  • 2317查看
[分享] 二次空气系统诊断
发表于 13-5-2008 19:09:07 | 显示全部楼层 |阅读模式
Secondary air system
The performance of the secondary air system was previously tested via the lambda control value. This means that the voltage present at the probe before the catalyst must indicate a lean mixture during secondary air discharge (l>1) although the engine control unit is running the engine on a rich mixture.
Flow rate diagnosis
Since the introduction of the broadband lambda probe, the signal from the probe before the catalyst is used for diagnosis purposes, because the broadband lambda probe supplies more detailed measurement results than the step type lambda probe for example. The actual air mass flow is calculated and checked on the basis of the lambda differential (lambda value before and during secondary air discharge).
发表于 17-5-2008 14:44:36 | 显示全部楼层
LZ是做什么专业的?在这看到了你几篇原版资料!不错,但看不懂。遗憾!!!
GMT+8, 11-5-2026 07:35 , Processed in 0.361090 second(s), 36 queries .
