  • 1701查看
内燃机试验术语
发表于 26-5-2009 20:40:03 | 显示全部楼层 |阅读模式
design of experiments        DOE        试验设计
one factor at a time                单因次试验
corporate engineering test procedures        CETP        公司工程测试程序
design verification        DV        设计验证
design verification plan        DVP        设计验证计划
design verification method        DVM        设计验证方法
design verification process and production validation        DV&PV
design varification plan and report        DVP&R        设计验证计划和报告
design varification & product reliability        DVP&P        设计验证和产品可靠性
design verification and process verification        DV&PV        设计验证和过程验证
european steady state cycle        ESC        稳态工况
european load response test        ELR        负荷烟度试验
european transient cycle        ETC        瞬态循环
standard reference condition                标准环境状况
bench test                台架试验
starting test                启动试验
performace test                性能试验
exhaust analysis test                废气分析试验
no-load characteristic test                空载特性试验
sudden load change test                突变负荷试验
cylinder fuel-cut test                停缸试验
simulated test                模拟试验
cylinder uniformity test(cylinder variation test)                各缸均匀性试验
supercharger-cut test                停增压器试验
reversing test                换向试验
back pressure test                背压试验
speed test                转速试验
steadiness test                稳定性试验
heat balance test                热平衡试验
motoring test                拖动试验
astern rnning test                倒车试验
road test                道路试验
sea trial test                航行试验
traction test                牵引试验
mooring trial test                系泊试验
endurance test                耐久试验
hop-up test(overrating test)                强化试验
thermo-shock test                热冲击试验
accelerated wear test                快速磨损试验
special ambient test                特种环境试验
parallel operation test                并车试验
acceptance test                验收试验
type test                鉴定实验(型试实验)
delivery test                出厂实验
high speed with idle test                高怠速试验        考核所有零件
general durability                常规耐久试验        考核所有零件
critical speed test                关键转速试验
exhaust manifold test                排气歧管开裂试验
发表于 24-6-2009 23:21:05 | 显示全部楼层
受用了,还是这种不用花钱的好
发表于 26-6-2009 18:00:59 | 显示全部楼层
就是有点儿少。。。。。。。。
GMT+8, 3-5-2026 11:50 , Processed in 0.415943 second(s), 36 queries .
