  • 2076查看
[底盘电器] J1939协议的问题
发表于 30-7-2009 10:49:45 | 显示全部楼层 |阅读模式
我看J1939方面的资料 上面有介绍TSC的,就是扭矩速度根据人为定义的TSC来控制。但是为什么后面还有说明,意思就是说在这个速度控制模式下发动机会自动朝着理想的转速或者扭矩去靠近。那么TSC自定义的扭矩或者转速 还有什么用处呢? 注:理想的转速或者扭矩,上面标注的是1800RPM 和 25%的扭矩。
[ 本帖最后由 江北老怪 于 30-7-2009 10:53 编辑 ]
发表于 7-8-2009 13:39:48 | 显示全部楼层
I hope can help you.
对于这个问题,楼主没有表达清楚。
TSC是Torque/Speed Control的简称
In the vehicle CAN system,a lot of  CAN users can send TSC,for example,transmission can send TSC to Engine, and transmission can also send TSC to Engine retarder.
In TSC which Transmission send to Engine, it can include a lot of parameters,
like:
Override Control Mode;
Override Control Mode Priority;
Request speed limit;
Request torque limit  and so on.
Override Control Mode Priority meaning: This field is used as an input to the engine to determine the priority of the Override Control Mode received in the TSC message.
Note: It is not required to use the same priority during the entire  override function. For example, the transmission can use priority 01(High priority)during a shift, but can set the priority to 11(Low pritory)at the end of  the shift to allow traction control to also interact with the torque limit of the engine.
发表于 13-8-2009 10:36:05 | 显示全部楼层
.....还好我懂点汽车英语    2楼的最好翻译成中文
GMT+8, 2-5-2026 21:37 , Processed in 0.509442 second(s), 40 queries .
