  • 1496查看
请教pro-e如何导出标准G代码
发表于 19-6-2008 19:59:13 | 显示全部楼层 |阅读模式
请教pro-e如何导出标准G代码
请教各位前辈,
pro-e能否导出表准G代码
如果能,怎么导出?
发表于 19-6-2008 19:59:21 | 显示全部楼层
In Pro/NC, retrieve the manufacturing model pplab1.mfg. In the CL Data menu, Output the Operation OP010(the file you output before ) to a File, checking both the CL File and the MCD File options. Accept the default name pplab1.ncl for the CL file. From the PP Options menu check only the Verbose option and click Done. Select the post-processor UNCX01.01(based on the machine you want)  from the PP List menu and click Done. At the end of the execution, click Close to quit the Pro/NC information window. In the work dirctroy, you will find the op010.tap lst, open with notepad.
GMT+8, 13-4-2026 20:47 , Processed in 0.411787 second(s), 32 queries .
