  • 2797查看
Motor vehicle structure together with technique --Bodywork section
发表于 21-2-2008 21:28:28 | 显示全部楼层 |阅读模式
Form of bodywork
The bodywork is the fundamental framework of motor vehicle ,Components that also are the largesttest ,It resolves the fundamental form shape of motor vehicle 、Size and use 。
The bodywork casing part of the body is that the everything bodywork are fragmentary 、Components installation base 。Point out longitudinally usually 、Crossbeam and prop await chiefly to hold the stiff space structure that force element along with Ban spare who is linked together against them make up together ,Such is classified followingly :
(1)According to the composition mould style branch :
①Framework style 。There is the integrated framework ,The bodywork covering is simply solidityd stably such on 。
②Semi framework style 。There is the part of framework ,In case by oneself vertical column 、Arch Liang Ji else consolidates piece 。Every framework may be linked together one another either borrowing the covering is linked together 。
③Does not there is not the framework style 。In immediate future there is not the framework ,Replaces the framework is that every the covering plank joins rib strengthening that hour takes shape either plank casing reciprocally 。
(2)According to accepts the force situation branch :
①Non- bearing the weight style 。Such distinguishing feature is continueing to have the frame ,The bodywork joins against the frame by means of spring either the rubber flexible 。The stiffness of frame is greatly ,Force by means of the stand transmission when it stands motor and underpan every components gravitational force along with they to do 、Through the pavement by means of suspends the force that the shelf passed on when the motor vehicle plyes 。The bodywork stands in itself passenger and cargo's gravitational force along with motor vehicle against loads of gravitational force what when plying arouses force of inertia and the air resistance 。
②Semi bearing the weight style 。Such distinguishing feature is continueing to have the frame ,The bodywork joins against the frame rigidity ,The bodywork except for standing not the bearing the weight style relates every loading ,The part of loading of frame still share responsibility for 。The bodywork is consolidated the action to the frame 。
③Bearing the weight style 。Such distinguishing feature is not thering is not the frame ,The bodywork simply as the motor with the underpan the different installation base that invariably succeeds ,The above-mentioned different loading are all stand through the bodywork 。
Use of bodywork
The motor vehicle bodywork is shiping passenger 、Arena that the commodity is doed with driver 。The bodywork ought to be possess the passenger causing and commodity and dispense with to accept dirt 、Rain and snow 、Vibration 、Noise 、Waste gas is invaded and attacked 、Cause driver do the easy term 。On the bodywork —Some composition step and installations still proper assisting be to driving security with eases the mishap 。
The airflow in vicinity ought to be gurranteed effectively guides in the moldmaking of bodywork ,Air resistance and fuel use up in order to decrease 。And conducing to lifing the motor vehicle plyes stability and the improvement motor cooling term ,Gurrantee that it is well internal the bodywork to air 。
  In the wake of the auto industry development ,Moldmaking of bodywork 、Facilities 、The substance that the respect embodys such as colour and so on more and more is subjected to the high opinion of people 。The contemporary motor vehicle bodywork except for is gurranteed such basic skill use ,Still meeting people to the full pursues to its more and more tall substance enjoyment and essence 。
  The motor vehicle bodywork chiefly consists of :Bodywork casing part of the body 、Door of a car 、Bus window 、Ban's finished piece altogether 、Bodywork annex 、Adorns domestic and foreign the bodywork piece 、Pedestal bench 、Ventilation 、Cooling 、Await 。The goods train is with still consists of packing box and else dedicated device on the motor vehicle special 。
The door of a car and bus window
One of the door of a car is significant on the bodywork components ,It is employd a hinge and fixs the bodywork on 。The door of a car degree of turning on gurranteed to be living to slope , and the door of a car on pavement be able to be unfolded successfuly 。Besides ,The door of a car installation place may one another marry against the bodywork noumenon camber 。
The door of a car opens that the means may be divided into with the style turned on according to such 、Against the style turned on 、Horizontal scroll style 、Collapse style 、On the lifting style awaits some kinds ;
(1)With the style turned on with against the style turned on
  Tendency that the airflow was closed down voluntarily when possesing the motor vehicle to ply with the style turned on ,This kind of means not only security but also is convenient for driver watchs when backing a car backward ,Hence by widely being adoptd 。Close down if being living not tightly in the driving against the style turned on ,Possess by in one's face that the airflow dashes peril which turned on ,With the result that secure quality of damage motor vehicle ,Moreover cause the door of a car hinge suffer damage ,Therefore more a moment adopt ( oridinarily being for the sake of the improvement 、Getting out the car convenient quality reaches to adapt to to receive visitors , and the ceremony and propriety necessaries are adoptd ) 。
(2)Horizontal scroll style
? This kind is opened to be put to use 、It is middle 、Second three smooth tracks are dominateeed the door of a car and are moved ,Yet either horizontal sliining is ised turned on slidinginging door such as draws the window ,Also there is the turing style placeeing out near revolveing the arm 。Such strong point was occupied when being opening , and the room is little ,When the bodywork side wall against the obstacle distance hour yet be able to completely open 。
(3)Collapse style
? Widely used greatly 、On the middle-sized passenger train 。
(4)On lifting style either fliies the wing style
  Car and small-size passenger train are widely used 、Back door that the ambulance awaits ,Also used the low motor vehicle front gate 。
  The door of a car is borrowed the hinge and is fixed the bodywork casing part of the body in 。When the motor vehicle plyes since being living ,The bodywork casing part of the body shall be come into being turning about the deformation again and again ,Proper greatter gap between the door of a car together with the doorframe ,Come into being the buzz in order to guard against reciprocally the rub ,Such gap near rubber is sealed airtight future densely 。
Car 、Ban of the door of a car that the goods train cab door of a car along with passenger train driver comeses in and go out usually through the door outside 、Cooked rice inner place the door 、The window frame ( still packing the triangle window on some buss ) awaits the component 。The outward Ban of door fixs the door and locks the outward laddle 7 。Ban is the different annex installation bases inner place the door 。Such is make up :Door hinge 、The glass ging up and down reaches such guide 、The glass gos up and down the utensil 、Door is locked 、Annex such as door of a car degree of turning on limiter and so on 。Still fix up that central heating ventilation piping and the stereo radio receiver loudspeaker awaits inner place some sedan doors of a car 。
  Some passengeres train are in the interest of gurrantee door of a car security ,By the door of a car geing up to shut unities against the brake ,In case the door of a car not Guan Hao ,The vehicle simply is in the brake condition ,That the motor also is in remisss the rapid condition ,And the top rinies , and the utensil rinies to sound ,Tell that driver takes the step 。
  The distinct places bus window adopt not isomorph shape and qualitative glass of distinct materials usually 。
  The bus window adopts being favour of field of vision and beautiful curve glass usually about the motor vehicle 。Contemporary sandwich glass that the motor vehicle overturned cart ahead window widely adoptd security 。If adoping ordinary glass ,The bus windowpane is living , and the collision of vehicles is smash the particular circumstances of the time and is stabbed and wounded driver 。Although it is very secure when the resin shape bus window is smash ,Yet come into being a stroke mark easily on the bus window ,The light reflects the chaos ,Effect field of vision expending glass such as polishs 。Reinforced glass is when some sections are stabbed and wounded by the keen matter ,Completely opening the glass has simply ariseed the kcarcle ,The kcarcle that splits is very much fine and closely woven ,Forfeit in the field of vision 。Hence ,The Asiatic plantain window adopts sandwich glass more 。Mingle the resin membrane between the sandwich glass ,Have higher shock intensity ,Accept the shock kcarcle afterwards coming into being spider net shape only ,Not forfeit such as reinforced glass in the field of vision 。,The resin membrane of middle may be guarded against glass splashing of fragments 。Decreasing glass destroys queen's haring two times by stabs and wounds 。Queen usable reinforced glass of bus window 。Bus window all fiing styles in the interest of admittedly about the motor vehicle ,Borrowing rubber seals airtight to inlay the window frame on either sticing the book of models in the way of the binder special is living on the window frame 。
  In the interest of is convenient for the natural ventilation ,The motor vehicle side windowpane may be removed usually up and down either altogether 。When removing up and down ,Be living to fix inner place the door of a car utensil that the hand stirs either power-driven glass gos up and down 。It is in the way of the hand shaking inner place the door of a car side laddle that the hand stirs ,Causing glass go up and down , the utensil is doed 。Power-driven is that such gos up and down packing the small-size electric motor inner place the utensil ,The bus the shuing window may be drive in the operation by means of the button 。Have in consummate daily life gas 、High-quality passenger train of ventilation air-condition ,The side windowpane should not be removed usually ,With sealing airtight quality of raise bodywork 。Be living to pack between glass together with the guide the sealing airtight the trough of stuffs such as wool fabric either flocking rubber and so on 。Some motors vehicle sides window still adopts the cylinder form glass being favour of the motor vehicle to fix up 。The side windowpane adopts dark brown either heat insulation straturm may cause heat preservation of interior have the tranquil cosy feeling 。
Motor vehicle pedestal bench
Inner place the bus in the outfit ,The pedestal bench is the unit that attracts the gaze of people most ,Frequently value its moldmaking . very much 。Through takes the human body projects such as cosy quality and guaranty are drive and so on see ,Unit that it is significant 。
发表于 21-7-2008 22:56:22 | 显示全部楼层
Thanks a lot
发表于 24-8-2008 10:00:52 | 显示全部楼层
恶补英语先!!
发表于 24-8-2008 15:01:04 | 显示全部楼层
支持,学习。
    慵懒
    21-6-2016 06:49
  • 签到天数: 18 天
    [LV.4]偶尔看看III
    发表于 14-3-2014 19:59:02 | 显示全部楼层
    it  is  good
    GMT+8, 13-5-2026 15:52 , Processed in 0.349481 second(s), 37 queries .
