  • 1576查看
设置导向时遇到的连接问题!
发表于 26-6-2008 23:49:39 | 显示全部楼层 |阅读模式
设置导向时遇到的连接问题!
BEGIN search (LINER)
  Searching for Liner node sets...
                                        NOTE
    'Distance Crankshaft Axis - Liner Top' value in 'Crank Train Globals' dialog
    not specified!
    ACTION: Distance Crankshaft Axis - Liner Top will be determined internally.
                                        NOTE
    not specified!
                                      WARNING
    Liner #6 node sets not found!
    POSSIBLE REASON(S):
    1) orientation of the Liner FE Model does not correspond to the 'Global
       Axes of FE-Model' defined in the 'Excite>FEM Preferences' dialog;
    2) origin of the Liner FE Model does not lay along the Liner vertical axis;
    3) no 'active' Liner FE nodes defined in the .DOFT file (those having at
       least one active DOF);
    4) coordinates of some/all nodes of interest not defined in the global rect-
       angular coordinate system;
    5) no Liner FE nodes defined in the .GEOM file at all;
    6) tolerance specified in the 'Node Sets Search' dialog is too fine;
    7) values of the FE model coordinates do not match the Simulation Units.
  Done.
发表于 26-6-2008 23:49:56 | 显示全部楼层
坐标系,单位制等都可能导致搜索不到节点,请安装primer解释的步骤一步一步对照做
发表于 26-6-2008 23:50:01 | 显示全部楼层
希望各位指导下用excite做V6发动机需要注意的事项
发表于 26-6-2008 23:50:06 | 显示全部楼层
我已经建好了模型,不过我的缸套到最后还是自定义连上的 (auto就是找不到),仿真的时候出现了常遇到的间隙过大的问题(进行了几步迭代,不过时间太短impress看不到脱离过程),我是按照培训教程设置的刚度和阻尼,基本都是设置的最大值,怎么还能脱离呢?我的主轴颈是严格按旋转轴拉出来的,报错说的radial slider02_1是指的那个轴承?
GMT+8, 16-4-2026 03:29 , Processed in 0.384304 second(s), 37 queries .
