  • 3045查看
OBD II 数据监控
发表于 13-1-2008 16:42:03 | 显示全部楼层 |阅读模式
这是监控出来的完全符合OBD 规定的数据
#       Time        Function                        Data ( String )
1       [00024439]  IRP_MJ_WRITE                    Length: 0005, Data: 010B
2       [00024441]  IRP_MJ_READ                     Length: 0003, Data: 010
3       [00024442]  IRP_MJ_READ                     Length: 0011, Data: B
41 0B 23
4       [00024444]  IRP_MJ_READ                     Length: 0005, Data:
5       [00024451]  IRP_MJ_WRITE                    Length: 0005, Data: 0104
6       [00024454]  IRP_MJ_READ                     Length: 0011, Data: 0104
41 04
7       [00024455]  IRP_MJ_READ                     Length: 0006, Data: 46
8       [00024457]  IRP_MJ_READ                     Length: 0002, Data:
9       [00024462]  IRP_MJ_WRITE                    Length: 0005, Data: 0108
10      [00024465]  IRP_MJ_READ                     Length: 0009, Data: 0108
41 0
11      [00024466]  IRP_MJ_READ                     Length: 0006, Data: 8 86
12      [00024468]  IRP_MJ_READ                     Length: 0004, Data:
13      [00024474]  IRP_MJ_WRITE                    Length: 0005, Data: 0106
14      [00024476]  IRP_MJ_READ                     Length: 0005, Data: 0106
15      [00024478]  IRP_MJ_READ                     Length: 0009, Data: 41 06 84
16      [00024479]  IRP_MJ_READ                     Length: 0005, Data:
17      [00024486]  IRP_MJ_WRITE                    Length: 0005, Data: 010B
18      [00024487]  IRP_MJ_READ                     Length: 0004, Data: 010B
19      [00024489]  IRP_MJ_READ                     Length: 0010, Data:
41 0B 23
20      [00024490]  IRP_MJ_READ                     Length: 0005, Data:
21      [00024502]  IRP_MJ_WRITE                    Length: 0005, Data: 0104
22      [00024503]  IRP_MJ_READ                     Length: 0005, Data: 0104
23      [00024505]  IRP_MJ_READ                     Length: 0009, Data: 41 04 4A
24      [00024506]  IRP_MJ_READ                     Length: 0005, Data:
25      [00024515]  IRP_MJ_WRITE                    Length: 0005, Data: 0108
26      [00024518]  IRP_MJ_READ                     Length: 0009, Data: 0108
41 0
27      [00024519]  IRP_MJ_READ                     Length: 0006, Data: 8 87
28      [00024521]  IRP_MJ_READ                     Length: 0004, Data:
29      [00024531]  IRP_MJ_WRITE                    Length: 0005, Data: 0106
30      [00024534]  IRP_MJ_READ                     Length: 0008, Data: 0106
41
31      [00024535]  IRP_MJ_READ                     Length: 0007, Data: 06 7E
32      [00024537]  IRP_MJ_READ                     Length: 0004, Data:
33      [00024548]  IRP_MJ_WRITE                    Length: 0005, Data: 010B
34      [00024550]  IRP_MJ_READ                     Length: 0005, Data: 010B
35      [00024551]  IRP_MJ_READ                     Length: 0009, Data: 41 0B 23
36      [00024553]  IRP_MJ_READ                     Length: 0005, Data:
37      [00024567]  IRP_MJ_WRITE                    Length: 0005, Data: 0104
38      [00024569]  IRP_MJ_READ                     Length: 0003, Data: 010
39      [00024570]  IRP_MJ_READ                     Length: 0011, Data: 4
41 04 48
40      [00024572]  IRP_MJ_READ                     Length: 0005, Data:
发表于 31-3-2008 16:07:50 | 显示全部楼层
好像有点深奥,不懂
发表于 14-7-2008 20:01:59 | 显示全部楼层
能不能说详细点呢?
发表于 7-12-2010 10:09:02 | 显示全部楼层
应该是符合iso—15031的诊断应用层数据~~主要是service01--09各种服务,但是楼主只给出部分数据,没有什么实际意义,而且没有给出数据链路层的结构,即是使用了k线还是can线不得而知....
GMT+8, 17-4-2026 22:58 , Processed in 0.516326 second(s), 39 queries .
