  • 4989查看
  • 9回复
发动机冷却系统【简单的英语文章】
发表于 5-1-2009 21:31:01 | 显示全部楼层 |阅读模式
这个英语文章比较简单,大家可以试着翻译,提高英语水平。
The cooling system
Introduction
Your engine needs a cooling system to protect it from self-destruction. Burning gases inside the cylinders can reach a temperature of 4500°F (2500°C) and produce enough heat to melt a 200 lb. engine block.
About one-third of the heat produced in the engine must be carried away by the cooling system. Some is utilized for heating the passenger compartment. Moreover, strange as it seems, your vehicle’s air conditioner produces heat in the process of cooing and dehumidifying the air. This heat must also be dispersed by the cooling system.
How the cooling system works
The main parts of the engine cooling system are the radiator, pressure cap, hoses, thermostat, coolant pump, fan, and drive belt (except on electric fan engines). The system is filled with coolant, which should be a 50-50 mixture of antifreeze and water. No mater where you live or how hot or cold the weather becomes, the mixture should be maintained the year around.
The water pump and engine cooling fan are mounted on the same shaft and driven by a belt connected to the engine. The pump draws coolant from the bottom of the radiator and forces it through passages surrounding the hot area—the cylinders, combustion chambers, valves and spark plugs. From there the coolant flows through a hose into the top of the radiator, then downward through tubes attached to cooling fins and surrounded by air passages. Heat is transferred from the coolant to air forced through the radiator passages by the fan and the forward motion of the vehicle.
Controlling the temperature
It’s important to get the coolant up to normal operating temperature as quickly as possible to ensure enough smooth engine operation, free flow of oil, and ample heat for the occupants. When the engine is cold, the thermostat blocks the passage from the cylinder head to the radiator and sends coolant on a shortcut to the water pump. The cooling fluid is not exposed to the blast of air from the radiator, so it warms up rapidly. As temperature increases, the thermostat gradually opens and allows coolant to flow through the radiator.
Cooling systems on older vehicles were limited to a maximum temperature of 212°F (100°C)—the boiling point of water. To get rid of the extra heat generated by more powerful engines, automatic transmissions, and air conditioning, modern vehicles have pressurized systems using a 50-50 mixture of antifreeze and water which enables them to operate at temperature up to 263°F (129.4°C) without boiling. At this temperature, plain water alone would boil away.
Transmission oil cooler
Automatic transmission oil is cooled by a small, separate radiator, usually located in the lower tank or alongside the main radiator. While the only purpose of the engine coolant is to keep the block and upper engine components cool, the transmission oil has three functions. It hydraulically operates the transmission, lubricates the transmission internal components and also keep the transmission within proper operating temperature range.
Most vehicles can benefit from the installation of a transmission oil cooler, especially if the vehicle is used to pull a trailer or for some other kind of heavy service.
Engine oil cooler
Some vehicles, particular high performance or diesel engines, are equipped with an engine oil cooler. The oil cooler can be located in one of the radiator tanks (similar to the transmission oil cooler), or mounted separately, near the front of the engine, on aftermarket applications. Also, there is usually an adapter mounted between the engine block and the oil filter. If the cooler is mounted in a radiator tank, heat is dissipated from the oil to the coolant. A separate oil cooler usually looks like a small radiator and heat is dispersed from the tubes and fins in the cooler to the air passing through the cooler. The purpose of the cooler is to reduce the temperature of the oil, preventing oxidation and increasing the oil’s lubricating and protecting properties.
发表于 12-1-2009 13:46:35 | 显示全部楼层
我翻译了一下```就小部分没太弄懂```
但是真的很简单``````对于这么短的一篇能包括这么多``
还是多可以的了`
字数上2000就更好了
    擦汗
    29-1-2019 14:52
  • 签到天数: 4 天
    发表于 31-3-2010 21:01:25 | 显示全部楼层
    多谢分享了。。。。哈哈。。。
    发表于 12-4-2010 11:20:00 | 显示全部楼层
    翻译中,请勿打扰!
    发表于 9-4-2012 20:16:16 | 显示全部楼层
    额,,不能截取单词,要一个字母一个字母打到翻译软件里。。。。
    发表于 19-4-2012 20:58:18 | 显示全部楼层
    自学汽车英语两个月,基本能在不查词典情况下翻译上述文章,但仍有单词遗忘中,需补救……
    发表于 26-5-2012 16:55:05 | 显示全部楼层
    谢谢楼主分享
    发表于 30-5-2012 10:35:14 | 显示全部楼层
    我顶        你个肺
    发表于 4-10-2012 19:00:55 | 显示全部楼层
    顶起来
    发表于 19-11-2012 19:38:46 | 显示全部楼层
    亲。可以发到我邮箱吗
    623262237@qq.com
    GMT+8, 15-5-2026 08:16 , Processed in 0.400423 second(s), 41 queries .
