  • 3696查看
请问conventional port deactivation 怎么翻译?
发表于 11-7-2008 13:17:39 | 显示全部楼层 |阅读模式
conventional port deactivation怎么翻?
split port concepts 什么意思?
还有 reduced swirl number 怎么翻?
发表于 11-7-2008 16:51:39 | 显示全部楼层
交流一下,不一定准确
port 在汽车英语中是 “通气道,通气口”的意思,valve port 就是气门座
conventional port deactivation, 我理解的是 :常规性气口老化(这时需要更换通气口管了),其实我觉得就是汽车修理中遇到的一个长见问题吧。
split port concepts  分隔式通气口概念
reduced swirl number  减小涡流系数
清雅轩 + 4 热心人士【论坛口号→知无不言,言无不尽】
发表于 12-9-2008 15:26:40 | 显示全部楼层
I have the same way.
发表于 11-1-2012 16:49:42 | 显示全部楼层
4楼够专业,PDA
    21-8-2017 18:34
    发表于 10-1-2012 16:25:36 | 显示全部楼层
    conventional Port Deactivation  绝对不是什么常规性气口,还老化……  误人子弟啊!PDA是菲亚特发动机独有的一种技术,看下文:
    PDA (Port De-Activation) system which "ensures high exhaust gas recirculation, resulting in combustion stability at low speeds and optimal performance at high speeds together with improved fuel efficiency." The PDA system also reduces emissions.
    Read more: http://wiki.answers.com/Q/What_i ... ology#ixzz1j2ebk7AF
    发表于 2-8-2012 10:47:21 | 显示全部楼层
    请问一下PDA和VIM(Variable Intake Manifold)有啥区别,控制方面?
    GMT+8, 14-5-2026 12:25 , Processed in 0.451940 second(s), 42 queries .
