  • 1485查看
说NVH,不过本人一直在想,其中文到底该怎么表述比较确切?
发表于 29-9-2009 09:57:51 | 显示全部楼层 |阅读模式
大家一直在说NVH,不过本人一直在想,其中文到底该怎么表述比较确切?特别是H的准确研究内容与含义。请教大家。
发表于 5-10-2009 14:30:31 | 显示全部楼层
h是舒适性 这样理解会好一些
发表于 5-10-2009 16:09:12 | 显示全部楼层
英文版
Lesson Three
Automobile Noise and Vibration
汽車噪音與振動
I.  Context
A student is curious about automobile noise and vibration problems.  His teacher explains how to diagnose them.
II.  Dialogue
Teacher:        Today, we are discussing automobile noise and vibration.  We hear about NVH very often.  What does it stand for?
Student:        I guess N and V denote “Noise” and “Vibration”, respectively.  I don’t know what H means.
Teacher:         H is the abbreviation of “Harshness”, which is composed of an impact noise and vibration generated when tires are crossing a ramp or a crack.
Student:         Can you tell me how to troubleshoot automobile noise and vibration problems?
Teacher:        First, you need to understand the diagnosis procedure.
Student:        Could you explain it briefly?
Teacher:        First of all, listen and write down customers’ complaints carefully.  Then, judge the possible areas of the malfunction from the complaints.  After that, do test drive.  Finally, choose a suitable diagnosis method.
Student:        What should I be careful about during a test drive?
Teacher:        Pay special attention to vehicle speed, engine rpm and shift gear position of the transmission.
Student:        There are many diagnosis methods.  Can you name some of them?
Teacher:         The most common methods are the auscultation method, the change-load method, sticking tape to the suspected chink, as well as squeezing and shaking the suspected area.  OK, now its my turn to ask you some questions.
Student:        Please.
Teacher:        What is the unit for noise?
Student:        Decibels (dB).
Teacher:        Correct.  If one noise has a sound level
        of 60 decibels and another is 70, do these two noises together
        have the strength of 130 decibels?
Student:        Of course not.  If decibels could be added directly, then there would be so much noise in the environment, and our ear drums would break.
Teacher:        Good.  Could you give some examples of automobile noise and vibration?
Student:        Engine noise, tire noise, wind noise, exhaust noise, and steering wheel shake, etc.
Teacher:        Terrific.
Student:        Today, I have learned some basic knowledge about diagnosis of automobile noise and vibration problems.  Thank you.
III.  Vocabulary and Terminology
1.         vibration (n.) 振動
        The vibration of the car was making me sick.
          車子的振動讓我感覺不舒服。
Newr shock absorbers can reduce vibration of the vehicle.
新避震器能降低汽車的振動。
2.         troubleshoot (v.) 排除
It is important to learn how to troubleshoot problems.
        學習如何排除問題是很重要的。
3.         diagnosis (n.) 診斷
Doctors have to be careful with their diagnosis.
          醫生必須小心的診斷。
IV.  Sentence Patterns
1.         Of course not …當然不是
   Of course not, if lizards were mammals they would not lay eggs.
   當然不是,如果蜥蜴是哺乳類動物牠們就不會下蛋。
2.         Today, … 今天…
   Toady, I went to the zoo and saw many animals.
          今天我去動物園並看了許多動物。
清雅轩 + 3 热心人士【论坛口号→知无不言,言无不尽】
发表于 9-10-2009 18:14:14 | 显示全部楼层
震动噪声
发表于 13-10-2009 19:26:40 | 显示全部楼层
声震舒适性比较合适
GMT+8, 27-4-2026 10:25 , Processed in 0.591906 second(s), 40 queries .
