  • 1076查看
帮个忙,翻译一下,谢谢!
发表于 5-6-2009 19:43:45 | 显示全部楼层 |阅读模式
the steering gear includes a housing ,a worm ,a ball nut ,a rack made integral with the piston ,a hydrulic booster,and a toothed sector integrated with the pitman arm shaft.
a higher torque should be applied to the wheels to set an automobile in motion or move uphill with a full load than to keep it rolling after it gets under way on level stretches of the road, when inertia is high and tractive resistance is low
发表于 6-6-2009 19:20:46 | 显示全部楼层
齿式转向器由壳体,涡轮,圆螺母,与活塞做成一体的齿条,液压助力器和与摇臂轴做成一体的扇形齿轮构成。
汽车满载上坡作用在轮胎上的扭矩比在平直公路上的要大,在平直公路上汽车的惯性大,牵引阻力小。
发表于 6-6-2009 19:22:04 | 显示全部楼层
水平有限  见谅
发表于 6-6-2009 20:02:14 | 显示全部楼层
个人感觉翻译的比较专业
发表于 14-10-2009 21:34:05 | 显示全部楼层
译的不错挺准确的
发表于 13-12-2009 21:42:12 | 显示全部楼层
翻译的很好,顶下
GMT+8, 2-5-2026 14:05 , Processed in 0.397762 second(s), 40 queries .
