lifter)
挺杆转位 tappet rotation
排气门挺杆 exhaust valve lifter
气门导管 valve guide
气门杆导管 stem guide
气门重叠度 stem overlap
气门开启持续时间 valve duration
气门正时标记 valve timing sign
气门弹簧 valve spring
气门内弹簧 inner valve spring
气门外弹簧 outer valve spring
刚性缓冲弹簧 stiff buffer spring
上紧弹簧 energizing spring
防振气门弹簧 non-surging spring
弹簧座圈 spring retainer
蝶形弹簧 belleville spring
滚柱 roller
气门室盖 valve chamber cover
摇臂 rocker arm
高升程摇臂 high lift rocker arm
摇臂轴 rocker arm shaft
汽车专业英语词汇(七)
推杆 push-rod
摇臂支架 rocker arm bracket
气门摇臂室罩 valve rocker chamber cover
导向轮 guide wheel
导杆 slide bar
导轨 slide rail
张紧轮 tensioning wheel
链条张紧调节装置 assembly chain tension adjuster
张紧带轮 tensioning pulley
传动带张紧装置 belt tensioner
同步驱动皮带 synchronous belt
同步驱动皮轮 synchronous belt pulley
供油系 fuel system
控制燃烧系统 controlled combustion system
反湿气装置 antipercolator
电子燃油喷射 electronic fuel injection
蒸气回收装置 vapor recovery system
燃油蒸气回收系统 fuel vapor recovery system
液体回收装置 liquid withdrawal system
恒量净化管 constant purge line
碳罐净化管 canister purge line
供油量 fuel delivery
循环供油量 fuel delivery per cycle
额定供油量 rated fuel delivery
怠速供油量 idling speed fuel delivery
供油规律 fuel supply rate curve
油量调节装置 fuel control unit
供油提前角 fuel supply advance angle
进油计量 inlet metering
几何供油行程 geometric fuel delivery stroke
供油率 fuel supply rate
燃油通道 fuel gallery
有效行程 effective stroke
剩余行程 remainder stroke
变行程计量 variable stroke metering
等容卸载 constant volume unloading
变容卸载 variable volume unloading
收缩容积 retraction volume
燃油喷油装置 fuel injection equipment
燃油喷射泵 fuel injection pump
滚轮式燃油喷射泵 roll fuel injection pump
凸轮轴式燃油喷射泵 camshaft fuel injection pump
直列式燃油喷射泵 in-line fuel injection pump
伺服式燃油喷射泵 servo fuel injection pump
底部突缘安装燃油喷射泵 base flanged mounted fuel injection pump
上部安装燃油喷射泵 high flanged-mounted fuel injection pump
侧向安装燃油喷射泵 side-mounted fuel injection pump
端部突缘安装式燃油喷射泵 end flange-mounted fuel injection pump
V形燃油喷射泵 vee fuel injection pump
脉动式燃油喷射泵 jerk fuel injection pump
螺纹安装燃油喷射泵 screw-mounted fuel injection pump
蓄能式燃油喷射泵 accumulator fuel injection pump
往复式燃油喷射泵 reciprocating fuel injection pump
驱动轴式燃油喷射泵 driveshaft fuel injection pump
单缸式燃油喷射泵 single cylinder fuel injection pump
圆柱式燃油喷射泵 cylindrical fuel injection pump
旋转式燃油喷射泵 rotary fuel injection pump
分配式燃油喷射泵 distributor fuel injection pump
多缸燃油喷射泵 multicylinder fuel injection pump
框架安装式燃油喷射泵 cradle mounted injection pump
汽车专业英语词汇(八)
喷油始点 fuel injection beginning
喷油终点 fuel injection end
喷油持续角 fuel injection duration angle
喷油延迟 injection delay
引燃喷射 pilot injection
启喷压力 injection starting pressure
峰值喷油扭矩 peak injection torque
峰值喷油压力 peak injection pressure
喷油泵油缸数目 number of cylinders of an injection pump
无气喷射 solid injection
喷射正时 injection timing
集中喷射 group injection
喷油器 injector
整体式喷油器 unit injector
喷嘴 nozzle
轴针式喷嘴 pintle type nozzle
环槽式喷嘴 annular slot nozzle
孔式喷嘴 hole type nozzle
长杆喷嘴 long stem nozzle
孔板式喷嘴 orifice plate nozzle
开式喷嘴 open nozzle
闭式喷嘴 closed nozzle
喷油提前器 timing advance unit
喷射泵壳体 injection pump housing
针阀 needle
芯轴 central spindle
喷嘴壳体 nozzle body
针阀升程 needle lift
喷嘴盖形螺母 nozzle cap nut
喷油器壳体 nozzle holder
突缘安装喷油器壳体 flanged-mounted injection nozzle holder
燃油喷射泵传动装置 transmision of an injection pump
喷嘴锥体 nozzle hole cone
柱塞 plunger
柱塞套 barrel
柱塞行程 plunger stroke
喷孔 spray orifice
海拔控制器 altitude control
提前器飞锤 flyweight
喷孔长径比 ratio of nozzle hole length nozzle diameter
喷嘴液动力特性 nozzle hydrokinetic characteristics
动态相位 dynamic phase
喷孔面积 nozzle hole area
喷嘴流通特性 nozzle flow characteristic
喷油背压 injection back pressure
高压油管 high pressure pipe
平均喷油扭矩 mean injection torque
喷油总效率 overall pumping efficiency
峰值喷油压力 injection peak pressure
