  • 1648查看
汽车专业英语(O-Z)
发表于 4-2-2009 16:29:59 | 显示全部楼层 |阅读模式
Odometer 里程表
Odontometer (齿轮)公法线测量仪
Off-gas 废[排]气
Off-position 断路位置,非工作位置
Offset 偏置;偏心
Offset cab 侧量驾驶室
Offset camshaft 偏置凸轮轴
Offset connecting rod 偏位式连杆
Offset cylinder 偏置气缸
Offset frame 偏置车架
Offset piston pin 偏置活塞销
Oil brake 液压制动器
Oil can 油壶,加油器
Oil circulating pump 机油循环泵
Oil cleaner 机油滤清器
Oil conduit 油道
Oil-control ring 油环
Oil coolant 冷却油
Oil cooled piston 油冷活塞
Oil cooler 机油冷却器
Oil deflector 导油器,挡油板
Oil delivery filter 输油滤清器
Oil drain hole (活塞环槽)回油孔
Oil drain cock 放油栓
Oil drain plug 放油塞
Oil emulsifier 润滑油乳化剂
Oil emulsion 乳化油
Oiler 加油器,注油器,油壶
Oil feeding line 供油装置
Oil feed line 供油管路
Oil filler 加机油口
Oil filler pipe 加油管
Oil film 油膜
Oil filter 机油滤清器
Oil filter body cover 机油滤清器口盖
Oil filter case 机油滤清器壳
Oil filter clamp 机油滤清器夹
Oil filter net 机油滤清器网
Oil hand pump 手动机油泵
Oiling 加油,润滑
Oil inlet 进油管
Oil jack 液压千斤顶
Oilless bearing 含油轴承
Oil level 油位,油面
Oil level dipstick 量油尺
Oil level warning sensor 机油油量报警传感器
Oil loam 油泥
Oil mist 油雾
Oil nipple 加油嘴
Oil outlet 机油出口
Oil overflow valve 溢油阀
Oil pan 机油盘,油底壳
Oil pan drain plug 机油盘放油塞
Oil pan gasket 机油盘衬垫
Oil pan seal 机油盘密封条
Oil pipe 机油管
Oil pistol 油枪
Oil pressure 油压
Oil pressure ga(u)ge 油压表,机油压力表
Oil pressure indicator 油压表
Oil pressure regulator body 油压调节器体
Oil pressure regulator gasket 油压调节器衬垫
Oil pressure regulator packing 油压调节器垫圈
Oil pressure regulator valve 油压调节器阀
Oil pressure relief valve 油压安全阀
Oil pressure sending unit 油压表传感器
Oil pressure stabilizer 油压稳定器
Oil pump 机油泵
Oil pump body 机油泵体
Oil pump body set screw 机油泵体固定螺钉
Oil pump cross gear 驱动机油泵螺旋齿轮
Oil pump driven gear 机油泵从动齿轮
Oil pump driving gear 机油泵主动齿轮
Oil pumping (活塞环)泵油作用
Oil pump location dowel 机油泵定位销
Oil pump safety valve 机油泵安全阀
Oil pump screen 机油泵滤网
Oil pump tube 机油泵管
Oil pump tube bush 机油泵管衬套
Oil quenching[hardening] 油淬
Oil regulating valve 机油调节阀
Oil renewal 机油再生
Oil reservoir 油罐,制动液罐
Oil resistance solid tire 耐油实心轮胎
Oil screen 滤油网
Oil screen cover 滤油网盖
Oil seal 油封
Oil seal retainer 油封护圈
Oil shield 油挡
Oil tank 油箱
Oil tank trailer 油罐挂车
Oil tank truck 油罐车
Oil tappet 液压挺杆
Oil temperature 油温
Oil temperature regulator 油温调节器
Oil thermometer 油温表
Oil thrower 抛油环
Oil tight 不漏油
Oil trough 油槽
Oil wiper 擦油器
Oily varnish 油性漆
One cylinder engine 单缸发动机
One hole nozzle 单孔喷嘴
One-piece rim 一件式轮辋
One-way road 单行线
One-way traffic 单向行驶,单向交通
One wire system 单线制(电路)
On ga(u)ge 符合公差
Open cell 非封闭式电池
Open combustion chamber 单一式燃烧室
Open die forging 自由锻
Open end wrenches 双手扳手
Open exhaust 自由排气
Open-link chain 开口链
Open type car body 敞式车身
Operating cam 作用凸轮
Opposed cylinder engine 对置气缸式发动机
Optical indicator 光学指示器
Optical tool presetter 光学对刀器
Oscillating axle 摆动轴
Oscillating cylinder 摆动(油,气)缸
Oscillation absorber 减振器
Oscillatory instability 振荡不稳定性
Oscilloscope 示波器
Otto cycle 奥托循环
Otto engine 四冲程内燃机
Outboard brake 轮毂外悬制动器
Outboard support 外侧支架
Outer lane 外车道
Outer panel [cover]蒙皮
Outlet valve 出油阀
Outlet velocity 出口速度
Outline 外廊,外形;概要
Out of control 失控
Output 输出,输出功率
Outside race 轴承外圈
Outside seat 外座
Ovality (活塞)椭圆度
Ovalization (活塞)椭圆化
Oval piston 椭圆形活塞
Overall 总计的,全部的
Overall efficiency 总效率
Overfill valve 过满阀
Overflow 溢流,溢出
Overflow nipple 溢流管嘴
Overflow pipe 溢流管
Overflow valve 溢流阀
Overfueling 呛油(供油过多而灭火)
Overhang 外悬(车身前后端悬出轴外)
Overhaul 大修
Overhauling 大修作业
Overhaul life 大修周期
Overhead camshaft 顶置凸轮轴
Overhead camshaft type engine 顶置凸轮式发动机
Overhead crossing 立体交叉点
Overhead servicing vehicle 架空修理车
Overhead valve 顶置气门
Overheat 过热
Overinflation (轮胎)过量充气
Overlap 重叠
Overlay 涂(镀)层
Overload 超载,过载
Overload protection brake 防过载制动器
Overload rating 过载定额
Over-lubrication 过度润滑,过量润滑
Over pass 立体交叉
Over recovery (制动器衰退的)过恢复
Over-revolution 超速
Over-rich mixture 过浓混合气
Overrunning clutch 单向离合器
Overshoot 超调量
Package 程序包;包装
Package tray (轿车)后窗台
Packeting machine 包装机
Packing 填料,垫料;包装
Packing cloth 密封布,填封布
Packing piece 填密片,垫片
Packing spring 衬垫弹簧,密封弹簧
Pad 衬垫,制动块
Paint 油漆,涂料
Pairglass 夹层玻璃
Pancake engine 卧式发动机
Panel (车身)板件;仪表板
Panel board for car bodies 车身仪表板
Panel body 厢式车身,封闭式车厢
Panel lamp[light] 仪表板照明灯
Parallel seat 平行座椅
Parallel spline 矩形花键
Parking lamp indicator 停车灯指示器
Parking lane 停车道
Parking meter 停车计时表
Parking place 停车车位
Parking prohibition 禁止停车
Parkometer 停车计时表
Part 部分,零件
Part design 零件设计
Part drawing 零件图
Part-flow smokemeter 部分流式烟度计
Partial failure 局部故障
Partial floating 半浮动
Partial flow sampling 部分流取样法
Partial projection 局部投影
Parts cleaner 零部清洗机
Parts cleanliness 零件清洁度
Parts list 零件表,配件目录
Parts repair 零件修理
Parts throttle 部分节流
Pass band 通(频)带
Passenger car tire 轿车轮胎
Passenger compartment 客厢
Passing lamp[light] 近光灯,会车灯
Patch rubber 修补用橡胶片
Patent 专利
Patent application 专利申请
Patent law 专利法
Patent leather 漆皮
Pedal 踏板
Pedal arm 踏板臂
Pedal bush 踏板衬套
Pedal effort 踏板力
Pedalfree autochoke 全自动阻风门
Pedal jack 脚踏起重器,千斤顶
Pedal-operated oil pump脚踏油泵
Pedal pad 踏板垫
Pedal plate 脚踏板
Pedal pressure 踏板力
Pedal shaft 踏板轴
Pedal stopper 踏板限位螺栓
Pedal switch 踏板开关
Pedal travel 踏板行程
Petrol economiser 省油器
Petrol engine 汽油(发动)机
Petrol pump 汽油泵
Petrol tank strap 汽油蒸气
Pferdestaerke 马力
Phase delay 相位滞后
Phase difference 相位差
Quadruple cylinder engine 四缸发动机
Quality control 质量控制
Quantity 数量
Quantity control valve 定量控制阀
Quick approach 快速接近
Quick charge 快速充电
Quick charger 快速充电机
Quick detachable rim 快卸式轮辋
Quick chuck 快换夹头
Quick fittings 快速接头
Quick joint 快换接头
Quick return stroke 快速回程
Quick steering 快速转向
Quill bearing 滚针轴承
Quieting ramp (凸轮)消声斜面
Race (轴承内,外,座)圈;竞赛,赛跑,全速行驶,发动机空转;种族
Raceabout(美)赛车
Rack 齿条,导轨,支架
Rack and pinion 齿轮齿条
Rack and pinion jack 齿轮齿条式千斤顶
Rack link 齿条联接杆
Rack nut 齿条螺母
Rack shaft 齿条
Rack-type steering gear 齿条式转向器
Radial bearing 向心轴承
Radial brush 径向电刷
Radial engine 星形发动机
Radial flow type converter 径流式转化器
Radial piston pump 径向活塞泵
Radial ply tire 子午线轮胎
Radial roller bearing 向心滚子轴承
Radial run-out 径向跳动
Radial spoke 径向辐条
Radial stiffness (车轮)径向刚度
Radial turret head 六角刀架
Radian 孤度(角)的单位
Radiant heat 辐射热
Radiating fin 散热片
Radiation dryer 辐射式干燥器
Radiation of heat 热辐射
Radiation pollution 辐[放]射污染
Radiation protection 辐[放]射防护
Radiator 散热器,水箱
Radiator cap 散热器盖
Radiator case frame 散热器框架
Radiator cleaner 散热器清洗器
Radiator core 散热器芯
Radiator cover 散热器面罩
Radiator cowling 散热器罩
Radiator flush 散絷器冲洗器
Radiator hose clip 散热器软管夹
Radiator insulation 散热器隔振垫
Radiator mascot 散热器盖口装饰性标志
Radiator of airconditioner 空气调节系统散热器
Radiator overflow 散热器溢流管
Radiator protecting plate 散热器护板
Radiator repair stand 散热器修理架
Radiator shell 散热器外壳
Rear apron 后档板
Rear axle 后轴,后桥
Rear axle casing(独立悬挂)后桥轴壳
Rear axle housing 后轴壳
Rear axle bousing cover 后轴壳盖
Rear axle radius rod 后轴纵向位杆
Rear axle shaft 后桥半轴
Rear axle tube 后轴半轴套管
Rear bearing cover 后轴承盖
Rear bearing cover packing 后轴承盖填料
Rear brake 后轴制动器
Rear brake lever 后制动器杆
Rear brake lining 后制动器摩擦片
Rear bumper 后保险杆
Rear bumper height 后保险杠高
Rear engine 后置发动机
Rear-engined bus 后置发动机客机
Rear engine rear drive 后置发动机后轮驱动
Rear engine support 发动机后支架
Rear servo-brake 后助力制动分室
Rear shelf 后窗台板
Rear side member 后纵梁
Rear spoiler 后扰流板
Rear spring 后弹簧
Rear spring bracket 后钢板弹簧架
Rear stabilizer bar 后稳定杆
Rear support bracket 后支承架
Rear support insulator bolt 后支架软垫螺栓
Safety 安全
Safety belt[band] 安全带
Safety can 安全罐
Safety car [vehicle]安全汽车(有在出事故时保护乘客的装置)
Safety catch 安全挡[锁扣,拉手]
Safety chain 安全链,(油罐车)接地链
Safety coefficient[factor] 安全系数
Safety cylinder 安全缸
Safety door 安全门
Safety double glass 安全中空玻璃
Safety fence 防护栅栏
Safety glass 安全玻璃,不碎玻璃
Safety guard 安全罩
Safety harness 安全带
Safety relay valve 安全继动阀
Safety spark gap 安全火花间隙
Safety switch 安全开关
Safety valve 安全阀
Sand cleaner 喷砂清洁器
Sand cloth 砂布
Sander 砂光机
Sand mo(u)ld casting 砂型铸造
Sand paper 砂纸
Sandwich glass 夹层玻璃
Sandwich material 夹层材料
Sanitizer 清扫车
Saxomat auto clutch 离心式自动离合器
Saxonia metal 锌基轴承合金
Scaffolding 台架
Scanning head 扫描头
Scavenge oil pump 回油泵
Scavenger 清除剂;防积碳添加剂;扫气泵
Scratch 拉缸
Scratch hardness 刮痕硬度
Screen 屏幕,屏蔽
Screened ignition 屏蔽点火
Screened wire 屏蔽电线
Screw base 螺口灯头
Screw bolt 螺栓
Screw brake 螺旋制动器
Screw clamp 螺旋夹
Screw cutting machine 螺纹切削机床
Screw die 板牙
Screwdriver 螺纹旋具,螺丝刀,起子,改锥
Screwed bulb 螺口灯炮
Screwed socket 螺纹插座
Screw ga(u)ge 螺纹量规
Screw gear 螺旋齿轮
Screw gearing 螺旋齿轮装置
Screw head slotter 螺钉头开槽机
Screw hole 螺孔
Screw jack 螺旋千斤顶
Screw micrometer 螺旋千分尺
Screw nut 螺母
Screw (and) nut steering gear 螺杆螺母式转向器
Screw pair 螺旋副
Screw pitch 螺距
Screw pitch ga(u)ge 螺距量规
Screw plate 搓丝板
Screw stud 双头螺栓,螺柱
Screw tap 丝锥
Tachograph 行驶记录表
Tachograph paper 速度记录器用纸
Tachometer 转速表
Tachometer carburetor 转速调节式化油器
Tailboard 货箱后板
Tail bumper 后保险杠
Tail pipe (排气管)尾管
Tail slide 后(轮向外)滑
Take charge 失控
Take-off 取走;起飞;功率输出
Tandem 串联
Tandem brake master cylinder 串联制动主缸
Tandem cylinder 串列式缸
Tandem engines 串联式发动机
Tandem master cylinder 串联式(制动器)主缸
Tandem piston 串联活塞
Tangent(ial) cam 切线凸轮
Tangential stiffness matrix 切线刚度矩阵
Tangential water inlet 切向进水口
Tank 油[水]箱[槽,罐];坦克
Tank capacity 油[水]箱容量
Tanker 罐(式汽)车;油轮
Tank filler 油[水]箱加油[水]口
Tank filler cap 油[水]箱加油[水]盖
Tank filler opening 油[水]箱加油[水]口
Temperature control valve 温度控制阀
Temperature ga(u)ge 温度表
Temperature sensor 温度传感器
Temperature stress 温度应力
Temperature switch 温度开关
Tempered heatabsorbing glass 吸热钢化玻璃
Tempered spring 回火的弹簧
Thermal analysis 热分析;热裂化
Thermal balance 热平衡
Thermal capacity 热容量
Thermal conductivity 热传导率
Thermal cracking 热裂化
Thermal efficiency 热效率
Thermal equivalent of work 热功当量
Thermal expansion 热膨胀
Thermal loss 热损失
Thermal reactor 热反应器[堆]
Thermal spraying 热喷涂[镀]
Thermal stability 热稳定性,抗热性
Thermal stress 热应力
Thermal treatment 热处理
Thermofin 散热片
Thermometer 温度计
Thermoplastic(s) 热塑性塑料
Thermostat 恒温器
Thermostat-controlled carburettor 恒温器控制的化油器
U-bolt U形螺栓
U-bolt washer U形螺栓垫圈
Ultimate stability 极限稳定性
Ultrasonic 超声(波)
Ultrasonic cleaning 超声清洗
Ultrasonic degreasing 超声脱脂
Unblended gasoline 未掺合汽油
Unblended octane number 掺合前辛烷值
Uncomplete combustion 不完全燃烧
Undercooling 过冷却
Undercut (齿轮的)根切
Underfloor engine 底置发动机
Underfloor engine rear wheel drive 底置发动机后轮驱动
Underground fuel storage tank 地下燃油罐
Underground garage 地下车库
Under-inflation 轮胎气压不足
Underrated octane number 低枯辛烷值
Underseat tank 座位下的油箱
Underslung frame 下弯式车架
Underslung spring 下悬式弹簧
Universal electric tester 万能电器试验机
Universal joint[coupling] 万向(联轴)节
Universal puller 万能拆卸工具
Unleaded gasoline 无铅汽油
Unload 卸载[货]
Unorganic glass 无机玻璃
Updraft carburetor 上吸式化油器
Upholstery 内饰
Upholstery covering 内饰覆盖物
Upholstery fabrics 内饰织物
U-piston engine U形槽活塞发动机
Upper ball joint 上球形接头
Upper beam 远光;顶梁
Upper control arm (悬架)上控制臂
Upper crankcase 上曲轴箱
Upper dead center 上止点
Upper spring seat 上弹簧座
Upper wishbone 上叉形拉臂
Upright drilling machine 立式钻床
Upright support 立式托架
Upset 镦锻
Upset forging ratio 顶锻镦粗比例
Used car 旧车,二手车
Used oil 废机油
Used oil regenerator[reclaimer] 废油再生器
Useful horsepower 有效功率[马力]
Useful load 有效载荷
Useful service life 有效使用寿命
Useful voltage 有效电压
User 用户
U-slot piston U形槽活塞
U-steel 槽钢
U-turn (车辆)调头
U-turn prohibition 禁止调头
Vacuum 真空
Vacuum advance mechanism 真空提前机构
Vacuum (ignition) advancer 真空提前点火装置
Vacuum brake 真空式制动器
Vacuum carburetor 真空式化油器
Vacuum check valve (真空)单向阀
Vacuum control 真空控制
Vacuum controlled gear shift 真空控制换档
Vacuum control valve 真空控制阀
Vacuum cup 真空吸盘
Vacuum ejector 真空喷射器
Vacuum ga(u)ge 真空表
Vacuum modulator 真空调节器
Vacuum-operated clutch 真空操纵离合器
Vacunm pipe 真空导管
Vacuum power brake 真空动力制动
Vacuum pump 真空泵
Vacuum regulating valve 真空调节阀
Vacuum reservoir 真空罐
Vacuum servo brake 真空伺服制动器
Vacuum spark advancer 真空提前机构
Vacuum speed governor (柴油机)真空调速器
Vacuum switch 真空开关
Vacuum tank 真空罐
Vacuum truck 吸污车
Vacuum valve 真空阀
Vacuum warning switch 真空报警开关
Vacuum wiper 真空式风窗刮水器
Valve 阀(门),(发动机配气机构)气门,(轮胎)气门嘴
Valve area 气门通道面积
Valve cage 阀笼,气门室
Valve cap 气门(嘴防尘)帽
Valve clearance 气门间隙
Valve core 气门芯
Valve cotter 气门锁环(销)
Valve cover 气门盖
Valve engine 气门式发动机
Valve face 阀面,气门面
Valve gear 气门机构
Valve gear timing 气门机构正时
Valve grinder 气门研磨机
Valve grinding 气门研磨
Valve grinding compound 气门研磨剂
Valve grinding tool 气门研磨具(手工研磨)
Valve guide 气门导管
Valve guide reamer 气门导管绞刀
Valve head 气门头
Valve-in-head engine 顶置气门发动机
Valve insert 气门镶座
Valve inside 气门芯
Valve lapper 气门研磨工具
Valve lash 气门间隙
Valve-lash adjuster 气门间隙调整
Valveless engine 无气门发动机(指二冲程或转子式)
Valve lift 气门升程
Valve lift diagram 气门升程图
Valve lifter 气门挺杆;气门提升器
Valve (head) margin 气门头(顶面与锥面间的)边缘(宽度)
Valve lock 气门锁片
Valve needle 阀针
Valve overlap 气门重叠
Valve refacer 气门研磨机
Valve refacing 气门研磨
Valve regulation 气门调整
Valve reseater 气门座修整器
Valve rocker 气门摇臂
Valve seat 气门座
Valve seat cutter 气门座铰刀
Valve seat grinder 气门座磨光机
Valve seat refacer 气门座光面器
Valve seat ring[insert] 气门镶座
Valve setting 气门调整
Valve silencer 气门消音装置
Valve spring 气门弹簧
Valve spring compressor 气门弹簧压缩工具
Valve spring lifter 气门弹簧提升器
Valve spring seat 气门弹簧座
Valve spud 气门嘴座
Valve steel 气门用钢
Valve stem 气门杆
Valve stem guide 气门杆导管
Valve stroke [travel]气门行程
Valve tappet 气门挺杆
Valve timing 配气正时
Valve timing adjusting 配气正时调整
Valve umbrella 气门伞形罩
Van 厢式货车
Van body 厢式货箱
Van container 大型集装箱
Vane 叶片
Vane angle 叶片角
Vaned wheel 叶轮
Vane pump 叶轮泵
Vapo(u)r (水)蒸气
Vapor deposition 气相淀积
Vapor return pipe 燃油蒸气回收管
Vapor separator 蒸气分离器
Variable capacity converter 变容式液力变矩器
Variable capacity oil pump 变量油泵
Variable compression engine 可变压缩比发动机
Variable-displacement motor 变量(液压)马达
Variable-displacement pump 变量(液压)泵
Variable gear ratio 可变传动比
Variable lift cam 变升程凸轮
Wankel engine 转子发动机
Warehouse 仓库
Warm up (冬季发动机)加温
Warning 报警,警告
Warning board 标志牌,警告牌
Warning buzzer 蜂鸣器(倒车用)
Warning flasher 报警闪光灯
Warning horn 喇叭
Warning sensor 报警传感器
Water circulation 水流循环
Water-cooled brake 水冷制动器
Water-cooled engine 水冷发动机
Water-cooled exhaust manifold 水冷排气歧管
Water-cooled jacket 水套
Watercooler 水冷却器
Water cooling 水冷
Water nozzle 水喷嘴
Water manifold (水套)导水管
Waterproof 防水的
Water-proff packing 防水密封
Water pump 水泵
Water pump impeller 水泵叶轮
Water quench 水淬(热处理)
Water scale 水垢
Water separator 水分离器
Water trap 脱水器
Waxing 打蜡
Wax pattern 蜡模
Weak mixture 稀薄混合气
Weapon 武器
Wear rate 磨损率
Wedge board 侧滑测定器
Wedge brake 楔式制动器
Wedge type[shape] 楔形车身
Wedge type ring 楔形(活塞)环
Weld 焊接
Wet clutch 湿式离合器
Wet(cylinder) liner[sleeve] 湿式气缸套
Wet multiple disc clutch 湿式多盘离合器
Wetness 湿度
Wheel 轮子,车轮;齿轮;转向盘;转动
Wheel aligner 转向轮定位仪
Wheel alignment 车轮定位
Wheel alignment indicator 轮位对准指示器
Wheel alignment tester 轮位对准试验器
Wheel arch 车轮拱罩
Wheel arrangement 车轮排列
Wheel balancer 车轮平衡机
Wheel base 轴距
Wheel bolt 车轮螺栓
Wheel brake 车轮制动器
Wheel cap 轮毂罩
Wheel center 轮心(转向节上装车轮的心轴)
Wheel changing 车轮换位
X-engine X型发动机
Xenon lamp 氙光灯(用于正时灯)
X-ray diffraction X射线衍射
X-ray inspection X射线探伤
X-type frame X形车架
X-Y plotter X-Y绘图仪
Yaw velocity 横摆角速度
Yaw vibration 横摆振动
Yawing moment 横摆力矩
Y-type engine 星形发动机
Young's modulus (杨氏)弹性模量
Yellow light 黄灯
Yellow zone (转速表表盘)黄区
Z-alloy Z合金
Zero bevel gear 零度锥齿轮
Zero camber 零外倾(角)
Zinc accumulator 锌蓄电池
Zinc alloy 锌合金
Zinc galvanizing 镀锌
Zip(per) 拉链
发表于 21-4-2025 06:58:01 | 显示全部楼层
汽车专业英语涵盖了从基础到高级的各类汽车相关词汇。从“O”到“Z”,涵盖了汽车设计、制造、维护等各个方面的专业术语。掌握这些专业英语,对于汽车工程师来说至关重要。这些词汇不仅涉及发动机、底盘、电气系统等核心部件,还包括汽车设计理论、材料科学以及市场分析等相关领域。熟练运用汽车专业英语,能更有效地进行技术沟通,提高工作效率,促进技术创新与发展。建议学习者结合实际工作场景,通过查阅专业文献、参加国际研讨会等方式,加强汽车专业英语的学习与应用。
GMT+8, 27-4-2026 11:58 , Processed in 0.431804 second(s), 35 queries .
