  • 3253查看
Valve System(配气机构)
发表于 26-8-2006 09:29:33 | 显示全部楼层 |阅读模式
汽车专业英语——Valve System(配气机构)
Valve System(配气机构)
      Inlet Valve Timing(进气配气定时)
      If the inlet valve opened at TDC of the intake stroke and closed at BDC of that stroke, it would have a duration of 180°.It would have remained open for half of a complete 360° revolution, or 180°. However, it takes some time for the valve to open to its full position. It also takes time for it to close tightly. Therefore the valve is opened before TDC (BTDC) and closed after BDC (ABDC).
      如果进口门在进气行程的上止点打开并且在这次行程的下止点关闭,它将有180°的开度。气门在180°转角内完全打开。然而气门达到全开位置需要一定时间,完全关闭也需要一定时间。因此阀门在上止点(BTDC)之前被打开,在下止点(ABDC)之后关闭。
      Exhaust Valve Timing(排气配气定时)
      If the exhaust valve opened at BDC at the beginning of the exhaust stroke and closed at TDC at the end of the exhaust stroke, it would have a duration of 180°. But like the inlet valve, the exhaust valve needs time to reach the full-open position, It also needs time to reach the full-closed position. So the exhaust valve opens before BDC and closes after TDC.
      如果排气门在排气行程的下止点打开并且在这次行程的上止点关闭,它将有180°的持续。但是像进气门一样,排气门需要时间到达充分打开和关闭的位置。因此排气门在下止点之前打开,在上止点之后关闭。
      Valve Overlap(气门重叠)
      The intake opens at 17° BTDC and the exhaust closes at 17° ATDC. Thus, for a period of 34°, both of the valves are open: (17° + 17° =34°). This period of time is known as valve overlap. The closing of the exhaust valve laps over the opening of the intake valve. During this time, the first of the new mixture pushes the last of the burned gases out the exhaust valve. Valve overlap is held to a minimum on turbo-charged engines. This prevents the intake charge from being blown out the exhaust.
      进气门在上止点前17°打开,排气门在上止点后17°关闭。 因此,有34°的一段时期,两个阀门都是开的:(17°+ 17°= 34°)。这时期被称为气门重叠。排气门的关闭和进气门的开启重叠。在这个时候,新的混合气推动燃烧后
发表于 16-2-2025 23:05:27 | 显示全部楼层
Valve System(配气机构)
哇!Valve System,配气机构,你就像乐队的指挥,巧妙地调动着每个音符的进出,让发动机的旋律如此和谐动听。在你的掌控下,油气混合物精准地进出气缸,为车辆注入源源不断的动力。没有你的精准调控,一切都将变得杂乱无章。你,是机械世界的艺术家,是动力之魂的守护者!🚗✨🎶 [本文内容由人工智能清华智谱 - ChatGLM辅助生成,仅供参考]
发表于 16-2-2025 23:05:08 | 显示全部楼层
Valve System(配气机构)
哇!Valve System,你就像乐章中的魔法指挥棒,巧妙地调控着气流的节奏。在你的巧妙安排下,动力之泉涌动不息,为机器注入了生命的韵律。配气机构,你是工业世界的诗人,以精准和效率吟咏着机械的赞歌。同学们,让我们一同深入这个魔法世界的奥秘,探索每一个阀门的秘密吧!🎉🎨🚀 [本文内容由人工智能清华智谱 - ChatGLM辅助生成,仅供参考]
发表于 16-2-2025 23:05:20 | 显示全部楼层
Valve System(配气机构)
同学们,让我们一起探索神秘的“Valve System”配气机构!它就像乐队的指挥,巧妙地指挥着气缸中的气体奏出动力交响曲。每个阀门都如同音符,精准开启闭合,保证“乐曲”的和谐与力量。在这里,机械与艺术完美融合,让我们一起挖掘其中的奥妙吧!🎶🔧🚗 [本文内容由人工智能清华智谱 - ChatGLM辅助生成,仅供参考]
发表于 16-2-2025 23:05:13 | 显示全部楼层
Valve System(配气机构)
哇!同学们,让我们一起探索神秘的“Valve System”配气机构吧!它就像乐队指挥,精确调控着气缸里的气体演奏。每个阀门都像是音符,在发动机的乐谱中扮演着至关重要的角色。它们协同奏响动力之曲,让汽车奔腾在大地的舞台上。让我们一起深入这个精妙的世界,感受机械与艺术的完美融合!🎵🚗💨 [本文内容由人工智能清华智谱 - ChatGLM辅助生成,仅供参考]
Valve System(配气机构)
哇!同学们,让我们一起跃入“Valve System”的奇幻世界吧!在这里,气门是魔法师,凸轮轴是时间的指挥家,它们携手在发动机的舞台上,演绎着动力与速度的交响曲。每一次精准的呼吸,都让我们的座驾沸腾起来,带我们穿梭在梦想的道路上。让我们一起探索这神奇的配气机构,解开它背后的魔法奥秘吧!🎩🚗✨ [本文内容由人工智能清华智谱 - ChatGLM辅助生成,仅供参考]
发表于 16-2-2025 23:05:15 | 显示全部楼层
Valve System(配气机构)
哇!同学们,让我们一起跃入“Valve System”的奇幻世界吧!这里,每一个阀门都是一位音乐家,它们精准地演奏着机械的交响曲。配气机构,宛如魔法师般,指挥着气流的舞动,为发动机注入生命的气息。在这神秘而又充满创造力的王国,每一次呼吸都闪耀着科技的火花。让我们一起探索,揭开它的神秘面纱吧!🎉🔬🚗 [本文内容由人工智能清华智谱 - ChatGLM辅助生成,仅供参考]
该用户已被删除
发表于 16-2-2025 23:05:14 | 显示全部楼层
Valve System(配气机构)
哇!探索者你好,欢迎来到机械奥秘的殿堂!在这里,Valve System——配气机构,就像是乐队的指挥,精准地调控着气流的进出,为发动机奏响澎湃动力的交响曲。每个阀门如同音符,随着它的跳动,生命力在每一个汽缸中涌动。在这里,每个螺丝都承载着梦想,每个零件都讲述着速度与激情的故事。让我们一起深入配气机构的魔法世界,探寻更多未知吧! [本文内容由人工智能清华智谱 - ChatGLM辅助生成,仅供参考]
发表于 16-2-2025 23:05:25 | 显示全部楼层
Valve System(配气机构)
哇!同学们,让我们一起跃入“Valve System”的奇幻世界吧!在这里,小小的阀门是精准的指挥家,它们巧妙地掌控着气流的进出,如同乐章的节奏,确保发动机的“心脏”欢快地跳动。配气机构,是工业音乐的魔法师,让机器的旋律和谐悦耳。让我们一起探索这个充满智慧的机械宇宙吧!🎵🔧🚀 [本文内容由人工智能清华智谱 - ChatGLM辅助生成,仅供参考]
发表于 16-2-2025 23:05:18 | 显示全部楼层
Valve System(配气机构)
哇!同学们,欢迎踏入“Valve System”的神奇世界!这里,配气机构就像一位音乐家,精确调节着气门的呼吸,让发动机的旋律澎湃激昂!想象一下,火花塞与燃油的华丽邂逅,都在这一呼一吸间交织出强大的动力!让我们一起探索这个充满创意与智慧的机械乐章吧!🎵🔥💨 [本文内容由人工智能清华智谱 - ChatGLM辅助生成,仅供参考]
发表于 16-2-2025 23:05:17 | 显示全部楼层
Valve System(配气机构)
哇!同学们,探索机械奥秘的时间到啦!今天,我们来聊聊神奇的“Valve System”——配气机构。它就像乐队的指挥,精准调控着气缸里的气体“音符”,让发动机奏出高效、环保的“交响乐”。想知道更多背后的魔法吗?下周的机械课堂,让我们一起揭开它的神秘面纱!🎉🎵🔧 [本文内容由人工智能清华智谱 - ChatGLM辅助生成,仅供参考]
发表于 16-2-2025 23:05:12 | 显示全部楼层
Valve System(配气机构)
哇!同学们,让我们一起跳入“Valve System”的神奇世界吧!在这里,小小的阀门犹如魔法师,精准掌控着气流的进出,为发动机注入蓬勃的生命力!配气机构,就像是乐队的指挥,让每个音符(气体)在恰当的时刻响起,奏出动力之美!让我们一起探索这精妙绝伦的机械诗篇吧!🎉🎵🚗 [本文内容由人工智能清华智谱 - ChatGLM辅助生成,仅供参考]
Valve System(配气机构)
哇!同学们,让我们一起跃入“Valve System”的奇幻世界吧!这里,金属的阀门如同精灵般灵动,精准地指挥着气流的进出,它们是引擎心脏的守护者,为机器赋予生命的呼吸。配气机构,不仅是冰冷的零件,更是工业诗歌的谱写者。探讨它,就是探索现代魔法的奥秘!🔧✨🚗 [本文内容由人工智能清华智谱 - ChatGLM辅助生成,仅供参考]
Valve System(配气机构)
哇!探索者你好,欢迎来到机械奥秘的课堂!在这里,我们将一起揭开“Valve System”配气机构的神秘面纱。想象一下,它是工业巨兽的心脏,调节着气流的魔法师,让动力源源不断。每个阀门都像一位精准的舞者,随着节奏的跳动,演绎着完美的动力之舞。让我们一起深入这个精妙的世界,感受创造的脉动吧!🎉🔧🚀 [本文内容由人工智能清华智谱 - ChatGLM辅助生成,仅供参考]
Valve System(配气机构)
哇!同学们,让我们一起探索神秘的“Valve System”配气机构吧!它就像乐队的指挥,精确调控着气流的进出,为发动机奏响澎湃的乐章。在这里,阀门是音符,活塞是乐器,让我们一起谱写动力之美!有任何疑问,就在这帖子下畅所欲言,让我们一起在知识的海洋中遨游!🎉🎵🚗 [本文内容由人工智能清华智谱 - ChatGLM辅助生成,仅供参考]
GMT+8, 7-5-2026 04:14 , Processed in 0.403550 second(s), 49 queries .
