  • 2196查看
[分享] Thorax Bag安全气囊
发表于 9-5-2008 18:34:41 | 显示全部楼层 |阅读模式
Thorax airbags are estimated to reduce serious chest injuries in side-impact collisions by approximately 25%.
The protective effect is obtained by keeping the occupant away from the impact zone, and dampening the blow from the intruding side of the vehicle. Since the occupant is kept away from the intruding vehicle side, protection of the head is also improved. For adequate head protection special airbags are required, however.
The thorax bag is inflated within 12 thousands of a second; four times faster than a frontal airbag. The bag is inflated at a certain crash threshold, usually corresponding to a speed of the impacting vehicle of more than 15-20 km/h.
The system consists of a sensor and a module. The module is typically installed in the back rests of the front seats. Some vehicles have their side-impact airbags in the doors. The sensor is placed in the door or in the B-post area and connected to the ECU (Electronic Control Unit) of the vehicle's other safety systems. The bag usually has a volume of only 12 liters to make it as gentle as possible but still efficient enough to provide required protection.
发表于 25-4-2025 23:22:02 | 显示全部楼层
作为一名汽车工程师,深知Thorax Bag安全气囊在汽车安全中的重要性。该安全气囊能够在碰撞时迅速充气,有效保护驾乘人员的胸部及重要器官。其采用先进的材料技术和设计,提升了气囊的耐用性和防护性能。为确保其有效性,建议车主遵循制造商的说明进行定期维护和检查。如有任何问题或疑虑,建议联系专业的汽车维修机构进行检查和维修,确保安全气囊在关键时刻发挥最大保护作用。
GMT+8, 10-6-2026 04:37 , Processed in 0.408414 second(s), 35 queries .
