  • 2823查看
车身英语
发表于 15-6-2008 21:28:34 | 显示全部楼层 |阅读模式
车身车间 :
凹:  dent                 凸: convex                     划伤 :scratch
残胶:residual glue          档孔:shaded hole                 离空:gap/see through gap
漏焊:missed welding point   焊穿:weld through               锈 : rust
变形:deformation          偏进:off set in                  偏出:off set out
间隙:gap(small)            间隙不均:gap uneven            毛刺:burr
凹凸波纹: wave           飞边:fin                        扭曲:distortion
干涉:interference           麻点:scab                    焊点凸:welding point dent
脱焊:poor welding          错位:dislocation                滑牙:thread damaged
腰线低:streamline misaligned   污染:contamination            平齐度:poor parallel
涂装车间:
流挂:run                 灰粒:dirt                     光泽差:poor gloss
桔皮:orange peel          发花:cloudy                   缩孔:shrink hole
针孔:pin hole             车身打磨印:grinding mark       漆薄: thin paint
打磨痕迹:sanding mark      湿印:wetting mark             斑痕:mottle mark
上胶质量差:poor sealing     油印:oil mark                 生锈:rusty
扳金缺陷:sheet metal defect
发表于 16-6-2008 16:39:38 | 显示全部楼层
搞得像qc
GMT+8, 9-6-2026 10:37 , Processed in 0.497944 second(s), 34 queries .
