  • 1388查看
求有关脉冲涡轮增压起的英文单词词汇(高手帮忙翻译一下)
发表于 14-5-2009 06:36:13 | 显示全部楼层 |阅读模式
Modern pulse-turbocharged systems produce a turbine operating environment that is dominated by unsteady flow.  Effective utilization of the unsteady exhaust gas energy content at the turbine inlet is critical to achieving optimum system efficiency.  This work presents predictions for turbocharger unsteady performance from a model based on the Euler equations with source terms (EEST).  This approach allows the time-accurate performance of the turbine to be determined, allowing comparisons of actual energy utilization and that estimated from steady flow performance maps.
谢谢各位了
[ 本帖最后由 aning 于 14-5-2009 06:58 编辑 ]
发表于 25-4-2025 02:42:19 | 显示全部楼层
关于脉冲涡轮增压的英文词汇,我可以为您提供以下翻译:
1. 脉冲涡轮增压器:Pulse Turbocharger
2. 脉冲控制:Pulse Control
3. 脉冲进气压力:Impulse Inlet Pressure
4. 脉冲增压空气压力调节器:Impulse Boost Air Pressure Regulator
请注意,具体的专业词汇可能会根据技术领域或特定的技术背景有所变化。为了确保准确性,您最好查阅相关领域的英文技术文献或使用专业术语库。如果您有更多具体问题或需要进一步解释,请随时告知。
GMT+8, 25-4-2026 10:32 , Processed in 0.364832 second(s), 35 queries .
