  • 1994查看
COSMOSFloWorks教程(中英双解AMA版).pdf
发表于 9-9-2009 22:39:31 | 显示全部楼层 |阅读模式
COSMOSFloWorks教程(中英双解AMA版).pdf (753 KB, 下载次数: 5)
模型描述
This is a ball valve. Turning the handle closes or opens the valve.
The local hydraulic loss (or resistance) produced by a ball valve installed in a piping system depends on the valve design dimensions and on the handle turning angle. The ball-to-pipe diameter ratio governs the handle turning angle at which the valve becomes closed.
这是一个球阀门。手柄关闭或打开阀门。安装于一个管道系统中的一个球阀门生产的液压的损失(或者主力)取决于阀门设计尺度和手柄的旋转角度。圆管子直径比率控制阀门关闭的旋转角度。
GMT+8, 31-5-2026 07:07 , Processed in 0.418426 second(s), 36 queries .
