  • 6325查看
  • 17回复
转向系英文Steering system
发表于 16-6-2008 16:47:44 | 显示全部楼层 |阅读模式
Steering system
Motor turning system: On the automobile uses for to change or restores its travel direction to suppose the organization to be called the motor turning system specially. Automobile's steering system is uses for to change the automobile travel direction and to maintain the automobile straight line travel organization
Composes
(1)To change the control mechanism basically mainly by the steering wheel, the steering axle, the steering tube column and so on to be composed.the
(2) Diverter becomes steering wheel's rotation steering arm's swinging or the rack axis straight reciprocating motion, and to changes the control force to carry on the enlargement the organization. The diverter fixes generally on the automobile frame or the automobile body, changes the control force after the diverter generally will also change the transmission direction.
(3)Changes the transmission system the strength which and the movement outputs the diverter passes to the wheel (knuckle), about and causes the wheel to carry on the deflection according to certain relations the organization.
Type
Crooked to energy difference, the steering system may divide into the machinery steering system and the power steering system two broad headings crooked.
Mechanical steering system: And changes the transmission system by the diverter to be composed.
Diverter: By the steering wheel, the steering wheel steering axle, changes meshing to pay (diverter) to be composed.
Changes the transmission system: By drop arm (drop arm), drag link, drag link arm, about trapezoidal arm, steering knuckle tie rod, if a dry bulb joint composes.
Power steering system: Changes the augmenter constitution by mechanical steering system Canada.
1.Mechanical steering system
The mechanical steering system changes the energy by pilot's physical strength achievement, all power transmission are the machinery. The mechanical steering system by changes the control mechanism, the diverter and changes the transmission system three major part to be composed.
(1)        Changes control mechanism
Changes the control mechanism by the steering wheel, the steering axle, the steering tube column and so on to be composed, its function is rotates the pilot steering wheel's control force to pass to the diverter.
(2)        Diverter
The diverter (also often is called steering unit) is completes from the rotary motion to the translation (or approximate straightline motion) a group of gear mechanism, simultaneously is also in the steering system speed reducer drive. At present the commonly used toothed wheel rack type, follows round the world the crank to refer to sells the type, the worm bearing adjuster crank to refer to sells the type, to follow round the world - the tooth rack tooth fan type, the worm bearing adjuster hoop type and so on. We mainly introduce the first several kinds.
1) Gear rack type diverter
The gear rack type diverter divides the both sides output type and among (or single end) the output type two kinds
The both sides output's gear rack type diverter, changes the gear shaft as the transmission vice-host moving parts and installs through the bearing in the diverter shell, its upper extreme through spline and universal joint sliding yoke and steering axle connection. With the steering gear meshing steering rack level arrangement, the both sides with change the steering knuckle tie rod through a ball place to be connected. The spring presses through the briquetting the rack depending in the gear, guarantees ceaseless meshing.
Spring's pretightening up force available adjustment thread plug adjustment. When rotates the steering wheel, the diverter gear-driven, causes with it meshing rack along the end motion, thus about causes the steering knuckle tie rod to lead about the knuckle to rotate, causes to change the wheel deflection, thus realizes motor turning.
Middle output gear rack type diverter, its structure and principle of work and both sides output gear rack type diverter basic same, the difference lies in it to change the steering knuckle tie rod in steering rack's middle with the bolt with about to be connected. On single-ended output's gear rack type diverter, a rack's end with changes the steering knuckle tie rod through the inside and outside bracket to be connected.
2) Follows round the world-like the diverter
  Follows round the world-like the diverter is one of present domestic and foreign application most widespread structure patterns, generally has two-stage drive, the first level is screw rod nut transmission, the second level is tooth rack tooth fan transmission.
  In order to reduce between the steering screw steering nut's friction, the two's thread immediate contact, during is loaded with many steel balls, realizes the rolling friction. On the steering screw and the nut processes the profiled outline is two section or three section of not concentric circular arc composition approximate semicircle spiral groove. The two's spiral groove can coordinate to form the approximate circular cross section the spiral tubular channel.
  The nut side has two pair of through holes, may henceforth the vent plug enter the steel ball in the helix channel. Outside the steering nut has two steel ball drive pipes, each drive pipe's both sides insert the nut side separately in a pair of through hole. In the drive pipe has also packed the steel ball. Thus, in two drive pipes and nut's spiral tubular channels combine two respectively independent seals the steel ball " the flow channel ".
  When the steering screw rotates, passes to the steering nut through the steel ball the strength, the nut namely along the end motion. At the same time, friction couple function between the screw rod and the nut and under the steel ball, all steel balls then rolls in the spiral tubular channel, formation " ball class ". When the diverter works, two rows steel balls are only in the respective seal flow channel internal recycling, will leave.
3)The worm bearing adjuster crank refers to sells the type diverter
  The worm bearing adjuster crank refers to sells the type diverter's transmission vice-(by the steering worm primarily moving parts, it is installs from the moving parts in the rocker arm shaft crank nose refers to sells. When the steering worm rotates, refers to with it meshing sells namely circles the rocker arm shaft spool thread along the circular, and leads the rocker arm shaft rotation.
  Changes the transmission system the function is the strength which and the movement outputs the diverter passes to the steering axle both sides the knuckle, causes the both sides wheering wheel deflection, and causes two wheering wheel deflection angles according to certain relational change, guarantees when motor turning the wheel and the ground relative sliding is as far as possible small.
1) Uses for parts with the non-independent suspension fork changes the transmission system
Uses for parts with the non-independent suspension fork changes the transmission system mainly to include the steering arm, to change the drag link, the steering, and the steering trapezium. In the front axle is only in the steering axle situation, by changes the steering trapezium general arrangement which the steering knuckle tie rod and the left and right trapezoidal arm are composed after the front axle, when the wheering wheel is in with the automobile straight line travel corresponding neutral point, trapezoidal arm and steering knuckle tie rod in and path parallel plane (horizontal plane) in angle of intersection >90.
In the engine position is low or in the steering axle concurrently sufficient driving axle's situation, to avoid the movement interference, often steering trapezium arrangement before the front axle, this time above angle of intersection <90, if the steering arm is not around swings in the automobile fore-and-aft plane, but is shaking right toward left with the path parallel plane, then may change the drag link horizontal, and sells taking advantage of ball leads directly changes the steering knuckle tie rod, thus pushes somebody into doing something the both sides trapezoidal arm rotation.
2)Uses for parts with the independent suspension fork changes the transmission system
  When wheering wheel independent suspension, each wheering wheel needs to be opposite in the frame makes the independence movement, thus the steering axle must be the separation type. With this corresponding, changes in the transmission system the steering trapezium also to be the separation type.
3)Changes the drag link
Changes drag link's function is the strength which and the movement transmits the steering arm passes to the steering trapezium arm (or steering). It receives the strength already has the pulling force, also to have the pressure, therefore the drag link is uses the high quality special steel products manufacture, guarantees the operation reliable. In wheering wheel deflection or because of suspension fork elastic deformation when is opposite beats in the frame, changes the drag link and the steering arm and the steering relative motion is the space motion, for does not have the movement interference, the above three connection uses the pin ball.
4)Changes the shock absorber
  Along with the vehicle speed enhancement, the modern automobile's wheering wheel will sometimes have the oscillation (wheering wheel to circle king pin spool thread reciprocation swinging, will cause complete bikes automobile body's vibration), not only this will affect automobile's stability, will also affect automobile's comfortableness, the aggravating front wheel tire's attrition. In changes in the transmission system to establish changes the shock absorber is overcomes the wheering wheel oscillation the effective action. Changes the shock absorber an end and the automobile body (or front axle) the hinge, another end and changes the drag link (or diverter) the hinge
 楼主| 发表于 16-6-2008 16:50:23 | 显示全部楼层
汽车转向系中文
转向系统
汽车转向系统:汽车上用来改变或恢复其行驶方向的专设机构称为汽车转向系统。汽车的转向系统是用来改变汽车行驶方向和保持汽车直线行驶的机构
基本组成
(1)转向操纵机构主要由转向盘、转向轴、转向管柱等组成。
(2)转向器将转向盘的转动变为转向摇臂的摆动或齿条轴的直线往复运动,并对转向操纵力进行放大的机构。转向器一般固定在汽车车架或车身上,转向操纵力通过转向器后一般还会改变传动方向。
(3)转向传动机构将转向器输出的力和运动传给车轮(转向节),并使左右车轮按一定关系进行偏转的机构。
类型
按转向能源的不同,转向系统可分为机械转向系统和动力转向系统两大类。
机械转向系:由转向器和转向传动机构组成.
转向器:由方向盘,方向盘转向轴,转向啮合付(转向器)组成.
转向传动机构:由转向臂(转向垂臂),直拉杆,直拉杆臂,左右梯形臂,横拉杆,若干球头关节组成.
动力转向系:由机械转向系加转向加力装置构成.
1.机械转向系
    机械转向系以驾驶员的体力作为转向能源,其中所有传力件都是机械的。机械转向系由转向操纵机构、转向器和转向传动机构三大部分组成。
(1)转向操纵机构
    转向操纵机构由方向盘、转向轴、转向管柱等组成,它的作用是将驾驶员转动转向盘的操纵力传给转向器。
(2) 转向器
    转向器(也常称为转向机)是完成由旋转运动到直线运动(或近似直线运动)的一组齿轮机构,同时也是转向系中的减速传动装置。 目前较常用的有齿轮齿条式、循环球曲柄指销式、蜗杆曲柄指销式、循环球-齿条齿扇式、蜗杆滚轮式等。我们主要介绍前几种。】
1)齿轮齿条式转向器
    齿轮齿条式转向器分两端输出式和中间(或单端)输出式两种。
    两端输出的齿轮齿条式转向器,作为传动副主动件的转向齿轮轴通过轴承和安装在转向器壳体中,其上端通过花键与万向节叉和转向轴连接。与转向齿轮啮合的转向齿条水平布置,两端通过球头座与转向横拉杆相连。弹簧通过压块将齿条压靠在齿轮上,保证无间隙啮合。
    弹簧的预紧力可用调整螺塞调整。当转动转向盘时,转向器齿轮转动,使与之啮合的齿条沿轴向移动,从而使左右横拉杆带动转向节左右转动,使转向车轮偏转,从而实现汽车转向。
    中间输出的齿轮齿条式转向器,其结构及工作原理与两端输出的齿轮齿条式转向器基本相同,不同之处在于它在转向齿条的中部用螺栓与左右转向横拉杆相连。在单端输出的齿轮齿条式转向器上,齿条的一端通过内外托架与转向横拉杆相连。
2)循环球式转向器
    循环球式转向器是目前国内外应用最广泛的结构型式之一, 一般有两级传动副,第一级是螺杆螺母传动副,第二级是齿条齿扇传动副。
    为了减少转向螺杆转向螺母之间的摩擦,二者的螺纹并不直接接触,其间装有多个钢球,以实现滚动摩擦。转向螺杆和螺母上都加工出断面轮廓为两段或三段不同心圆弧组成的近似半圆的螺旋槽。二者的螺旋槽能配合形成近似圆形断面的螺旋管状通道。
    螺母侧面有两对通孔,可将钢球从此孔塞入螺旋形通道内。转向螺母外有两根钢球导管,每根导管的两端分别插入螺母侧面的一对通孔中。导管内也装满了钢球。这样,两根导管和螺母内的螺旋管状通道组合成两条各自独立的封闭的钢球"流道"。
    转向螺杆转动时,通过钢球将力传给转向螺母,螺母即沿轴向移动。同时,在螺杆及螺母与钢球间的摩擦力偶作用下,所有钢球便在螺旋管状通道内滚动,形成"球流"。在转向器工作时,两列钢球只是在各自的封闭流道内循环,不会脱出。
3)蜗杆曲柄指销式转向器
    蜗杆曲柄指销式转向器的传动副(以转向蜗杆为主动件,其从动件是装在摇臂轴曲柄端部的指销。转向蜗杆转动时,与之啮合的指销即绕摇臂轴轴线沿圆弧运动,并带动摇臂轴转动。
(3)转向传动机构
    转向传动机构的功用是将转向器输出的力和运动传到转向桥两侧的转向节,使两侧转向轮偏转,且使二转向轮偏转角按一定关系变化,以保证汽车转向时车轮与地面的相对滑动尽可能小。
1)与非独立悬架配用的转向传动机构
    与非独立悬架配用的转向传动机构主要包括转向摇臂、转向直拉杆、转向节臂、和转向梯形。在前桥仅为转向桥的情况下,由转向横拉杆和左、右梯形臂组成的转向梯形一般布置在前桥之后,当转向轮处于与汽车直线行驶相应的中立位置时,梯形臂与横拉杆在与道路平行的平面(水平面)内的交角>90。
    在发动机位置较低或转向桥兼充驱动桥的情况下,为避免运动干涉,往往将转向梯形布置在前桥之前,此时上述交角<90,若转向摇臂不是在汽车纵向平面内前后摆动,而是在与道路平行的平面向左右摇动,则可将转向直拉杆横置,并借球头销直接带动转向横拉杆,从而推使两侧梯形臂转动。
2)与独立悬架配用的转向传动机构
    当转向轮独立悬挂时,每个转向轮都需要相对于车架作独立运动,因而转向桥必须是断开式的。与此相应,转向传动机构中的转向梯形也必须是断开式的。
3)转向直拉杆
    转向直拉杆的作用是将转向摇臂传来的力和运动传给转向梯形臂(或转向节臂)。它所受的力既有拉力、也有压力,因此直拉杆都是采用优质特种钢材制造的,以保证工作可靠。在转向轮偏转或因悬架弹性变形而相对于车架跳动时,转向直拉杆与转向摇臂及转向节臂的相对运动都是空间运动,为了不发生运动干涉,上述三者间的连接都采用球销。
4)转向减振器
    随着车速的提高,现代汽车的转向轮有时会产生摆振(转向轮绕主销轴线往复摆动,甚至引起整车车身的振动),这不仅影响汽车的稳定性,而且还影响汽车的舒适性、加剧前轮轮胎的磨损。在转向传动机构中设置转向减振器是克服转向轮摆振的有效措施。转向减振器的一端与车身(或前桥)铰接,另一端与转向直拉杆(或转向器)铰接。
发表于 16-6-2008 20:56:07 | 显示全部楼层
中英文对照,辛苦LZ了,谢谢
发表于 1-4-2009 16:09:41 | 显示全部楼层
OMG,这正是我所需要的,谢谢咯
发表于 2-4-2009 04:26:41 | 显示全部楼层
楼主不厚道啊
怎么不能复制粘贴啊????
发表于 2-4-2009 23:42:02 | 显示全部楼层
顶下楼主菊花   谢谢 了啊
发表于 5-4-2009 12:52:06 | 显示全部楼层
顶顶
楼主辛苦了,怎么不够3000字啊
发表于 6-4-2009 15:48:07 | 显示全部楼层
谢谢 楼主啦 不能粘贴 真郁闷
发表于 4-3-2010 21:10:07 | 显示全部楼层
楼主辛苦了
发表于 6-3-2010 17:13:37 | 显示全部楼层
辛苦了!
发表于 16-3-2010 16:47:56 | 显示全部楼层
辛苦了哦!
发表于 16-3-2010 17:01:52 | 显示全部楼层
怎么下载啊?
发表于 29-3-2010 09:46:32 | 显示全部楼层
是啊 无解  不能COPY啊
发表于 11-4-2010 14:47:39 | 显示全部楼层
yao lunwen  xingshi de bijiao hao  buguo ye bucuole
发表于 6-5-2010 07:30:58 | 显示全部楼层
楼主能让我们复制一下吗
GMT+8, 15-5-2026 08:16 , Processed in 0.400532 second(s), 46 queries .
