  • 18833查看
組裝、衝壓、噴漆等專業詞匯
发表于 23-11-2008 16:29:40 | 显示全部楼层 |阅读模式
組裝、衝壓、噴漆等專業詞匯
Assembly line組裝線
Layout布置圖
Conveyer流水線物料板
Rivet table拉釘機
Rivet gun拉釘槍
Screw driver起子
Electric screw driver電動起子
Pneumatic screw driver氣動起子
worktable 工作桌
OOBA開箱檢查
fit together組裝在一起
fasten鎖緊(螺絲)
fixture 夾具(治具)
pallet棧板
barcode條碼
barcode scanner條碼掃描器
fuse together熔合
fuse machine熱熔機
repair修理
operator作業員
QC品管
supervisor 課長
ME制造工程師
MT製造生技
cosmetic inspect外觀檢查
inner parts inspect內部檢查
thumb screw大頭螺絲
lbs.inch鎊、英寸
EMI gasket導電條
front plate前板
rear plate后板
chassis |'∫æsi| 基座
bezel panel面板
power button電源按鍵
reset button重置鍵
Hi-pot test of SPS高源高壓測試
Voltage switch of SPS
電源電壓接柆鍵
sheet metal parts 沖件
plastic parts塑膠件
SOP製造作業程序
material check list物料檢查表
work cell工作間
trolley台車
carton紙箱
sub-line支線
left fork叉車
personnel resource department
人力資源部
production department生產部門
planning department企劃部
QC Section品管科
stamping factory沖壓廠
painting factory烤漆廠
molding factory成型廠
common equipment常用設備
uncoiler and straightener整平機
punching machine 沖床
robot機械手
hydraulic machine油壓機
lathe車床
planer |'plein|刨床
miller銑床
grinder磨床
driller鉆床
linear cutting線切割
electrical sparkle電火花
welder電焊機
staker=reviting machine鉚合機
position職務
president董事長
general manager總經理
special assistant manager特助
factory director廠長
department director部長
deputy manager |'depjuti| =vice manager副理
section supervisor課長
deputy section supervisor =vice section superisor副課長
group leader/supervisor組長
line supervisor線長
assistant manager助理
to move, to carry, to handle搬運
be put in storage入庫
pack packing包裝
to apply oil擦油
to file burr 銼毛刺
final inspection終檢
to connect material接料
to reverse material 翻料
wet station沾濕台
Tiana天那水
cleaning cloth抹布
to load material上料
to unload material卸料
to return material/stock to退料
scraped |'skræpid|報廢
scrape ..v.刮;削
deficient purchase來料不良
manufacture procedure制程
deficient manufacturing procedure制程不良
oxidation |' ksi'dein|氧化
scratch刮傷
dents壓痕
defective upsiding down抽芽不良
defective to staking鉚合不良
embeded lump|in'bed| |lmp|鑲塊
feeding is not in place送料不到位
stamping-missing漏沖
production capacity生產力
education and training教育與訓練
proposal improvement提案改善
spare parts=buffer備件
forklift叉車
trailer=long vehicle拖板車
compound die合模
die locker鎖模器
pressure plate=plate pinch壓板
bolt螺栓
name of a department部門名稱
administration/general affairs dept總務部
automatic screwdriver電動啟子
thickness gauge厚薄規
gauge(or jig)治具
power wire電源線
buzzle蜂鳴器
defective product label不良標簽
identifying sheet list標示單
screwdriver holder起子插座
pedal踩踏板
stopper阻擋器
flow board流水板
hydraulic handjack油壓板車
forklift叉車
pallet棧板
glove(s)手套
glove(s) with exposed fingers割手套
thumb大拇指
forefinger食指
midfinger中指
ring finger無名指
little finger小指
band-aid創可貼
iudustrial alcohol工業酒精
alcohol container沾濕台
head of screwdriver起子頭
sweeper掃把
mop拖把
vaccum cleaner吸塵器
rag 抹布
garbage container灰箕
garbage can垃圾箱
garbage bag垃圾袋
chain鏈條
jack升降機
production line流水線
chain鏈條槽
magnetizer加磁器
lamp holder燈架
to mop the floor拖地
to clean the floor掃地
to clean a table擦桌子
air pipe 氣管
packaging tool打包機
packaging打包
missing part漏件
wrong part錯件
excessive defects過多的缺陷
critical defect極嚴重缺陷
major defect主要缺陷
minor defect次要缺陷
not up to standard不合規格
dimension/size is a little bigger尺寸偏大(小)
cosmetic defect外觀不良
slipped screwhead/slippery screw head螺絲滑頭
slipped screwhead/shippery screw thread滑手
speckle斑點
mildewed=moldy=mouldy發霉
rust生銹
deformation變形
burr(金屬)flash(塑件)毛邊
poor staking鉚合不良
excesssive gap間隙過大
grease/oil stains油污
inclusion雜質
painting peel off臟污
shrinking/shrinkage縮水
mixed color雜色
scratch劃傷
poor processing 制程不良
poor incoming part事件不良
fold of pakaging belt打包帶折皺
painting make-up補漆
discoloration羿色
water spots水漬
polishing/surface processing表面處理
exposed metal/bare metal金屬裸露
lack of painting烤漆不到位
safety安全
quality品質
delivery deadline交貨期
cost成本
engineering工程
die repair模修
enterprise plan = enterprise expansion projects企劃
QC品管
die worker模工
production, to produce生產
equipment設備
to start a press開機
stop/switch off a press關機
classification整理
regulation整頓
cleanness清掃
conservation清潔
culture教養
qualified products, up-to-grade products良品
defective products, not up-to-grade products不良品
waste廢料
board看板
feeder送料機
sliding rack滑料架
defective product box不良品箱
die change 換模
to fix a die裝模
to take apart a die拆模
to repair a die修模
packing material包材
basket蝴蝶竺
plastic basket膠筐
isolating plate baffle plate; barricade隔板
carton box紙箱
to pull and stretch拉深
to put material in place, to cut material, to input落料
to impose lines壓線
to compress, compressing壓縮
character die字模
to feed, feeding送料
transportation運輸
(be)qualfied, up to grade合格
not up to grade, not qualified不合格
material change, stock change材料變更
feature change 特性變更
evaluation評估
prepare for, make preparations for 準備
parameters參數
rotating speed, revolution轉速
manufacture management製造管理
abnormal handling異常處理
production unit生產單位
lots of production生產批量
steel plate鋼板
roll material捲料
operation procedure作業流程
to revise, modify修訂
to switch over to, switch---to throw--over switching over切換
engineering, project difficulty工程瓶頸
stage die工程模
automation自動化
to stake, staking, reviting鉚合
add lubricating oil加潤滑油
shut die架模
shut height of a die架模高度
analog-mode device類模器
die lifter舉模器
argon welding氬焊
vocabulary for stamping
衝壓常詞匯
stamping, press沖壓
punch press, dieing out press沖床
uncoiler & strainghtener整平機
feeder送料機
rack, shelf, stack料架
cylinder油缸
robot機械手
taker取料機
conveyer belt輸送帶
transmission rack輸送架
top stop上死點
bottom stop下死點
one stroke一行程
inch寸動
to continue, cont.連動
to grip(material)吸料
location lump, locating piece, block stop 定位塊
reset復位
smoothly順利
dent壓痕
scratch刮傷
deformation變形
filings鐵削
to draw holes抽孔
inquiry, search for查尋
to stock, storage, in stock庫存
receive領取
approval examine and verify審核
processing, to process加工
delivery, to deliver 交貨
to return delivenry to. to send delinery back to retrn of goods退貨
registration登記
registration card登記卡
to control管制
to put forward and hand in提報
safe stock安全庫存
acceptance = receive驗收
to notice通知
application form for purchase請購單
consume, consumption消耗
to fill in填寫
abrasion磨損
reverse angle = chamfer倒角
character die字模
to collect, to gather收集
failure, trouble故障
statistics統計
demand and supply需求
career card履歷卡
to take apart a die卸下模具
to load a die裝上模具
to tight a bolt擰緊螺栓
to looser a bolt擰鬆螺栓
to move away a die plate移走模板
easily damaged parts易損件
standard parts標準件
breaking.(be)broken,(be)cracked 斷裂
to lubricate潤滑
common vocabulary for die engineering模具工程常用詞匯
die 模具
figure file, chart file圖檔
cutting die, blanking die沖裁模
progressive die, follow (-on)die
連續模
compound die復合模
punched hole沖孔
panel board鑲塊
to cutedges=side cut=side scrap切邊
to bending折彎
to pull, to stretch拉伸
Line streching, line pulling線拉伸
engraving, to engrave刻印
upsiding down edges翻邊
to stake鉚合
designing, to design設計
design modification設計變化
die block模塊
folded block折彎塊
sliding block滑塊
location pin定位銷
lifting pin頂料銷
die plate, front board模板
padding block墊塊
stepping bar墊條
upper die base上模座
lower die base下模座
upper supporting blank上承板
upper padding plate blank上墊板
spare dies模具備品
spring 彈簧
bolt螺栓
document folder文件夾
file folder資料夾
to put file in order整理資料
spare tools location手工備品倉
first count初盤人
first check初盤復櫂人
second count 復盤人
second check復盤復核人
equipment設備
waste materials廢料
work in progress product在制品
casing = containerazation裝箱
quantity of physical invetory second count 復盤點數量
quantity of customs count
會計師盤,點數量
the first page第一聯
filed by accounting department for reference會計部存查
end-user/using unit(department)使用單位
summary of year-end physical inventory bills
年終盤點截止單據匯總表
bill name單據名稱
This sheet and physical inventory list will be sent to accounting department together (Those of NHK will be sent to financial department)
本表請與盤點清冊一起送會計部-(NHK廠區送財會部)
Application status records of year-end physical inventory List and physical inventory card 年終盤點卡與清冊使用-狀況明細表
blank and waste sheet NO.
空白與作廢單號
plate電鍍
mold成型
material for engineering mold testing工程試模材料
not included in physical inventory不列入盤點
sample樣品
incoming material to be inspected進貨待驗
description品名
steel/rolled steel鋼材
material statistics sheet
物料統計明細表
meeting minutes會議記錄
meeting type 會別
distribution department分發單位
location地點
chairman主席
present members出席人員
subject主題
conclusion結論
decision items決議事項
responsible department負責單位
pre-fixed finishing date預定完成日
approved by / checked by / prepared by核準/審核/承辦
PCE assembly production schedule sheet
PCE組裝廠生產排配表
model機鍾
work order工令
revision版次
remark備注
production control confirmation生產確認
checked by初審
approved by核準
department部門
stock age analysis sheet
庫存貨齡分析表
on-hand inventory現有庫存
available material良品可使用
obsolete material良品已呆滯
to be inspected or reworked
待驗或重工
total合計
cause description原因說明
part number/ P/N 料號
type形態
item/group/class類別
quality品質
prepared by制表
notes說明
year-end physical inventory difference analysis sheet
年終盤點差異分析表
physical inventory盤點數量
physical count quantity帳面數量
difference quantity差異量
cause analysis原因分析
raw materials原料
materials物料
finished product成品
semi-finished product半成品
packing materials包材
good product/accepted goods/ accepted parts/good parts良品
defective product/non-good parts不良品
disposed goods處理品
warehouse/hub倉庫
on way location在途倉
oversea location海外倉
spare parts physical inventory list備品盤點清單
spare molds location模具備品倉
skid/pallet棧板
tox machine自鉚機
wire EDM線割
EDM放電機
coil stock卷料
sheet stock片料
tolerance工差
score=groove壓線
cam block滑塊
pilot導正筒
trim剪外邊
pierce剪內邊
drag form壓鍛差
pocket for the punch head挂鉤槽
slug hole廢料孔
feature die公母模
expansion dwg展開圖
radius半徑
shim(wedge)楔子
torch-flame cut火焰切割
set screw止付螺絲
form block折刀
stop pin定位銷
round pierce punch=die button圓沖子
shape punch=die insert異形子
stock locater block定位塊
under cut=scrap chopper清角
active plate活動板
baffle plate擋塊
cover plate蓋板
male die公模
female die母模
groove punch壓線沖子
air-cushion eject-rod氣墊頂桿
spring-box eject-plate彈簧箱頂板
bushing block襯套
insert 入塊
club car高爾夫球車
capability能力
parameter參數
factor系數
phosphate皮膜化成
viscosity涂料粘度
alkalidipping脫脂
main manifold主集流脈
bezel斜視規
blanking穿落模
dejecting頂固模
demagnetization去磁;消磁
high-speed transmission高速傳遞
heat dissipation熱傳
rack上料
degrease脫脂
rinse水洗
alkaline etch齡咬
desmut剝黑膜
D.I. rinse純水次
Chromate鉻酸處理
Anodize陽性處理
seal封孔
revision版次
part number/P/N料號
good products良品
scraped products報放心品
defective products不良品
finished products成品
disposed products處理品
barcode條碼
flow chart流程表單
assembly組裝
stamping沖壓
molding成型
spare parts=buffer備品
coordinate座標
dismantle the die折模
auxiliary fuction輔助功能
poly-line多義線
heater band 加熱片
thermocouple熱電偶
sand blasting噴沙
grit 砂礫
derusting machine除銹機
degate打澆口
dryer烘干機
induction感應
induction light感應光
response=reaction=interaction感應
ram連杆
edge finder巡邊器
concave凸
convex凹
short射料不足
nick缺口
speck瑕疪
shine亮班
splay 銀紋
gas mark焦痕
delamination起鱗
cold slug冷塊
blush 導色
gouge溝槽;鑿槽
satin texture段面咬花
witness line證示線
patent專利
grit沙礫
granule=peuet=grain細粒
grit maker抽粒機
cushion緩沖
magnalium鎂鋁合金
magnesium鎂金
metal plate鈑金
lathe車
mill銼
plane鉋
grind磨
drill鋁
boring鏜
blinster氣泡
fillet鑲;嵌邊
through-hole form通孔形式
voller pin formality滾針形式
cam driver鍘楔
shank摸柄
crank shaft曲柄軸
augular offset角度偏差
velocity速度
production tempo生產進度現狀
torque扭矩
spline=the multiple keys花鍵
quenching淬火
tempering回火
annealing退火
carbonization碳化
alloy合金
tungsten high speed steel鎢高速的
moly high speed steel鉬高速的
organic solvent有機溶劑
bracket小磁導
liaison聯絡單
volatile揮發性
resistance電阻
ion離子
titrator滴定儀
beacon警示燈
coolant冷卻液
crusher破碎機
模具工程類
plain die簡易模
pierce die沖孔模
forming die成型模
progressive die連續模
gang dies複合模
shearing die剪邊模
riveting die鉚合模
pierce沖孔
forming成型(抽凸,沖凸)
draw hole抽孔
bending折彎
trim切邊
emboss凸點
dome凸圓
semi-shearing半剪
stamp mark沖記號
deburr or coin壓毛邊
punch riveting沖壓鉚合
side stretch側沖壓平
reel stretch卷圓壓平
groove壓線
blanking下料
stamp letter沖字(料號)
shearing剪斷
tick-mark nearside正面壓印
tick-mark farside反面壓印
沖壓名稱類
extension dwg展開圖
procedure dwg工程圖
die structure dwg模具結構圖
material材質
material thickness料片厚度
factor系數
upward向上
downward向下
press specification沖床規格
die height range適用模高
die height閉模高度
burr毛邊
gap間隙
weight重量
total wt.總重量
punch wt.上模重量
五金零件類
inner guiding post內導柱
inner hexagon screw內六角螺釘
dowel pin固定銷
coil spring彈簧
lifter pin頂料銷
eq-height sleeves=spool等高套筒
pin銷
lifter guide pin浮升導料銷
guide pin導正銷
wire spring圓線彈簧
outer guiding post外導柱
stop screw止付螺絲
located pin定位銷
outer bush外導套
模板類
top plate上托板(頂板)
top block上墊腳
punch set上模座
punch pad上墊板
punch holder上夾板
stripper pad脫料背板
up stripper上脫料板
male die公模(凸模)
feature die公母模
female die母模(凹模)
upper plate上模板
lower plate下模板
die pad下墊板
die holder下夾板
die set下模座
bottom block下墊腳
bottom plate下托板(底板)
stripping plate內外打(脫料板)
outer stripper外脫料板
inner stripper內脫料板
lower stripper下脫料板
零件類
punch沖頭
insert入塊(嵌入件)
deburring punch壓毛邊沖子
groove punch壓線沖子
stamped punch字模沖子
round punch圓沖子
special shape punch異形沖子
bending block折刀
roller滾軸
baffle plate擋塊
located block定位塊
supporting block for location
定位支承塊
air cushion plate氣墊板
trimming punch切邊沖子
stiffening rib punch = stinger 加強筋衝子
ribbon punch壓筋沖子
reel-stretch punch卷圓壓平沖子
guide plate定位板
sliding block滑塊
sliding dowel block滑塊固定塊
active plate活動板
lower sliding plate下滑塊板
upper holder block上壓塊
upper mid plate上中間板
spring box彈簧箱
spring-box eject-rod彈簧箱頂桿
bushing bolck襯套
cover plate蓋板
guide pad導料塊
塑件&模具相關英文
compre sion molding壓縮成型
       flash mold溢流式模具
       plsitive mold擠壓式模具
       split mold分割式模具
cavity型控 母模
core模心 公模
taper錐拔
leather cloak倣皮革
shiver飾紋
flow mark流痕
welding mark溶合痕
post screw insert螺紋套筒埋值
self tapping screw自攻螺絲
striper plate脫料板
piston活塞
cylinder汽缸套
chip細碎物
handle mold手持式模具
移轉成型用模具
encapsulation molding低壓封裝成型
射出成型用模具
two plate兩極式(模具)
well type蓄料井
insulated runner絕緣澆道方式
hot runner熱澆道
runner plat澆道模塊
valve gate閥門澆口
band heater環帶狀的電熱器
spindle閥針
spear head鉋尖頭
slag well冷料井
cold slag冷料渣
air vent排氣道
h=0.02~0.05mm
w=3.2mm
L=3~5mm
welding line熔合痕
eject pin頂出針
knock pin頂出銷
return pin回位銷反頂針
sleave套筒
stripper plate脫料板
insert core放置入子
runner stripper plate澆道脫料板
guide pin導銷
eject rod (bar)(成型機)頂業捧
subzero深冷處理
three plate三極式模具
runner system澆道系統
stress crack應力電裂
orientation定向
sprue gate射料澆口,直澆口
nozzle射嘴
sprue lock pin料頭鉤銷(拉料杆)
slag well冷料井
side gate側澆口
edge gate側緣澆口
tab gate搭接澆口
film gate薄膜澆口
flash gate閘門澆口
slit gate縫隙澆口
fan gate扇形澆口
dish gate因盤形澆口
H=F=1/2t~1/5t
T=2.5~3.5mm
diaphragm gate隔膜澆口
ring gate環形澆口
subarine gate潛入式澆口
tunnel gate隧道式澆口
pin gate針點澆口
Φ0.8~1.0mm
Runner less無澆道
    (sprue less)無射料管方式
long nozzle延長噴嘴方式
sprue澆口;溶渣
品質人員名稱類
QC   quality control  品質管理人員
FQC   final quality control  終點品質管制人員
IPQC   in process quality control  制程中的品質管制人員
OQC  output quality control  最終出貨品質管制人員
IQC  incoming quality control  進料品質管制人員
TQC  total quality control  全面質量管理
POC  passage quality control  段檢人員
QA  quality assurance  質量保證人員
OQA  output quality assurance  出貨質量保證人員
QE  quality engineering  品質工程人員
品質保證類
FAI   first article inspection  新品首件檢查
FAA  first article assurance  首件確認
TVR  tool verification report  模具確認報告
3B  3B  模具正式投產前確認
CP  capability index  能力指數
CPK  capability index of process  模具製程能力參數
SSQA  standardized supplier quality  合格供應商品質評估
OOBA  out of box audit  開箱檢查
QFD  quality function deployment  品質機能展開
FMEA  failure model effectiveness analysis  失效模式分析
  8 disciplines  8項回復內容
FA  final audit  最後一次稽核
CAR  corrective action request  改正行動要求
  corrective action report  改正行動報告
FQC運作類
AQL  Acceptable Quality Level  運作類允收品質水準
S/S  Sample size  抽樣檢驗樣本大小
ACC  Accept  允收
REE  Reject  拒收
CR  Critical  極嚴重的
MAJ  Major  主要的
MIN  Minor  輕微的
AOQ  Average Output Quality  平均出廠品質
AOQL  Average Output Quality Level  平均出廠品質
Q/R/S  Quality/Reliability/Service  品質/可靠度服務
MIL-STD  Military-Standard  軍用標準
S I-S IV  Special I-Special IV  特殊抽樣水準等級
P/N  Part Number  料號
L/N   Lot Number  特采
AOD  Accept On Deviation  特采
UAI  Use As It  首件檢查報告
FPIR  First Piece Inspection Report  百萬分之一
PPM  Percent Per Million  批號
制程統計品管專類
SPC  Statistical Process Control  統計製程管制
SQC  Statistical Quality Control  統計品質管制
R  Range  全距
AR  Averary Range  全距平均值
UCL  Upper Central Limit  管制上限
LCL  Lower Central Limit  管制下限
MAX  Maximum  最大值
MIN  Minimum  最小值
GRR  Gauge Reproducibility&Repeatability  量具之再制性及重測性判斷量可靠與否
DIM  Dimension  尺寸
DIA  Diameter  直徑
FREQ  Frequency  頻率
N  Number  樣品數
其它品質術語類
QCC  Quality Control Circle  品質圈
QIT  Quality Improvement Team  品質改善小組
PDCA  Plan Do Check Action  計劃 執行 檢查 總結
ZD  Zero Defect  零缺點
QI  Quality Improvement  品質改善
QP  Quality Policy  目標方針
TQM  Total Quality Management  全面品質管理
MRB  Material Reject Bill  退貨單
LQL  Limiting Quality Level  最低品質水準
RMA  Return Material Audit  退料認可
QAN  Quality Amelionrate Notice  品質改善活動
ADM  Absolute Dimension Measuremat  全尺寸測量
QT  Quality Target  品質目標
7QCTools  7 Quality Controll Tools  品管七大手法
通用之件類
ECN  Engineering Change Notes  工程變更通知(供應商)
ECO  Engineering Change Order  工程改動要求(客戶)
PCN  Process Change Notice  工序改動通知
PMP  Product Management Plan  生產管制計劃
SIP  Specification In Process  製程檢驗規格
SOP  Standard Operation Procedure  製造作業規範
IS  Inspection Specification  成品檢驗規範
BOM  Bill Of Material  物料清單
PS  Package Specification  包裝規範
SPEC  Specification  規格
DWG  Drawing  圖面
系統文件類
QC  Quality System  品質系統
ES  Engineering Standarization  工程標準
CGOO  China General  PCE龍華廠文件
H  Huston  (美國)休斯敦
C  Compaq  (美國)康伯公司
C  China  中國大陸
A  Assembly  組裝(廠)
S  Stamping  沖壓(廠)
P  Painting  烤漆(廠)
I  Intel  英特爾公司
T  TAIWAN  臺灣
IWS  International Workman Standard  工藝標準
ISO  International Standard Organization  國際標準化組織
GS  General Specification  一般規格
CMCS  C-China M-Manufact C-Compaq S-Stamping  Compaq產品在龍華衝壓廠製造作業規範
CQCA  Q-Quality A-Assembly  Compaq產品在龍華組裝廠品管作業規範
CQCP  P-Painting  Compaq產品在龍華烤漆廠品管作業規範
部類
PMC   Production & Material Control  生產和物料控制
PPC  Production Plan Control  生產計劃控制
MC  Material Control  物料控制
ME  Manafacture Engineering  製造工程部
PE  Project Engineering  產品工程部
A/C  Accountant Dept  會計部
P/A  Personal & Administration  人事行政部
DC  Document Center  資料中心
QE  Quality Engineering  品質工程(部)
QA  Quality Assurance  品質保證(處)
QC  Quality Control  品質管制(課)
PD  Product Department  生產部
LAB  Labratry  實驗室
IE  Industrial Engineering  工業工程
R&D  Research & Design  設計開發部
P  Painting  烤漆(廠)
A  Asssembly  組裝(廠)
S  Stamping  沖壓(廠)
生產類
PCS  Pieces  個(根,塊等)
PRS  Pairs  雙(對等)
CTN  Carton  卡通箱
PAL  Pallet/skid  棧板
PO  Purchasing Order  采購訂單
MO  Manufacture Order  生產單
D/C  Date Code  生產日期碼
ID/C  Identification Code  (供應商)識別碼
SWR  Special Work Request  特殊工作需求
L/N  Lot Number  批號
P/N  Part Number  料號
 楼主| 发表于 23-11-2008 16:30:42 | 显示全部楼层
词汇
其它
OEM  Original Equipment Manufacture  原設備製造
PCE  Personal Computer Enclosure  個人電腦外設
PC  Personal Computer  個人電腦
CPU  Central Processing Unit  中央處理器
SECC  SECC`  電解片
SGCC  SGCC  熱浸鍍鋅材料
NHK  North of Hongkong  中國大陸
PRC  People's Republic of China   中國大陸
U.S.A  the United States of America  美國
A.S.A.P  As Soon As Possible  盡可能快的
E-MAIL  Electrical-Mail  電子郵件
N/A  Not Applicable  不適用
QTY  Quantity  數量
VS    以及
REV  Revision  版本
JIT  Just In Time  零庫存
I/O  Input/Output  輸入/輸出
OK  Ok  好
NG  Not Good  不行,不合格
C=0  Critical=0  極嚴重不允許
ESD  Electry-static Discharge  靜電排放
5S  希臘語  整理,整頓,清掃,清潔,教養
ATIN  Attention  知會
CC  Carbon Copy  副本復印相關人員
APP  Approve  核準,認可,承認
CHK  Check  確認
AM  Ante Meridian  上午
PM  Post Meridian  下午
CD  Compact Disk  光碟
CD-ROM  Compact Disk Read-Only Memory  只讀光碟
FDD  Floppy Disk Drive  軟碟機
HDD  Hard Disk Drive  碟碟機
REF  Reference  僅供參考
CONN  Connector  連接器
CAV  Cavity  模穴
CAD  Computer Aid Design  計算機輔助設計
ASS'Y  Assembly  裝配,組裝
MAT'S  Material  材料
IC  Integrated Circuit  集成電路
T/P  True Position  真位度
TYP  Type  類型
WDR  Weekly Delivery Requitement  周出貨需求
C?T  Cycle Time  制程周期
L/T  Lead Time  前置時間(生產前準備時間)
S/T  Standard Time  標準時間
P/M  Product Market  產品市場
3C  Computer,Commumcation,Consumer electronic's  消費性電子
5WIH  When,Where,Who,What,Why,How to
5M  Man,Machine,Material,Method,Measurement
4MIH  Man,Materia,Money,Method,Time  人力,物力,財務,技術,時間(資源)
SQA  Strategy Quality Assurance  策略品質保證
DQA  Desigh Quality Assurance  設計品質保證
MQA  Manufacture Quality Assurance  製造品質保證
SSQA  Sales and service Quality Assurance  銷售及服務品質保證
LRR  Lot Rejeet Rate  批退率
BS  Brain storming  腦力激蕩
EMI  Electronic Magnetion Inspect  高磁測試
FMI  Frequency Modulatim Inspect  高頻測試
B/M  Boar/Molding(flat cable)
C/P  Connector of PC
A/P  Assembly
SPS  Switching power supply  電源箱
DT  Desk Top  臥式(機箱)
MT  Mini-Tower  立式(機箱)
DVD  Digital Vedio Disk
VCD  Vdeio Compact Disk
LCD  Liquid Crystal Display
CAD  Computer AID Design
CAM  Computer AID Manufacturing
CAE  Computer AID Engineering
ABIOS  Achanced Basic in put/output system  先進的基本輸入/輸出系統
CMOS  Complemeruary Metoll Oxide Semiconductor  互補金屬氧化物半導體
PDA  Personal Digital Assistant  個人數字助理
ISA  Industry Standard Architecture  工業標準體制結構
MCA  Micro Channel Architecture   微通道結構
EISA  Extended Industry Standard Architecture  擴充的工業標準結構
SIMM  Single in-line memory module  單項導通匯流組件
DIMM  Dual in-line Memory Module  雙項導通匯流組件
LED  Light-Emitting Diode  發光二級管
FMEA  Failure Mode Effectivenes  失效模式分析
W/H  Wire Harness  金屬線緒束集組件
F/C  Flat Calle  排線
PCB  Printed Circuit Board  印刷電路板
CAR  Correction Action Report  改善報告
NG  Not Good  不良
WPR  Weekly Delivery Requirement  周出貨要求
PPM  Parts Per Million  百萬分之一
TPM  Total Production Maintenance  全面生產保養
MRP  Material Requiremcnt Planning  物料需計劃
OC  Operation System  作業系統
TBA  To Be Design  待定,定缺
D/C  Drawing Change
P/P  Plans & Procedune
EMI  Electrical-Music Industry  電子音樂工業
RFI  Read Frequency Input  讀頻輸入
MMC  Maximum Material Condition
MMS  Maximum Material Size
LMC  Least Material Condition
LMS  Least Material Size
模具技術用語
各種模具常用成形方式
accurate die casting 精密壓鑄 powder forming 粉末成形
calendaring molding 壓延成形 powder metal forging 粉末鍛造
cold chamber die casting 冷式壓鑄 precision forging 精密鍛造
cold forging 冷鍛 press forging 沖鍛
compacting molding 粉末壓出成形 rocking die forging 搖動鍛造
compound molding 複合成形 rotary forging 迴轉鍛造
compression molding 壓縮成形 rotational molding 離心成形
dip mold 浸漬成形 rubber molding 橡膠成形
encapsulation molding 注入成形 sand mold casting 砂模鑄造
extrusion molding 擠出成形 shell casting 殼模鑄造
foam forming 发泡成形 sinter forging 燒結鍛造
forging roll 軋鍛 six sides forging 六面鍛造
gravity casting 重力鑄造 slush molding 凝塑成形
hollow(blow) molding 中空(吹出)成形 squeeze casting 高壓鑄造
hot chamber die casting 熱室壓鑄 swaging 擠鍛
hot forging 熱鍛 transfer molding 轉送成形
injection molding 射出成形 warm forging 溫鍛
investment casting 精密鑄造 matched die method 對模成形法
laminating method 被覆淋膜成形 low pressure casting 低壓鑄造
lost wax casting 脫蠟鑄造 matched mould thermal forming 對模熱成形模
各式模具分類用語
bismuth mold 鉍鑄模 landed plunger mold 有肩柱塞式模具
burnishing die 擠光模 landed positive mold 有肩全壓式模具
button die 鑲入式圓形凹模 loading shoe mold 料套式模具
center-gated mold 中心澆口式模具 loose detail mold 活零件模具
chill mold 冷硬用鑄模 loose mold 活動式模具
clod hobbing 冷擠壓製模 louvering die 百葉窗沖切模
composite dies 複合模具 manifold die 分歧管模具
counter punch 反凸模 modular mold 組合式模具
double stack mold 雙層模具 multi-cavity mold 多模穴模具
electroformed mold 電鑄成形模 multi-gate mold 複式澆口模具
expander die 擴徑模 offswt bending die 雙折冷彎模具
extrusion die 擠出模 palletizing die 疊層模
family mold 反套製品模具 plaster mold 石膏模
blank through dies 漏件式落料模 porous mold 通氣性模具
duplicated cavity plate 複板模 positive mold 全壓式模具
fantail die 扇尾形模具 pressure die 壓緊模
fishtail die 魚尾形模具 profile die 輪廓模
flash mold 溢料式模具 progressive die 順序模
gypsum mold 石膏鑄模 protable mold 手提式模具
hot-runner mold 熱流道模具 prototype mold 雛形試驗模具
ingot mold 鋼錠模 punching die 落料模
lancing die 切口模 raising(embossing) 壓花起伏成形
re-entrant mold 倒角式模具 sectional die 拼合模
runless injection mold 無流道冷料模具 sectional die 對合模具
segment mold 組合模 semi-positive mold 半全壓式模具
shaper 定型模套 single cavity mold 單腔模具
solid forging die 整體鍛模 split forging die 拼合鍛模
split mold 雙併式模具 sprueless mold 無注道殘料模具
squeezing die 擠壓模 stretch form die 拉伸成形模
sweeping mold 平刮鑄模 swing die 振動模具
three plates mold 三片式模具 trimming die 切邊模
unit mold 單元式模具 universal mold 通用模具
unscrewing mold 退扣式模具 yoke type die 軛型模
模具廠常用之標準零配件
air vent vale 通氣閥 anchor pin 錨梢
angular pin 角梢 baffle 調節阻板
angular pin 傾斜梢 baffle plate 折流檔板
ball button 球塞套 ball plunger 定位球塞
ball slider 球塞滑塊 binder plate 壓板
blank holder 防皺壓板 blanking die 落料沖頭
bolster 上下模板 bottom board 澆注底板
bolster 墊板 bottom plate 下固定板
bracket 扥架 bumper block 緩衝塊
buster 堵口 casting ladle 澆注包
casting lug 鑄耳 cavity 模穴(模仁)
cavity retainer plate 模穴扥板 center pin 中心梢
clamping block 鎖定塊 coil spring 螺旋彈簧
cold punched nut 冷沖螺母 cooling spiral 螺旋冷卻栓
core 心型 core pin 心型梢
cotter 開口梢 cross 十字接頭
cushion pin 緩衝梢 diaphragm gate 盤形澆口
die approach 模頭料道 die bed 型底
die block 塊形模體 die body 鑄模座
die bush 合模襯套 die button 沖模母模
die clamper 夾模器 die fastener 模具固定用零件
die holder 母模固定板 die lip 模唇
die plate 沖模板 die set 沖壓模座
direct gate 直接澆口 dog chuck 爪牙夾頭
dowel 定位梢 dowel hole 導套孔
dowel pin 合模梢 dozzle 輔助澆口
dowel pin 定位梢 draft 拔模錐度
draw bead 張力調整桿 drive bearing 傳動軸承
ejection pad 頂出襯墊 ejector 脫模器
ejector guide pin 頂出導梢 ejector leader busher 頂出導梢襯套
ejector pad 頂出墊 ejector pin 頂出梢
ejector plate 頂出板 ejector rod 頂出桿
ejector sleeve 頂出襯套 ejector valve 頂出閥
eye bolt 環首螺栓 filling core 椿入蕊
film gate 薄膜形澆口 finger pin 指形梢
finish machined plate 角形模板 finish machined round plate 圓形模板
fixed bolster plate 固定側模板 flanged pin 帶凸緣销
flash gate 毛邊形澆口 flask 上箱
floating punch 浮動沖頭 gate 澆口
gate land 澆口面 gib 凹形拉緊销
goose neck 鵝頸管 guide bushing 引導襯套
guide pin 導梢 guide post 引導柱
guide plate 導板 guide rail 導軌
head punch 頂镦沖頭 headless punch 直柄沖頭
heavily tapered solid 整體模蕊盒 hose nippler 管接頭
impact damper 緩衝器 injection ram 壓射柱塞
inlay busher 嵌入襯套 inner plunger 內柱塞
inner punch 內沖頭 insert 嵌件
insert pin 嵌件梢 king pin 轉向梢
king pin bush 主梢襯套 knockout bar 脫模杵
land 合模平坦面 land area 合模面
leader busher 導梢襯套 lifting pin 起模頂销
lining 內襯 locating center punch 定位中心沖頭
locating pilot pin 定位導梢 locating ring 定位環
lock block 壓塊 locking block 定位塊
locking plate 定位板 loose bush 活動襯套
making die 打印沖子 manifold block 歧管檔塊
master plate 靠模樣板 match plate 分型板
mold base 塑膠模座 mold clamp 鑄模緊固夾
mold platen 模用板 moving bolster 換模保持裝置
moving bolster plate 可動側模板 one piece casting 整體鑄件
parallel block 平行墊塊 paring line 分模線
parting lock set 合模定位器 pass guide 穴型導板
peened head punch 鑲入式沖頭 pilot pin 導销
pin gate 針尖澆口 plate 襯板
pre extrusion punch 頂擠沖頭 punch 沖頭
puncher 推桿 pusher pin 襯套梢
rack 機架 rapping rod 起模桿
re-entrant mold 凹入模 retainer pin 嵌件梢
retainer plate 扥料板 return pin 回位梢
riding stripper 浮動脫模器 ring gate 環型澆口
roller 滾筒 runner 流道
runner ejector set 流道頂出器 runner lock pin 流道拉梢
screw plug 頭塞 set screw 固定螺絲
shedder 脫模裝置 shim 分隔片
shoe 模座之上下模板 shoot 流道
shoulder bolt 肩部螺絲 skeleton 骨架
slag riser 冒渣口 slide(slide core) 滑塊
slip joint 滑配接頭 spacer block 間隔塊
spacer ring 間隔環 spider 模蕊支架
spindle 主軸 sprue 注道
sprue bushing 注道襯套 sprue bushing guide 注道導套
sprue lock bushing 注道定位襯套 sprue puller 注道拉料销
spue line 合模線 square key 方鍵
square nut 方螺帽 square thread 方螺紋
stop collar 限位套 stop pin 止動梢
stop ring 止動環 stopper 定位停止梢
straight pin 圓柱销 stripper bolt 脫料螺栓
stripper bushing 脫模襯套 stripper plate 剝料板
stroke end block 行程止梢 submarine gate 潛入式澆口
support pillar 支撐支柱/頂出支柱 support pin 支撐梢
supporting plate 扥板 sweep templete 造模刮板
tab gate 輔助澆口 taper key 推拔鍵
taper pin 拔錐梢/錐形梢 teeming 澆注
three start screw 三條螺紋 thrust pin 推力銷
tie bar 拉杵 tunnel gate 隧道形澆口
vent 通氣孔 wortle plate 拉絲模板
模具常用之工作機械
3D coordinate measurement 三次元量床 boring machine 搪孔機
cnc milling machine CNC銑床 contouring machine 輪廓鋸床
copy grinding machine 仿形磨床 copy lathe 仿形車床
copy milling machine 仿形銑床 copy shaping machine 仿形鉋床
cylindrical grinding machine 外圓磨床 die spotting machine 合模機
drilling machine 钻孔機 engraving machine 雕刻機
engraving E.D.M. 雕模放置加工機 form grinding machine 成形磨床
graphite machine 石墨加工機 horizontal boring machine 臥式搪孔機
horizontal machine center 臥式加工製造中心 internal cylindrical machine 內圓磨床
jig boring machine 冶具搪孔機 jig grinding machine 冶具磨床
lap machine 研磨機 machine center 加工製造中心
multi model miller 靠磨銑床 NC drilling machine NC鑽床
NC grinding machine NC磨床 NC lathe NC車床
NC programming system NC程式製作系統 planer 龍門鉋床
profile grinding machine 投影磨床 projection grinder 投影磨床
radial drilling machine 旋臂钻床 shaper 牛頭鉋床
surface grinder 平面磨床 try machine 試模機
turret lathe 轉塔車床 universal tool grinding machine 萬能工具磨床
vertical machine center 立式加工製造中心 wire E.D.M. 線割放電加工機
檢驗量測工具用語
autocollimator 自動準直機 bench comparator 比長儀
block gauge 塊規 bore check 精密小測定器
calibration 校準 caliper gauge 卡規
check gauge 校對規 clearance gauge 間隙規
clinoretee 測斜儀 comparator 比測儀
cylinder square 圓筒直尺 depth gauge 測深規
dial indicator 針盤指示表 dial snap gauge 卡規
digital micrometer 數位式測微計 feeler gauge 測隙規
gauge plate 量規定位板 height gauge 測高規
inside calipers 內卡鉗 inside micrometer 內分釐卡
interferometer 干涉儀 leveling block 平台
limit gauge 限規 micrometer 測微計
mil 千分之一吋 monometer 壓力計
morse taper gauge 莫氏錐度量規 nonius 游標卡尺
optical flat 光學平晶 optical parallel 光學平行
passimeter 內徑儀 position scale 位置刻度
profile projector 輪廓光學投影儀 protractor 分角器
radius 半徑 ring gauge 環規
sine bar 正弦量規 snap gauge 卡模
square master 直角尺 stylus 觸針
telescopic gauge 伸縮性量規 working gauge 工作量規
模具鋼材
alloy tool steel 合金工具鋼 aluminium alloy 鋁合金鋼
bearing alloy 軸承合金 blister steel 浸碳鋼
bonderized steel sheet 邦德防蝕鋼板 carbon tool steel 碳素工具鋼
clad sheet 被覆板 clod work die steel 冷鍛模用鋼
emery 金鋼砂 ferrostatic pressure 鋼鐵水靜壓力
forging die steel 鍛造模用鋼 galvanized steel sheet 鍍鋅鐵板
hard alloy steel 超硬合金鋼 high speed tool steel 高速度工具鋼
hot work die steel 熱鍛模用鋼 low alloy tool steel 特殊工具鋼
low manganese casting steel 低錳鑄鋼 marging steel 馬式體高強度熱處理鋼
martrix alloy 馬特里斯合金 meehanite cast iron 米漢納鑄鋼
meehanite metal 米漢納鐵 merchant iron 市售鋼材
molybdenum high speed steel 鉬係高速鋼 molybdenum steel 鉬鋼
nickel chromium steel 鎳鉻鋼 prehardened steel 頂硬鋼
silicon steel sheet 矽鋼板 stainless steel 不銹鋼
tin plated steel sheet 鍍錫鐵板 tough pitch copper 韌銅
troostite 吐粒散鐵 tungsten steel 钨鋼
vinyl tapped steel sheet 塑膠覆面鋼板
表面處理關連用語
age hardening 時效硬化 ageing 老化處理
air hardening 氣體硬化 air patenting 空氣韌化
annealing 退火 anode effect 陽極效應
anodizing 陽極氧化處理 atomloy treatment 阿扥木洛伊表面
austempering 奧氏體等溫淬火 austenite 奧斯田體/奧氏體
bainite 貝氏體 banded structure 條紋狀組織
barrel plating 滾鍍 barrel tumbling 滾筒打光
blackening 染黑法 blue shortness 青熟脆性
bonderizing 磷酸鹽皮膜處理 box annealing 箱型退火
box carburizing 封箱滲碳 bright electroplating 輝面電鍍
bright heat treatment 光輝熱處理 bypass heat treatment 旁路熱處理
carbide 炭化物 carburized case depth 浸碳硬化深層
carburizing 滲碳 cementite 炭化鐵
chemical plating 化學電鍍 chemical vapor deposition 化學蒸鍍
coarsening 結晶粒粗大化 coating 塗布被覆
cold shortness 低溫脆性 comemtite 滲碳體
controlled atmosphere 大氣熱處理 corner effect 銳角效應
creeping discharge 蠕緩放電 decarburization 脫碳處理
decarburizing 脫碳退火 depth of hardening 硬化深層
diffusion 擴散 diffusion annealing 擴散退火
electrolytic hardening 電解淬火 embossing 壓花
etching 表面蝕刻 ferrite 肥粒鐵
first stage annealing 第一段退火 flame hardening 火焰硬化
flame treatment 火焰處理 full annealing 完全退火
gaseous cyaniding 氣體氧化法 globular cementite 球狀炭化鐵
grain size 結晶粒度 granolite treatment 磷酸溶液熱處理
graphitizing 石墨退火 hardenability 硬化性
hardenability curve 硬化性曲線 hardening 硬化
heat treatment 熱處理 hot bath quenching 熱浴淬火
hot dipping 熱浸鍍 induction hardening 高周波硬化
ion carbonitriding 離子滲碳氮化 ion carburizing 離子滲碳處理
ion plating 離子電鍍 isothermal annealing 等溫退火
liquid honing 液體噴砂法 low temperature annealing 低溫退火
malleablizing 可鍛化退火 martempering 麻回火處理
martensite 馬氏體/硬化鐵炭 metallikon 金屬噴鍍法
metallizing 真空塗膜 nitriding 氮化處理
nitrocarburizing 軟氮化 normalizing 正常化
oil quenching 油淬化 overageing 過老化
overheating 過熱 pearlite 針尖組織
phosphating 磷酸鹽皮膜處理 physical vapor deposition 物理蒸鍍
plasma nitriding 離子氮化 pre-annealing 預備退火
precipitation 析出 precipitation hardening 析出硬化
press quenching 加壓硬化 process annealing 製程退火
quench ageing 淬火老化 quench hardening 淬火
quenching crack 淬火裂痕 quenching distortion 淬火變形
quenching stress 淬火應力 reconditioning 再調質
recrystallization 再結晶 red shortness 紅熱脆性
residual stress 殘留應力 retained austenite 殘留奧
rust prevention 防蝕 salt bath quenching 鹽浴淬火
sand blast 噴砂處理 seasoning 時效處理
second stage annealing 第二段退火 secular distortion 經年變形
segregation 偏析 selective hardening 部分淬火
shot blast 噴丸處理 shot peening 珠擊法
single stage nitriding 等溫滲氮 sintering 燒結處理
soaking 均熱處理 softening 軟化退火
solution treatment 固溶化熱處理 spheroidizing 球狀化退火
stabilizing treatment 安定化處理 straightening annealing 矯直退火
strain ageing 應變老化 stress relieving annealing 應力消除退火
subzero treatment 生冷處理 supercooling 過冷
surface hardening 表面硬化處理 temper brittleness 回火脆性
temper colour 回火顏色 tempering 回火
tempering crack 回火裂痕 texture 咬花
thermal refining 調質處理 thermoechanical treatment 加工熱處理
time quenching 時間淬火 transformation 變態
tufftride process 軟氮化處理 under annealing 不完全退火
vacuum carbonitriding 真空滲碳氮化 vacuum carburizing 真空滲碳處理
vacuum hardening 真空淬火 vacuum heat treatment 真空熱處理
vacuum nitriding 真空氮化 water quenching 水淬火
wetout 浸潤處理
焊接用語
acetylene 乙炔 ampere 電流安培
angle welding 角焊 arc 電弧
argon arc welding 氬弧焊接 bare electrode 光熔接條
butt welding 對接焊接 camber 電弧彎曲
cascade 階疊熔接法 clad weld 被覆熔接
crator 焊疤 excess metal 多餘金屬
filler rod 焊條 fillet weld 填角焊接
gas shield 氣體遮蔽 groove welding 起槽熔接
hand face shield 手握面罩 hard facing 硬表面堆焊
jig welding 工模焊接 laser beam welding 雷射光焊接
metal electrode insert gas welding MIG熔接 nugget 點焊熔核
overlaying 堆焊 peening of welding 珠擊熔接法
plug welding 塞孔熔接 positioned welding 正向熔接
pressure welding 壓焊 propane gas cutting 丙烷氣切割
pure nickel electrode 純鎳熔接條 reinforcement of weld 加強焊接
resist 抗蝕護膜 root running 背面熔接
seam 焊縫 seaming 接合
seam welding 流縫熔接 series seam welding 串聯縫熔接
skip welding process 跳焊法 spark 火花
spot welding 點焊接 stitch welding 針角焊接
stud arc welding 電弧焊接 under laying 下部焊層
void 焊接空隙 weld flow mark 焊接流痕
weld flush 焊縫凸起 weld line 焊接紋
weld mark 焊接痕 weld penetration 熔接透入
weld zone 焊接區 welding 焊接
welding bead 焊接泡 welding direction 焊接方向
welding distortion 焊接變形 welding flux 焊劑
welding ground 電熔接地 welding interval 焊接週期
welding stress 熔接應變 welding torch 熔接氣炬
射出成形關聯用語
activator 活化劑 bag moulding 氣胎施壓成形
bonding strength 黏合強度 breathing 排氣
caulking compound 填隙料 cell 氣孔
cold slug 半凝式射出 colorant 著色劑
color matching 調色 color masterbatch 色母料
compound 混合料 copolymer 共聚合體
cull 殘料廢品 cure 凝固化
cryptometer 不透明度儀 daylight 開隙
dry cycle time 空料試車週期時間 ductility 延性
elastomer 彈性體 extruded bead sealing 壓出粒塗層法
feed 供料 filler 充填劑
film blowing 薄膜吹製法 floating platen 活動模板
foaming agent 發泡劑 gloss 光澤
granule 顆粒料 gunk 料斗
hot mark 熱斑 hot stamping 燙印
injection nozzle 射出噴嘴 injection plunger 射出柱塞
injection ram 射出衝柱 isomer 同分異構物
kneader 混合機 leveling agent 勻塗劑
lubricant 潤滑劑 matched die method 配合成形法
mould clamping force 鎖模力 mould release agent 脫模劑
nozzle 噴嘴 oriented film 取向薄膜
parison 吹氣成形壞料 pellet 粒料
plasticizer 可塑劑 plunger 壓料柱塞
porosity 孔隙率 post cure 後固化
premix 預混料 purging 清除
reciprocating screw 往復螺桿 resilience 回彈性
resin injection 樹脂射出法 rheology 流變學
sheet 塑膠片 shot 注射
shot cycle 射出循環 slip agent 光滑劑
take out device 取料裝置 tie bar 拉桿
toggle type mould clamping system 肘桿式鎖模裝置
torpedo spreader 魚雷形分流板 transparency 透明性
void content 空洞率
塑膠原料
acrylic 壓克力 casein 酪素
cellulose acetate 醋酸纖維素CA cellulose acetate butyrate 醋酸丁酸纖維素CAB
composite material 複合材料 cresol resin 甲酚樹脂CF
dially phthalate 苯二甲酸二烯丙酯 disperse reinforcement 分散性強化複合材料
engineering plastics 工程塑膠 epoxy resin 環氧樹脂EP
ethyl cellulose 乙基纖維素 ethylene vinylacetate copolymer 乙烯-醋酸乙烯EVA
ethylene-vinlacetate copolyme 醋酸乙烯共聚物EVA expanded polystyrene 发泡聚苯乙烯EPS
fiber reinforcement 纖維強化熱固性/纖維強化複合材料
high density polyethylene 高密度聚乙烯HDPE
high impact polystyrene 高衝擊聚苯乙烯HIPS
high impact polystyrene rigidity 高衝擊性聚苯乙烯
low density polyethylene 低密度聚乙烯LDPE melamine resin 三聚氰胺酚醛樹脂MF
nitrocellulose 硝酸纖維素 phenolic resin 酚醛樹脂
plastic 塑膠 polyacrylic acid 聚丙烯酸PAP
polyamide 耐龍PA polybutyleneterephthalate 聚對苯二甲酸丁酯PBT
polycarbonate 聚碳酸酯PC polyethyleneglycol 聚乙二醇PFG
polyethyleneoxide 聚氧化乙烯PEO polyethyleneterephthalate 聚乙醇對苯PETP
polymetylmethacrylate 聚甲基丙烯酸甲酯PMMA polyoxymethylene 聚縮醛POM
polyphenylene oxide 聚硫化亞苯 polyphenyleneoxide 聚苯醚PPO
polypropylene 聚丙烯PP polystyrene 聚苯乙烯PS
polytetrafluoroethylene 聚四氟乙烯PTFE polytetrafluoroethylene 聚四氟乙烯
polythene 聚乙烯PE polyurethane 聚氨基甲酸酯PU
polyvinylacetate 聚醋酸乙烯PVAC polyvinylalcohol 聚乙烯醇PVA
polyvinylbutyral 聚乙烯醇縮丁醛PVB polyvinylchloride 聚氯乙烯PVC
polyvinylfuoride 聚氟乙烯PVF polyvinylidenechloride 聚偏二氯乙烯PVDC
prepolymer 預聚物 silicone resin 矽樹脂
thermoplastic 熱塑性 thermosetting 熱固性
thermosetting plastic 塑膠 unsaturated polyester 不飽和聚酯樹脂
成形不良用語
aberration 色差 atomization 霚化
bank mark 滞料紋 bite 咬入
blacking hole 塗料孔(鑄疵) blacking scab 塗料疤
blister 起泡 blooming 起霜
blow hole 破孔 blushing 泛白
body wrinkle 側壁皺紋 breaking-in 冒口帶肉
bubble 膜泡 burn mark 糊斑
burr 毛邊 camber 翹曲
cell 氣泡 center buckle 表面中部波皺
check 細裂痕 checking 龜裂
chipping 修整表面缺陷 clamp-off 鑄件凹痕
collapse 塌陷 color mottle 色斑
corrosion 腐蝕 crack 裂痕
crazing 碎裂 crazing 龜裂
deformation 變形 edge 切邊碎片
edge crack 裂邊 fading 退色
filler speak 填充料斑 fissure 裂紋
flange wrinkle 凸緣起皺 flaw 刮傷
flow mark 流痕 galling 毛邊
glazing 光滑 gloss 光澤
grease pits 污斑 grinding defect 磨痕
haircrack 發裂 haze 霧度
incrustation 水銹 indentation 壓痕
internal porosity 內部氣孔 mismatch 偏模
mottle 斑點 necking 縮頸
nick 割痕 orange peel 橘皮狀表面缺陷
overflow 溢流 peeling 剝離
pit 坑 pitting corrosion 點狀腐蝕
plate mark 模板印痕 pock 麻點
pock mark 痘斑 resin streak 樹脂流紋
resin wear 樹脂脫落 riding 凹陷
sagging 松垂 saponification 皂化
scar 疤痕 scrap 廢料
scrap jam 廢料阻塞 scratch 刮傷/劃痕
scuffing 深沖表面劃傷 seam 裂痕
shock line 模口擠痕 short shot 充填不足
shrinkage pool 凹孔 sink mark 凹痕
skin inclusion 表皮摺疊 straightening 矯直
streak 條狀痕 surface check 表面裂痕
surface roughening 橘皮狀表皮皺摺 surging 波動
sweat out 冒汗 torsion 扭曲
warpage 翹曲 waviness 波痕
webbing 熔塌 weld mark 焊痕
whitening 白化 wrinkle 皺紋
模具常用刀具與工作法用語
adjustable spanner 活動扳手 angle cutter 角銑刀
anvil 鐵钻 arbour 心軸
backing 襯墊 belt sander 帶式打磨機
buffing 拋光 chamfering machine 倒角機
chamfering tool 去角刀具 chisel 扁鏨
chuck 夾具 compass 兩角規
concave cutter 凹面銑刀 convex cutter 凸形銑刀
cross joint 十字接頭 cutting edge clearance 刃口餘隙角
drill stand 鑽台 edge file 刃用銼刀
file 銼刀 flange joint 凸緣接頭
grinder 砂輪機 hammer 鐵鎚
hand brace 手搖鑽 hatching 剖面線
hexagon headed bolt 六角頭螺栓 hexagon nut 六角螺帽
index head 分度頭 jack 千斤頂
jig 治具 kit 工具箱
lapping 研磨 metal saw 金工鋸
nose angle 刀角 pinchers 鉗子
pliers 鋏鉗 plug 柱塞頭
polisher 磨光器 protable driller 手提鑽孔機
punch 沖頭 sand paper 砂紙
scraper 刮刀 screw driver 螺絲起子
scribing 劃線 second out file 中紋銼
spanner 扳手 spline broach 方栓槽拉刀
square 直角尺 square sleeker 方形鏝刀
square trowel 直角度 stripping 剝離工具
T-slot T形槽 tool for lathe 車刀
tool point angle 刀刃角 tool post 刀架
tosecan 劃線盤 trimming 去毛邊
waffle die flattening 壓紋效平 wiper 脫模鉗
wrench 螺旋扳手
電腦關聯用語
3D modeling 三次元模擬 access 通路
animation 卡通影片 application 應用
board 基板 bug 故障
bus 匯流排 CAD 電腦輔助設計
CAE 電腦輔助工程分析 CAM 電腦輔助製造
cassette 卡座 color display 彩色顯示器
command 指令 communication 通信
compact 精簡小型 computer 電腦
copy 複製 cursor 游標
curve modeling 曲面模擬 database 資料庫
design 設計 digitizing 數位化
disk 磁碟 dot 點
eyelet 眼孔 floppy 磁碟片
format 格式化 graphic 圓解
hardware 硬體 honeycomb 蜂巢
interface 界面 know how 秘訣
laser printer 雷射印表機 lay out 佈置
memory 記憶 memory swap 交換記憶
microprocessor 微處理器 modeling 造型
module 模組 monitor 螢幕
mouse 滑鼠 need 需求
network 網路 new version 新版
on line 上線中 option 選擇
PC 個人電腦 plotter 繪圖機
program 程式 scanning 掃描
simulation 模擬 software 軟體
solid model 實體模型 system 系統
tape 磁帶 terminal 終端機
texture 構造 trim 修邊
venter 排氣風扇 word processor 文書處理器
各種沖模加工關連用語
barreling 滾光加工 belling 壓凸加工
bending 彎曲加工 blanking 下料加工
bulging 撐壓加工 burring 衝緣加工
cam die bending 凸輪彎曲加工 caulking 铆合加工
coining 壓印加工 compressing 壓縮加工
compression bending 押彎曲加工 crowning 凸面加工
curl bending 捲邊彎曲加工 curling 捲曲加工
cutting 切削加工 dinking 切斷蕊骨
double shearing 疊板裁斷 drawing 引伸加工
drawing with ironing 抽引光滑加工 embossing 浮花壓製加工
extrusion 擠製加工 filing 銼削加工
fine blanking 精密下料加工 finish blanking 光製下料加工
finishing 精整加工 flanging 凸緣加工
folding 折邊彎曲加工 folding 摺疊加工
forming 成形加工 impact extrusion 衝擊擠壓加工
indenting 壓痕加工 ironing 引縮加工
knurling 滾花 lock seaming 固定接合
louvering 百葉窗板加工 marking 刻印加工
necking 頸縮加工 notching 沖口加工
parting 分斷加工 piercing 沖孔加工
progressive bending 連續彎曲加工 progressive blanking 連續下料加工
progressive drawing 連續引伸加工 progressive forming 連續成形加工
reaming 鉸孔加工 restriking 二次精沖加工
riveting 铆接加工 roll bending 滾筒彎曲加工
roll finishing 滾壓加工 rolling 壓延加工
roughing 粗加工 scrapless machining 無廢料加工
seaming 折彎重疊加工 shaving 缺口修整加工
shearing 切斷加工 sizing 精壓加工/矯正加工
slitting 割縫加工 spinning 捲邊铆接
staking 铆固 stamping 鍛壓加工
swaging 擠鍛壓加工 trimming 整緣加工
upsetting 鍛粗加工 wiring 抽線加工
沖壓機械及周邊關連用語
back shaft 支撐軸 blank determination 胚料展開
bottom slide press 下傳動式壓力機 board drop hammer 板落鎚
brake 煞車 buckle 剝砂面
camlachie cramp 鑄包 casting on flat 铆合
chamotte sand 燒磨砂 charging hopper 加料漏斗
clearance 間隙 closed-die forging 合模鍛造
clump 夾緊 clutch 離合器
clutch brake 離合器制動器 clutch boss 離合器輪殼
clutch lining 離合器覆蓋 coil car 帶卷升降運輸機
coil cradle 卷材進料裝置 coil reel stand 鋼材卷料架
column 圓柱 connection screw 連桿調節螺釘
core compound 砂心黏結劑 counter blow hammer 對擊鍛鎚
cradle 送料架 crank 曲柄軸
crankless 無曲柄式 cross crank 橫向曲軸
cushion 緩衝 depression 外縮凹孔
dial feed 分度送料 die approach 模口角度
die assembly 合模 die cushion 模具緩衝墊
die height 沖壓閉合高度 die life 模具壽命
die opening 母模逃孔 die spotting press 調整沖模用壓力機
double crank press 雙曲柄軸沖床 draght angle 逃料傾斜角
edging 邊鍛伸 embedded core 加裝砂心
feed length 送料長度 feed level 送料高度
filling core 埋入砂心 filling in 填砂
film play 液面花紋 fine blanking press 精密下料沖床
forging roll 輥鍛機 finishing slag 煉後熔渣
fly wheel 飛輪 fly wheel brake 飛輪制動器
foot press 腳踏沖床 formboard 進模口板
frame 床身機架 friction 摩擦
friction brake 摩擦煞車 gap shear 凹口剪床
gear 齒輪 gib 滑塊引導部
gripper 夾具 gripper feed 夾持進料
gripper feeder 夾緊傳送裝置 hammer 槌機
hand press 手動沖床 hand rack pinion press 手動齒輪齒條式沖床
hand screw press 手動螺旋式沖床 hopper feed 料斗送料
idle stage 空站 inching 微調尺寸
isothermal forging 恆溫鍛造 key clutch 鍵槽離合器
knockout 脫模裝置 knuckle mechanic 轉向機構
land 模具直線刀面部 level 水平
loader 供料器 unloader 卸料機
loop controller 閉回路控制器 lower die 下模
micro inching device 微寸動裝置 microinching equipment 微動裝置
motor 馬達 moving bolster 活動工作台
notching press 沖缺口壓力機 opening 排料逃孔
overload protection device 防超載裝置 pinch roll 導正滾輪
pinion 小齒輪 pitch 節距
pressfit 壓入 progressive 連續送料
pusher feed 推桿式送料 pusher feeder 料片押片裝置
quick die change system 快速換模系統 regrinding 再次研磨
releasing 鬆釋動作 reversed blanking 反轉下料
robot 機器人 roll forming machine 輥軋成形
roll forming machine 輥軋成形機 roll release 脫輥
roller feed 輥式送料 roller leveler 輥式矯直機
rotary bender 卷彎成形機 safety guard 安全保護裝置
scrap cutter 廢料切刀 scrap press 廢料沖床
seamless forging 無縫鍛造 separate 分離
shave 崩砂 shear angle 剪角
sheet loader 薄板裝料機 shot 單行程工作
shrinkage fit 收縮配合 shut height 閉合高度
sieve mesh 篩孔 sintering of sand 鑄砂燒貼
slide balancer 滑動平衡器 slug hole 逃料孔
spin forming machine 旋壓成形機 spotting 合模
stack feeder 堆疊撥送料機 stickness 黏模性
straight side frame 沖床側板 stretcher leveler 拉伸矯直機
strip feeder 料材送料裝置 stripping pressure 彈出壓力
stroke 衝程 take out device 取料裝置
toggle press 肘桿式壓力機 transfer 傳送
transfer feed 連續自動送料裝置 turrent punch press 轉塔沖床
two speed clutch 雙速離合器 uncoiler 閉卷送料機
unloader 卸載機 vibration feeder 振動送料機
wiring press 嵌線卷邊機
線切割放電加工關連用語
abnormal glow 不規則輝光放電 arc discharge 電弧放電
belt 皮帶 centreless 無心
chrome bronze 銘銅 clearance angle 後角
corner shear drop 直角壓陷 deflection 橈曲度
discharge energy 放電能量 dressing 修整
dwell 保壓 flange 凸緣
gap 間隙 graphite 石墨
graphite contraction allowance 電極縮小餘量 graphite holder 電極夾座
hair crack 發裂 horn 電極臂
jump 跳刀 magnetic base 磁性座
master graphite 標準電極 pipe graphite 管狀電極
pulse 脈衝 rib working 肋部加工
roller electrode 滾輪式電極 rotary surface 旋轉面
shank 柄部 sharp edge 銳角部
tough bronze 韌銅 traverse 搖臂
tungsten bronze 钨青銅 waviness 波形起伏
work 工件 working allowance 加工餘量
working dischard 加工廢料
鍛鑄造關連用語
accretion 爐瘤 acid converter 酸性轉爐
acid lining cupola 酸性熔鐵爐 acid open-hearth furnace 酸性平爐
aerator 鬆砂機 air set mold 常溫自硬鑄模
airless blasting cleaning 離心噴光 all core molding 集合式鑄模
all round die holder 通用模座 assembly mark 鑄造合模記號
back pouring 補澆注 backing sand 背砂
base bullion 粗金屬錠 base permeability 原砂透氣度
belling 壓凸 billet 壞料
bleed 漏鑄 blocker 預鍛模膛
blocking 粗胚鍛件 blow hole 鑄件氣孔
board drop hammer 板落鎚 bottom pour mold 底澆
bottom pouring 底注 boxless mold 脫箱砂模
break-off core 縮頸砂心 brick molding 砌箱造模法
buckle 剝砂面 camber 錯箱
camlachie cramp 鑄包   cast blade 鑄造葉片
casting flange 鑄造凸緣 casting on flat 水平鑄造
cleaning of casting 鑄件清理 closed-die forging 合模鍛造
core compound 砂心黏結劑 core template 砂心模板
core vent 砂蕊排氣孔 corner gate 壓邊澆口
counter blow hammer 對擊鍛造 counter lock 止口鑲嵌方式
depression 外縮凹孔 die approach 模口角度
draw out 鍛造拔長 draw plate 起模板
draw spike 起模長針 dummying 預鍛
embedded core 加裝砂心 erosion 沖砂
fettling 鑄件清理 filling core 埋入砂心
filling in 填砂 film play 液面花紋
finishing slag 煉後熔渣 flash gutter 鍛模飛邊槽
flask molding 砂箱造模 forging roll 輥鍛機
formboard 進模口板 gutter 鍛模飛邊槽
hammer man 鍛工 heading machine 頂鐓機
impacter 臥式鍛造機 inblock cast 整體鑄造
ingot 鑄錠 ingot blank 鑄坯
inlay casting 鑲鑄法 investment casting 失模鑄造
isothermal forging 恆溫鍛造 loose piece 木模活塊
molding pit 鑄模地坑 pouring process 澆注法
recasting 重鑄 roll forging 軋鍛
rolled surface 軋製表面 rough sand 粗砂
roughing forge 粗鍛 sand crushing 塌箱
shave 崩砂 shrinkage fit 收縮配合
shut height 閉合高度 sieve mesh 篩孔
sintering of sand 鑄砂燒貼 slag 熔渣
slag inclusion 夾渣 stickness 黏模性
strip layout 帶狀胚料排樣法 tap casting 頂注
top gate 頂注澆口 unworked casting 不加工鑄件
upender 翻轉裝置 upending 頂鍛
uphill casting 底鑄 white cast iron 白口鑄件
模具加工方法
barrel 滾筒(加工) bending 波紋加工
broaching 拉刀切削 centering 定中心
cutting 切削 cylindrical lathe cutting 外圓車削
electric discharge machine 放電加工 electrolytic grinding 電解研磨
embossing 壓花加工 facing 面車削
filing 銼刀修潤 hand finishing 手工修潤
hemming 卷邊加工 hobbing 滾齒加工
joggling 搖動加工 lapping 拋光/研磨修潤
laser beam machining 雷射加工 lathe cutting 車床車削
planning 刨削加工 polishing 拋亮光
reaming 鉸孔修潤 rough machining 粗切削
rounding 圓形加工 sawing 鋸削
scaling 清除鋼碇缺陷 shaping 成形加工
skiving 表面研磨 slotting 切縫切削
taper turning 錐度車削 thread cutting 螺紋切削
ultrasonic machining 超音波加工 up cut milling 逆銑加工
學理實驗與試驗用語
air permeability test 透氣性試驗 austenitic steel 沃斯田鐵鋼
brinell hardness 布耐內爾硬度 brinell hardness test 布氏硬度試驗
charpy impact test 夏比衝擊試驗 conical cup test 圓錐杯突試驗
cup flow test 杯模式流動度試驗 dart drop impact test 落錘衝擊試驗
Elmendorf test 埃羅門多撕裂強度試驗 environmental stress cracking test 環境應力龜裂試驗
ericessen test 埃留伸薄板拉伸試驗 falling ball impact test 落球衝擊試驗
fatigue test 疲勞試驗 ferrite 純鐵體
gantt chart 甘特圖 heat cycle test 熱循環試驗
histogram 柱狀圖 hot bend test 熱彎試驗
izod impact test 埃左德衝擊試驗 loop tenacity 環結強度
martens heat distortion temperature test 馬頓斯耐熱試驗
martensite 馬氏體 mullen bursting strength tester 密廉式破裂強度試驗機
nol ring test 諾爾環試驗 normal distribution 常態分配
ozone resistance test 抗臭氧試驗 pareto diagram 柏拉圖
peeling test 剝離試驗 pinhole test 針孔試驗機
rattler test 磨耗試驗 rockweel hardness test 洛氏硬度試驗
rockweel hardness 洛氏威爾硬度 rolinx process 羅林克斯射出壓縮成形法
rossi-peakes flow test 羅西皮克斯流動試驗 sampling inspection 抽樣檢查
scratch hardness 抗刮硬度 shore hardness 蕭氏硬度
spiral flow test 螺旋流動試驗 surface abrasion test 表面磨耗試驗
taber abraser 泰伯磨耗試驗機 tensile impact test 拉伸衝擊試驗
tensile strength 抗拉強度 tension test 張力試驗
thermal shock test 冷熱劇變試驗 torsion test 扭曲試驗
ubbelohde viscometer 烏別洛德黏度計 vicat indentation test 維卡針壓陷試驗
Vickers hardness test 維氏硬度試驗 warpage test 翹曲試驗
weatherometer 人工老化試驗機 weissenberg effect 威森伯格迴轉效應
砂輪用語
abrasive 砂輪 Al2O3 氧化鋁
balance 平衡 bond 結合
borazon 氧化硼立方晶 buffing wheel 拋光布輪
diamond 鑽石 dresser 砂輪整修機
dressing 修整 endless grinding belt 循環式研磨帶
finishing allowance 加工餘量 grain 磨粒
grinding disc 研磨盤 jamp up 孔眼堵塞
mesh 網篩目 parameter 參數
resinoid grinding wheel 半樹脂型砂輪 slitting 切縫量
vitrified 陶瓷的 wheel 旋轉
機械設計及周邊其他用語
assembly drawing 裝配圖 auto tool change cycle 自動換刀時間週期
beam 橫梁 bending moment 彎矩
bending stress 彎曲應力 bottoming 底靠
buckling 縱彎曲 chamfering 去角斜切
channel 凹槽 chattering 顫動
check point 查核點 chip 切屑
chip conveyor 排屑輸送機 coefficient of friction 摩擦係數
compact 小型的 cooling pipe 冷卻管
coupon 試樣胚 deflection 撓曲量
distortion 扭曲變形 draft taper 拔模錐度
draw out 拉拔 fit tolerance 配合公差
flexible rigidity 彎曲剛性 gas vent 氣孔
hatching 剖面線 heater cooler 加熱器冷卻裝置
hook cavity 鉤穴 inching 寸動
lug 凸緣 maintenance 維修保固
metallurgy 冶金學 notch effect 切口效果
out of roughness 真圓度 performance 動作性能
pit 坑 plane strain 倒角應力
plug mill 蕊棒軋管機 repeated load 重覆載荷
riveted joint 铆釘接合 sand paper 砂紙
shift 偏移 shrink fit 熱壓配合
shrinkage hole 縮孔 sinking 凹陷
sketch 草圖 spalling 剝落
straightness 直度 submarine 深陷式
surface roughness 表面粗度 tapping 攻螺絲
thermocouple 熱電耦 torsion load 扭轉載荷
toughness 韌性 tracing 描圖
under cut 凹割
業務與貿易關連用語
accept order 接受訂貨 account 帳戶
after service 售后服務 amendment 修正
annual sales 年銷售額 at sight 見票即付
balance 餘額 bank draft 匯票
bargain goods 廉價品 batch 批次
bid 出價 bid sales 投標買賣
bill of landing 提單 bills receivable 應收票據
brand 品牌 bulk cargo 散裝貨
business transaction 商業交易 buyer 買方
carbon copy 打字副本 cargo collection 攬貨
carton 紙箱 cash in advance 預付現金
catalogue 型錄 cheque 支票
CLF 運費保險費在內價格 claim 索賠
clearance goods 清倉品 commision 佣金
commission 批發商 complain 抱怨
container 貨櫃 correspondence bank 往來銀行
cost 成本 cost and freight; C&F 含運費價格
custom broker 報關行 customer 客戶
D/A 承兌交單 D/P 付款交單
deferred payment 分期付款 deferred shipment 分期裝運
delivery on spot 當場交貨 delivery time 交期
delivery order 交貨單 discount 折扣
discount on draft 貼現 documentary draft 跟單匯票
down payment 訂金 enclosure 附件
endorsement 背書 enquete 調查
exhibition 展覽會 export 出口
factory visiy 工廠參觀 favourable price 合宜價格
foreign exchange 外匯 free on board 船上交貨價
idea price 希望價格 import 進口
Japanese Industrial 日本工業規格 invoice 發票
L/C 信用狀 margin 利潤
market 市價 net weight 淨重
no payment 拒絕付款 odd item 零頭
offer 報價 open account 交互計算
order 訂單 over looked 疏漏
packing 包裝 pamphlet 小冊子
partial shipment 分批裝船 patent 專利
paying price 合算價格 payment method 付款方式
port of destination 目地港 port of trans-shipment 轉口港
price 價格 price decending 減價
price rising 漲價 procurement 採辦
prompt delivery 即時交貨 purchase 購入
purchasing agent 採購代理商 quotation 報價單
rebate 回扣 reference 查詢
remittance 匯款 repeat order 追加訂貨
request letter 請求函 rumor 風評
second hand goods 二手貨 shipper 貨主
shipping 裝船 shipping mark 麥頭
shipment 出貨 sold out 賣完
sole agent 總代理商 special discount 特別折扣
specification 規格 sample order 指樣訂貨
standing 信用情形 storage charge 倉租
subcontract 外包 subject to final confirmation 有待確認之報價
supplier 供應商 T/T 電匯
tie-in sale 搭售 trade fair 商展會
trans-shipment 轉運 transferred 已轉運
wharf 碼頭
A
3D coordinate measurement 三次元量床 3D modeling 三次元模擬
aberration 色差 abnormal glow 不規則輝光放電
abrasive 砂輪 access 通路
account 帳戶 accretion 爐瘤
accurate die casting 精密壓鑄 acid converter 酸性轉爐
acid lining cupola 酸性熔鐵爐 acid open-hearth furnance 酸性平爐
activator 活化劑 acetylene 乙炔
adjustable spanner 活動扳手 aerator 鬆砂機
after service 售後服務 age hardening 時效硬化
ageing 老化處理 air hardening 氣體硬化
airless plasting cleaning 離心噴光 air patenting 空氣韌化
air permeability test 透氣性試驗 air set mold 常溫自硬鑄模
air vent valve 通氣閥 all core molding 集合式鑄模
alloy tool steel 合金工具鋼 allround die holder 通用模型
aluminium alloy 鋁合金鋼 amendment 修正
ampere 電流安培 anchor pin 錨梢
angle cutter 角銑刀 angle welding 角焊
angular pin 角梢 angular pin 傾斜梢
animation 卡通影片 anode effect 陽極效應
annealing 退火 annual sales 年
 楼主| 发表于 23-11-2008 16:31:52 | 显示全部楼层
自己先顶一下
自己先顶一下,希望各位受用...
GMT+8, 23-4-2026 05:00 , Processed in 0.336264 second(s), 36 queries .
