  • 6412查看
广州本田车的自动变速器代码表
发表于 28-8-2009 19:22:19 | 显示全部楼层 |阅读模式
广州本田2.4\AT                7,10400
通讯过程如下:
00H,
RECE:40H,05H,00H,02H,b9H,
SEND:00S,07S,00S,02S,b9S,00S,3eS,
RECE:40H,05H,78H,05H,3eH,
SEND:00S,77S,08S,05S,3eS,00S,3eS,
00H,
RECE:20H,05H,00H,02H,d9H,
SEND:00S,07S,00S,02S,d9S,00S,1eS,
RECE:45H,07H,72H,00H,00H,05H,3dH,
SEND:05S,0bS,72S,00S,00S,02S,03S,00S,0fS,08S,62S,
RECE:2eH,04H,f1H,ddH,
SEND:0eS,03S,efS,
00H,
SEND:0eS,03S,efS,
00H,
RECE:7dH,06H,02H,01H,00H,7aH,
SEND:0dS,08S,02S,01S,00S,7aS,00S,6eS,
RECE:45H,07H,72H,00H,00H,01H,41H,
SEND:05S,07S,72S,00S,00S,02S,80S,
RECE:45H,07H,72H,10H,00H,01H,31H,
SEND:05S,06S,72S,10S,00S,73S,
RECE:45H,07H,72H,11H,00H,01H,30H,
SEND:05S,06S,72S,11S,00S,72S,
RECE:45H,07H,72H,12H,00H,01H,2fH,
SEND:05S,07S,72S,12S,00S,00S,70S,
RECE:45H,07H,72H,20H,00H,01H,21H,
SEND:05S,06S,72S,20S,00S,63S,
RECE:45H,07H,72H,21H,00H,01H,20H,
SEND:05S,06S,72S,21S,00S,62S,
RECE:45H,07H,72H,22H,00H,01H,1fH,
SEND:05S,07S,72S,22S,00S,14S,4cS,
RECE:45H,07H,72H,23H,00H,01H,1eH,
SEND:05S,06S,72S,23S,00S,60S,
RECE:45H,07H,72H,24H,00H,01H,1dH,
SEND:05S,06S,72S,24S,00S,5fS,
RECE:45H,07H,72H,60H,00H,01H,e1H,
SEND:05S,06S,72S,60S,00S,23S,
RECE:45H,07H,72H,61H,00H,01H,e0H,
SEND:05S,06S,72S,61S,00S,22S,
RECE:45H,07H,72H,62H,00H,01H,dfH,
SEND:05S,07S,72S,62S,00S,00S,20S,
RECE:45H,07H,72H,70H,00H,01H,d1H,
SEND:05S,06S,72S,70S,00S,13S,
RECE:45H,07H,72H,71H,00H,01H,d0H,
SEND:05S,06S,72S,71S,00S,12S,
RECE:45H,07H,72H,72H,00H,01H,cfH,
SEND:05S,07S,72S,72S,00S,00S,10S,
RECE:45H,07H,72H,73H,00H,01H,ceH,
SEND:05S,06S,72S,73S,00S,10S,
RECE:45H,07H,72H,74H,00H,01H,cdH,
SEND:05S,06S,72S,74S,00S,0fS,
RECE:45H,07H,72H,b0H,00H,01H,91H,
SEND:05S,06S,72S,b0S,00S,d3S,
RECE:45H,07H,72H,b1H,00H,01H,90H,
SEND:05S,07S,72S,b1S,00S,00S,d1S,
RECE:45H,07H,72H,b2H,00H,01H,8fH,
SEND:05S,07S,72S,b2S,00S,80S,50S,
RECE:45H,07H,72H,b3H,00H,01H,8eH,
SEND:05S,07S,72S,b3S,00S,00S,cfS,
RECE:45H,07H,72H,b4H,00H,01H,8dH,
SEND:05S,07S,72S,b4S,00S,80S,4eS,
RECE:45H,07H,72H,b5H,00H,01H,8cH,
SEND:05S,07S,72S,b5S,00S,00S,cdS,
RECE:45H,07H,72H,b6H,00H,01H,8bH,
SEND:05S,07S,72S,b6S,00S,00S,ccS,
RECE:45H,07H,72H,c0H,00H,01H,81H,
SEND:05S,06S,72S,c0S,00S,c3S,
RECE:45H,07H,72H,c5H,00H,01H,7cH,
SEND:05S,07S,72S,c5S,00S,00S,bdS,
RECE:45H,07H,72H,e0H,00H,01H,61H,
SEND:05S,06S,72S,e0S,00S,a3S,
RECE:45H,07H,72H,e1H,00H,01H,60H,
SEND:05S,07S,72S,e1S,00S,00S,a1S,
RECE:45H,07H,72H,e2H,00H,01H,5fH,
SEND:05S,07S,72S,e2S,00S,64S,3cS,
RECE:45H,07H,72H,f0H,00H,01H,51H,
SEND:05S,06S,72S,f0S,00S,93S,
RECE:45H,07H,72H,f2H,00H,01H,4fH,
SEND:05S,07S,72S,f2S,00S,00S,90S,
RECE:45H,07H,72H,feH,00H,01H,43H,
SEND:05S,06S,72S,feS,00S,85S,
RECE:45H,07H,72H,ffH,00H,01H,42H,
SEND:05H,06H,72H,ffH,00H,84H,
RECE:45H,05H,73H,01H,42H,
SEND:05S,0cS,73S,01S,00S,00S,00S,00S,00S,00S,00S,7bS,
SEND:0eS,03S,efS,
读码:
00H,
RECE:feH,04H,36H,c8H,
SEND:0eH,04H,36H,b8H,
RECE:45H,05H,73H,01H,42H,       读当前码命令
SEND:05H,0cH,73H,01H,00H,
        00H,00H,                故障码1
        00H,00H,                故障码2
        00H,00H,                故障码3
        7bH,
01-1    P1753   扭矩变换器离合器(TCC)电磁阀A故障
01-2    P0743   扭矩变换器离合器(TCC)电磁阀A故障
01-3    P2769   液力变扭器离合器(TCC)电磁阀A输出过低
01-4    P2770   液力变扭器离合器(TCC)电磁阀A输出过高
02-1    P1758   扭矩变换器离合器(TCC)电磁阀B故障
02-2    P2756   TCC电磁阀B故障
03-1    P1790   节气门开度(TP)传感器故障
04-1    P1791   车速传感器(VSS)信号故障
04-2    P0501   车速传感器(VSS)信号故障
04-3    P0502   车速传感器没有信号
04-5    P0501   车速传感器性能
05-1    P1705   A/T档位开关齿轮档位短路
05-2    P0705   档位开关电路短路故障
06-1    P1706   A/T档位开关断路
06-2    P0706   档位开关电路断路故障
07-1    P0753   换档电磁阀A故障
07-3    P0973   换档电磁阀A输入过低
07-4    P0974   换档电磁阀A输入过高
08-1    P0758   换档电磁阀B故障
08-3    P0976   换档电磁阀B输入过低
08-4    P0977   换档电磁阀B输入过高
09-1    P0720   输出轴(副轴)速度传感器故障
09-3    P0722   输出轴(副轴)速度传感器无信号
09-5    P0721   输出轴(副轴)速度传感器性能
09-6    P0723   输出轴(副轴)速度传感器间断
10-1    P1792   发动机冷却液温度(ECT)传感器故障
11-1    P0725   发动机转速信号故障
12-1    P1793   进气歧管绝对压力(MAP)传感器故障
13-1    P1794   BARO(大气压力)传感器故障
14-1    P1786   FAS信号故障
15-1    P0715   输入轴(主轴)速度传感器故障
15-3    P0717   输入轴(主轴)速度传感器无信号
15-5    P0716   输入轴(主轴)速度传感器性能
15-6    P0718   输入轴(主轴)速度传感器间
16-1    P1768   离合器压力控制(线性)电磁阀A故障
16-2    P0748   离合器压力控制电磁阀A故障
16-3    P0962   离合器压力控制电磁阀A输入过低
16-4    P0963   离合器压力控制电磁阀A输入过高
17-1    P1725   低速档开关故障
18-1    P1787   FFS信号故障
19-1    P1788   ATSDLA信号故障
20-1    P1795   AP传感器故障
21-1    p1713   D3档位开关故障
22-1    p0763   换档电磁阀C故障
22-3    P0979   换档电磁阀C输入过低
22-4    P0980   换档电磁阀C输入过高
23-1    P1773   离合器压力控制(线性)电磁阀B故障
23-2    P0778   离合器压力控制电磁阀B故障
23-3    P0966   离合器压力控制电磁阀B输入过低
23-4    P0967   离合器压力控制电磁阀B输入过高
24-1    P1709   模式开关故障
24-3    P0957   模式开关电路过低
24-4    P0958   模式开关电路过高
24-5    P0815   升档开关故障
24-6    P0816   降档开关故障
25-1    P1738   2档压力开关故障
25-2    P0840   2档压力开关故障
25-3    P0842   2档压力开关电路低
25-4    P0843   2档压力开关电路高
26-1    P1739   3档压力开关故障
26-2    P0845   3档压力开关故障
26-3    P0847   3档压力开关电路低
26-4    P0848   3档压力开关电路高
27-1    P1740   4档压力开关故障
27-3    P0872   4档压力开关电路低
27-4    P0873   4档压力开关电路高
28-1    P0710   ATF温度传感器故障
28-3    P0712   ATF温度传感器输入过低
28-4    P0713   ATF温度传感器输入过高
28-5    P0711   ATF温度传感器性能
29-1    P1778   离合器压力控制(线性)电磁阀C故障
29-2    P0798   离合器压力控制(线性)电磁阀C故障
29-3    P0970   离合器压力控制电磁阀C输入过低
29-4    P0971   离合器压力控制电磁阀C输入过高
RECE:45H,05H,74H,01H,41H,       读历史码命令
SEND:05H,0cH,74H,01H,00H,
        00H,00H,                故障码1
        00H,00H,                故障码2
        00H,00H,                故障码3
        7aH,
RECE:45H,07H,72H,b1H,00H,20H,71H,
SEND:05H,26H,72H,b1H,00H,00H,00H,80H,80H,80H,80H,82H,82H,80H,80H,82H,82H,82H,82H,80H,80H,80H,80H,00H,00H,00H,00H,00H,00H,00H,00H,00H,00H,00H,00H,00H,00H,a6H,
RECE:45H,07H,72H,b2H,00H,20H,70H,
SEND:05H,26H,72H,b2H,00H,80H,80H,80H,80H,80H,80H,00H,00H,00H,00H,00H,00H,80H,80H,80H,80H,00H,00H,82H,82H,82H,80H,00H,80H,80H,00H,00H,00H,00H,00H,00H,00H,abH,
RECE:45H,07H,72H,b3H,00H,20H,6fH,
SEND:05H,26H,72H,b3H,00H,00H,00H,00H,80H,00H,00H,00H,00H,00H,00H,00H,00H,80H,80H,80H,80H,00H,00H,00H,80H,00H,00H,80H,80H,80H,80H,80H,00H,00H,00H,00H,00H,30H,
RECE:45H,07H,72H,b4H,00H,20H,6eH,
SEND:05H,26H,72H,b4H,00H,80H,80H,80H,80H,80H,00H,00H,00H,00H,00H,00H,00H,00H,00H,00H,00H,00H,00H,00H,00H,00H,00H,00H,00H,00H,00H,00H,00H,00H,00H,00H,00H,2fH,
RECE:45H,05H,71H,00H,45H,
SEND:05H,0aH,71H,00H,02H,03H,00H,0fH,08H,64H,
清码:
00H,
RECE:45H,07H,72H,12H,09H,01H,26H,
SEND:05H,07H,72H,12H,09H,01H,66H,
SEND:05H,07H,72H,12H,00H,00H,70H,
RECE:45H,07H,72H,22H,06H,01H,19H,
SEND:05S,07S,72S,22S,06S,00S,5aS,
RECE:8cH,05H,01H,10H,5eH,               清码命令
SEND:0cS,05S,01S,20S,ceS,
SEND:0eS,03S,efS,
数据流:
00  发动机转速(RPM)     45H,07H,72H,12H,00H,14H,1cH,    DATA5~00[X00]*12750/255
01  发动机转速2(RPM)    45H,07H,72H,12H,00H,14H,1cH,    DATA19DATA20~00[X00Y01]
02  副轴转速(KM/H)      45H,07H,72H,12H,00H,14H,1cH,    DATA6~00[X00]
03  副轴转速rpm(RPM)    45H,07H,72H,12H,00H,14H,1cH,    DATA21DATA22~00[X00Y01]
04  主轴转速(KM/H)      45H,07H,72H,12H,00H,14H,1cH,    DATA7~00[X00]
05  主轴转速rpm(RPM)    45H,07H,72H,12H,00H,14H,1cH,    DATA23DATA24~00[X00Y01]
06  TP传感器(')         45H,07H,72H,12H,00H,14H,1cH,    DATA8~00[X00]*90/255
07  相对TP传感器(')     45H,07H,72H,12H,00H,14H,1cH,    DATA9~00[X00]*90/255
08  ECT传感器('C)       45H,07H,72H,12H,00H,14H,1cH,    DATA11~00[X00]-40
09  电磁阀电源(V)       45H,07H,72H,12H,00H,14H,1cH,    DATA12~01[X00]/10
0A  排档控制            45H,07H,72H,12H,00H,14H,1cH,    DATA13~19X00&FF=00:N;&FF=01:1档;&FF=02:2档;&FF=03:3档;&FF=04:4档;&FF=05:5档;&FF=06:未定义;&FF=0F:R;UNDEFINED
0B  SCS                 45H,07H,72H,12H,00H,14H,1cH,    DATA14~12X00&08=08:短;不能关闭
0C  制动开关            45H,07H,72H,12H,00H,14H,1cH,    DATA14~12X00&10=10:打开;关闭
0D  D4/D5/D档指示器     45H,07H,72H,12H,00H,14H,1cH,    DATA14~12X00&40=40:打开;关闭
0E  MAP传感器(Kpa)      45H,07H,72H,12H,00H,14H,1cH,    DATA16~00[X00]
0F  大气压力传感器(Kpa) 45H,07H,72H,12H,00H,14H,1cH,    DATA18~00[X00]
10  A/T C.P.C.电磁阀A指令(A)    45H,07H,72H,22H,00H,0aH,16H,    DATA5~02[X00]*1.27/255
11  A/T C.P.C.电磁阀A实际(A)    45H,07H,72H,22H,00H,0aH,16H,    DATA6~02[X00]*1.27/255
12  A/T C.P.C.电磁阀B指令(A)    45H,07H,72H,22H,00H,0aH,16H,    DATA7~02[X00]*1.27/255
13  A/T C.P.C.电磁阀B实际(A)    45H,07H,72H,22H,00H,0aH,16H,    DATA8~02[X00]*1.27/255
14  A/T C.P.C.电磁阀C指令(A)    45H,07H,72H,22H,00H,0aH,16H,    DATA9~02[X00]*1.27/255
15  A/T C.P.C.电磁阀C实际(A)    45H,07H,72H,22H,00H,0aH,16H,    DATA10~02[X00]*1.27/255
16  车速传感器(KM/H)    45H,07H,72H,22H,00H,0aH,16H,    DATA11~00[X00]
17  A/T换档电磁阀A      45H,07H,72H,22H,00H,0aH,16H,    DATA12~12X00&01=01:打开;关闭
18  A/T换档电磁阀B      45H,07H,72H,22H,00H,0aH,16H,    DATA12~12X00&02=02:打开;关闭
19  A/T换档电磁阀C      45H,07H,72H,22H,00H,0aH,16H,    DATA12~12X00&04=04:打开;关闭
1A  A/T换档电磁阀D      45H,07H,72H,22H,00H,0aH,16H,    DATA12~12X00&08=08:打开;关闭
1B  A/T换档电磁阀E      45H,07H,72H,22H,00H,0aH,16H,    DATA12~12X00&10=10:打开;关闭
1C  ATF温度传感器('C)   45H,07H,72H,22H,00H,0aH,16H,    DATA14~00[X00]-40
1D  驱动档              45H,07H,72H,12H,00H,14H,1cH,    DATA14~12X00&04=04:打开;关闭
1E  A/T P/N档位开关     45H,07H,72H,12H,00H,14H,1cH,    DATA14~12X00&01=01:打开;关闭
1F  A/T R档开关         45H,07H,72H,12H,00H,14H,1cH,    DATA14~12X00&02=02:打开;关闭
20  A/T N档开关         45H,07H,72H,b5H,00H,0aH,83H,    DATA5~12X00&04=04:打开;关闭
21  A/T D3档位开关      45H,07H,72H,b5H,00H,0aH,83H,    DATA5~12X00&20=20:打开;关闭
22  A/T 2档开关         45H,07H,72H,b5H,00H,0aH,83H,    DATA5~12X00&40=40:打开;关闭
23  A/T 1档开关         45H,07H,72H,b5H,00H,0aH,83H,    DATA5~12X00&80=80:打开;关闭
24  前进开关            45H,07H,72H,b5H,00H,0aH,83H,    DATA6~12X00&01=01:打开;关闭
25  A/T P档开关         45H,07H,72H,b5H,00H,0aH,83H,    DATA6~12X00&02=02:打开;关闭
26  倒档开关            45H,07H,72H,b5H,00H,0aH,83H,    DATA6~12X00&04=04:打开;关闭
27  A/T D档开关         45H,07H,72H,b5H,00H,0aH,83H,    DATA6~12X00&08=08:打开;关闭
28  A/T 2-1开关         45H,07H,72H,b5H,00H,0aH,83H,    DATA6~12X00&10=10:打开;关闭
29  P档指示器           45H,07H,72H,b5H,00H,0aH,83H,    DATA11~12X00&01=01:打开;关闭
2A  R档指示器           45H,07H,72H,b5H,00H,0aH,83H,    DATA11~12X00&02=02:打开;关闭
2B  N档指示器           45H,07H,72H,b5H,00H,0aH,83H,    DATA11~12X00&04=04:打开;关闭
2C  D3档指示器          45H,07H,72H,b5H,00H,0aH,83H,    DATA11~12X00&20=20:打开;关闭
2D  2档指示器           45H,07H,72H,b5H,00H,0aH,83H,    DATA11~12X00&40=40:打开;关闭
2E  1档指示器           45H,07H,72H,b5H,00H,0aH,83H,    DATA11~12X00&80=80:打开;关闭
2F  D档指示器           45H,07H,72H,b5H,00H,0aH,83H,    DATA14~12X00&01=01:打开;关闭
30  排档位置图号        45H,07H,72H,b5H,00H,0aH,83H,    DATA9~00[X00]
31  排档锁定电磁阀      45H,07H,72H,b5H,00H,0aH,83H,    DATA10~12X00&01=01:打开;关闭
32  A/C离合器           45H,07H,72H,b5H,00H,0aH,83H,    DATA10~12X00&02=02:打开;关闭
33  定速巡航控制        45H,07H,72H,b5H,00H,0aH,83H,    DATA12~12X00&01=01:打开;关闭
34  降档请求1           45H,07H,72H,b5H,00H,0aH,83H,    DATA12~12X00&02=02:打开;关闭
35  降档请求2           45H,07H,72H,b5H,00H,0aH,83H,    DATA12~12X00&04=04:打开;关闭
36  2档压力开关         45H,07H,72H,b5H,00H,0aH,83H,    DATA13~12X00&02=02:打开;关闭
37  3档压力开关         45H,07H,72H,b5H,00H,0aH,83H,    DATA13~12X00&04=04;打开;关闭
38  DFT(动态功能测试)监控器     45H,07H,72H,b6H,00H,07H,85H,    DATA5~00[X00]
39  DFT(动态功能测试)故障代码   45H,07H,72H,b6H,00H,07H,85H,    DATA6~00[X00]
3A  DFT(动态功能测试)结果       45H,07H,72H,b6H,00H,07H,85H,    DATA7~00[X00]
3B  SFT(单一功能测试)故障代码   45H,07H,72H,b6H,00H,07H,85H,    DATA9~00[X00]
3C  里程表(KM)                  45H,07H,72H,b6H,00H,07H,85H,    DATA10DATA11~00[X00Y01]
PCM/TCM重新设置:
00H,
SEND:05H,07H,72H,22H,06H,00H,5aH,
RECE:8cH,05H,01H,20H,4eH,               重新设置命令
SEND:0cH,05H,01H,20H,ceH,
SEND:05H,0cH,73H,01H,00H,00H,00H,00H,00H,00H,00H,7bH,
SEND:0eH,03H,efH,
动作测试:
1.换档电磁阀A
        按'确定'后出现一界面"测试条件: 停止车辆;排入'P'档;发动机熄火;"
        按'确定'后发命令:
        00H,
        SEND:05S,0aS,71S,00S,02S,03S,00S,0fS,08S,64S,
        RECE:45H,05H,73H,01H,42H,       检测有无当前故障码,有则不能测试
        SEND:05S,07S,72S,12S,00S,00S,70S,       若DATA5不为0则表示有RPM信号,发动机先熄火,不能测试
        SEND:05S,07S,72S,22S,06S,00S,5aS,       若DATA5不为0则表示有车速信号,先停止车辆,不能测试
        SEND:05S,07S,72S,12S,09S,01S,66S,       若DATA5不为1则表示档位开关没有在P档,不能测试
        并显示一界面"听电磁阀的动作声,最多需要20秒"
        按'确定'后发命令:
        RECE:43H,04H,00H,b9H,
        SEND:03S,04S,00S,f9S,
        RECE:45H,07H,72H,e0H,03H,01H,5eH,
        SEND:05S,06S,72S,e0S,03S,a0S,
        RECE:43H,04H,00H,b9H,           关闭电磁阀
        RECE:43H,04H,80H,39H,           打开电磁阀
        SEND:03S,04S,80S,79S,
        RECE:42H,03H,bbH,
        SEND:02S,03S,fbS,
        SEND:0eS,03S,efS,
2.换档电磁阀B
        RECE:43H,04H,01H,b8H,           关闭电磁阀
        SEND:03H,04H,01H,f8H,
        RECE:43H,04H,81H,38H,           打开电磁阀
        SEND:03H,04H,81H,78H,
        其余通讯过程同上
3.换档电磁阀C
        RECE:43H,04H,05H,b4H,           关闭电磁阀
        SEND:03H,04H,05H,f4H,
        RECE:43H,04H,85H,34H,           打开电磁阀
        SEND:03H,04H,85H,74H,
        其余通讯过程同上
4.换档电磁阀D
        RECE:43H,04H,08H,b1H,           关闭电磁阀
        SEND:03H,04H,08H,f1H,
        RECE:43H,04H,88H,31H,           打开电磁阀
        SEND:03H,04H,88H,71H,
        其余通讯过程同上
5.换档电磁阀E
        RECE:43H,04H,09H,b0H,           关闭电磁阀
        SEND:03H,04H,09H,f0H,
        RECE:43H,04H,89H,30H,           打开电磁阀
        SEND:03H,04H,89H,70H,
        其余通讯过程同上
2.4AT.TXT
16.36 KB, 下载次数: 5, 下载积分: 积分 -1
发表于 3-11-2009 21:35:57 | 显示全部楼层
这些都是具体的变速器型号的
发表于 24-11-2009 17:22:04 | 显示全部楼层
请教
本田CRV的变速器哪产的,怎么电磁阀在壳体外啊,
我见的比较少,都是在阀体里的,
有学长师父能给讲解一下么
发表于 5-4-2010 19:31:43 | 显示全部楼层
电控果然不是闹着玩的
GMT+8, 23-3-2026 20:20 , Processed in 0.290373 second(s), 39 queries .
