  • 2193查看
发动机性能指标
发表于 26-5-2009 20:38:33 | 显示全部楼层 |阅读模式
enging performance                发动机性能
loading perfromance                加载性能
stating perfromance                启动性能
acceleration performance                加速性能
power performance                动力性能
no-load characteristics                空载特性
partial thorttle characteristics                负载特性
governor control characteristics                调速特性
mapping characteristic                万有特性
steady-state speed governing rate                稳定调速率
idling speed(no load speed)                最低空载转速
maximum idling speed                最高空载转速
lowest continuous full-load speed                最低工作稳定转速
ecomomic speed                经济转速
steady-state speed band                转速波动率(稳定转速波动率)
maximum transient speed(overshoot speed)                最高瞬时转速
minmum transient speed(undershoot speed)                最低瞬时转速
transient speed regulation(transient speed difference)                瞬时调速率
speed droop                 稳定调速率
hunting                游车
operating condition                工况
declared operating condition                标定工况
economic operating condition                经济工况
indicator diagram                示功图
cleclared(rated)power                标定功率
corrected power                修正功率
standard power                标准功率
smoke limit power                 冒烟极限功率
constant speed characteristics                负荷特性
fixed throttle(rack) characteristics                速度特性
full-load (full throttle) characteristics                外特性
propeller characteristics                推进特性
trailing characteristics                牵引特性
fuel consumption map                万有特性
speed goerning characteristics                调速特性
regulation characteristics                调节特性
starting speed        na        启动转速
declared speed        n        标定转速
speed at maximum torque        ntq        最大扭矩转速
coefficient of speed reserve        φn        转速储备系数
power        P        功率
indicated power        Pi        指示功率
mechanical loss power        Pm        机械损失功率
brake power        Pe        有效功率                                αφθΔηβΩεπλ
power per litre        PL        升功率
maximum power        Pmax        最大功率
coefficient of power reserve        φp        功率储备系数
mechanical efficiency        ηm        机械效率
torque        Ttq        扭矩
maximum torque        Ttqmax        最大扭矩
torque backup        φtq        扭矩储备系数
coefficient of adaptability        φntq        适应性系数
mean indicated pressure        pi        平均指示压力
indicated thermal efficiency        ηi        指示热效率
indicated specific fuel consumption        bi        指示油耗率
indicated specific energy consumption        Ei        指示能耗率
mean mechanical loss pressure        pmm        平均机械损失压力
brake mean effective pressure(BMEP)        pme        平均有效压力
coefficient of intensification        pme·Vm        强化系数
effective brake thermal efficiency        ηet        有效热效率
fuel consumption        B        燃油消耗量
specific fuel consumption        b        燃油消耗率
minimum specific fuel consumption        bmin        最低燃油消耗率
lub-oil consumption        C        机油消耗量
specific lub-oil consumption        c        机油消耗率
air consumption        Aa        空气消耗量
specific air consumption        a        空气消耗率
air fuel ratio                空燃比
fuel air ratio                燃空比
compression ratio                压缩比
critical compression ratio                临界压缩比
expansion ratio                膨胀比
surface to volume ratio                面容比
mixture ratio                混合比
fuel equivalence ratio                燃料当量比
torque                扭矩
power per cylinder                单缸功率
power per liter                升功率
mass per liter                升质量
derating power                减额功率
output power                输出功率
gross power                总功率
net power                净功率
torque per liter                升扭矩
fuel consumption                燃油消耗量
sepcific fuel consumption                比燃油消耗量
oil consumption                机油消耗量
rate power                额定功率
brake power                制动功率
brake thermal efficiency                制动热效率
indicted thermal efficiency                指示热效率
overall efficiency                总效率
power curve                功率曲线
mechanical loss                机械损失
mechancial efficiency                机械效率
effictive thermal efficiency                有效热效率
volumetric efficiency                容积效率
excess air coefficient                过量空气系数
adaptive coefficient                适应性效率
torque adaptive coefficient                扭矩适应性效率
speed adaptive coefficient                转速适应性效率
intensification coefficient                强化系数
correction factor                校正系数
conversion factor                转化系数
mean piston speed                活塞平均速度
engine speed                发动机转速
lowest continuous speed with load                最低稳定转速
lowest idling temperature                最低怠速温度
maximum torque speed                最大扭矩转速
maximum noload governed speed                受控最高空载转速
speed governing                调速
overspeed                超速
idling                怠速
speed fluctuation rate                转速波动率
working condition(oprating condition)                工况
rate working condition                额定工况
variable working condition                变工况
steady working condition                稳定工况
no-load                空载
full load                全负荷
part load                部分负荷
charge                充气
driection of rotation                旋转方向
clockwise                顺时针
anticlockwise                逆时针
left-hand rotation                左转
right-hand rotation                右转
发表于 23-4-2025 08:52:35 | 显示全部楼层
针对发动机性能指标,以下是我的专业回复:
发动机性能指标是衡量汽车性能的关键参数。主要包括动力性、经济性、排放性、可靠性及噪音等方面。动力性指标如最大功率和扭矩,决定车辆的加速能力和最高时速。经济性指标如燃油消耗率,直接影响运行成本。排放性指标反映发动机对环境的影响。可靠性和噪音水平则影响使用舒适性和耐久性。优良的发动机性能指标是汽车高品质的重要保障。
GMT+8, 25-4-2026 15:55 , Processed in 0.431209 second(s), 33 queries .
