restroom 1号厂房工艺布置方案图 proposal of the Plant I layout 合笼 mate 底盘平移台 chassis shuttle 车辆转移台 bus transfer 前围角板 front wall angle cover 后围侧板 rear wall side cover 保险杠 bumper 三类底盘 three type chassis 左侧围应力蒙皮 R/S stretching skin (road side) 中涂 floating coat 拼装台 collector 切割轮口 wheel -arch cutting 内饰 trim 线束 harness 返工 re-doing 轮罩护板 wheel house 发车前准备 pre-delivery 举升 hoist 小批量产品 be pilot 2 套 two kits 配电站 power transformer substation 裙板 skirt 发动机托架 engine holding frame 诊断报警系统 diagnosis and alarming system 互换性 interchangeability 缩微图纸 microfiche files 总装 final assembly 磷化 phosphating 仪表板 dash board 切齐 trimming 结构完整性 structure integrity 自动愈合的防腐材料 self-healing corrosion preventative material 长途客车 inter-city bus 改装厂 refitting factory 遮阳板 sun visor 随车工具 tool box 钢化玻璃 toughened grass 异形钢管 special steel pipe 全天候空调系统 full range A/C 强制通风 ram-air ventilation 停机时间 downtime 无公害柴油 clean diesel 宽敞悬臂式座椅 roomy cantilevered seat 防滑地板 no-skid floor 织物纹里铝合金 textured aluminum extrution 爬坡能力 grade ability 排水阀 drain valve 除湿器 moisture ejector 怠速时 at idle 琴式驱动桥 banjo type drive axle 通风口 duct 恒温控制 thermostatic control 平衡水箱 surge tank 变光开关 simmer switch 消音器 muffler 防破坏 vandal resistant 聚碳化透镜 poly-carbonate len 镀锌板 galvanized plate 搭接 lap 亮丽的外表 smart apperance 隐藏式固定 concealed fastening 水洼 ponding 发动机中置式客车 bus with under floor engine 组合式客车车身 modular bus body 薄壳式结构 shell construction 衬垫 pad 空气导流板 air deflector 搁梁 shelf beam 腰梁 waist rail 梭梁 stabilizing beam 腰带式安全带 diagonal safety belt 压条 trim strip 嵌条 insertion strip 翼板 fender 斜撑 bracing piece 转向盘回正性试验test of steering wheel returnability转向盘转角脉冲试验steering wheel impulse input test转向盘转角阶跃输入试验steering wheel step input or transient state yaw response test极限侧向加速度试验limiting lateral acceleration test汽车平顺性随机输入行驶试验automobile ride random input running test汽车平顺性单脉冲输入行驶试验automobile ride single pulse input running test汽车悬挂系统固有频率与阻尼比的测定试验measurement of natural frequency and damping raito of suspension功率突然变化影响试验test of effect of sudden power change收油门后控制试验test of control at breakway横风稳定性试验test of crosswind stability反冲试验kick-back test轮胎爆破响应时间试验test of burst response of tyre绕过障碍物试验obstacle avoidance test移线试验lane change testJ型转弯试验test of J turn频率响应时间试验frequency response test瞬态响应时间试验transient response test阶路响应时间试验step response test脉冲响应试验pulse response test静态操舵力试验static steering effort test悬架举升试验jack-up test of suspension耐翻倾试验test of overturning immunity轮辋错动试验rim slip test风洞试验wind tunnel test制动稳定性试验test of braking stability最小转弯直径试验minimum turning diameter test操舵力试验steering effort test汽车发动机
类型type发动机engine内燃机intenal combusiton engine动力机装置power unit汽油机gasoline engine汽油喷射式汽油机gasoline-injection engine火花点火式发动机spark ignition engine压燃式发动机compression ignition engine往复式内燃机reciprocating internal combustion engine化油器式发动机carburetor engine柴油机diesel engine转子发动机rotary engine旋轮线转子发动机rotary trochoidal engine二冲程发动机two-stroke engine四冲程发动机four-stroke engine直接喷射式柴油机direct injection engine间接喷射式柴油机indirect injection engine增压式发动机supercharged engine风冷式发动机air-cooled engine油冷式发动机oil-cooled engine水冷式发动机water-cooled engine自然进气式发动机naturally aspirated engine煤气机gas engine液化石油气发动机liquified petroleum gas engine柴油煤气机diesel gas engine多种燃料发动机multifuel engine石油发动机hydrocarbon engine双燃料发动机duel fuel engine热球式发动机hot bulb engine多气缸发动机multiple cylinder engine对置活塞发动机opposed piston engine对置气缸式发动机opposed-cylinder engine十字头型发动机cross head engine直列式发动机in-line engine星型发动机radial engine筒状活塞发动机trunk-piston engine斯特林发动机stirling engine套阀式发动机knight engine气孔扫气式发动机port-scavenged engine倾斜式发动机slant engine前置式发动机front-engine后置式发动机rear-engine中置式发动机central engine左侧发动机left-hand engine右侧发动机right-hand engine短冲程发动机oversquare engine长冲程发动机undersquare engine等径程发动机square engine顶置凸轮轴发动机overhead camshaft engine双顶置凸轮轴发动机dual overhead camshaft engineV形发动机V-engine顶置气门发动机valve in-head engine侧置气门发动机side valve engine无气门发动机valveless engine多气门发动机multi-valve engine卧式发动机horizontal engine斜置式发动机inclined engine立式发动机vertical engineW形发动机w-engineI形发动机I-engineL形发动机L-engineF形发动机F-engine性能performance二冲程循环two-stroke cycle四冲程循环four-stroke cycle狄塞尔循环diesel cycle奥托循环otto cycle混合循环mixed cycle定容循环constant volume cycle工作循环workingcycle等压循环constant pressure cycle理想循环ideal cycle热力循环thermodynamic cycle冲程stroke活塞行程piston stroke长行程long stroke上行程up stroke下行程down stroke进气行程intake stroke充气行程charging stroke压缩行程compression stroke爆炸行程explosion stroke膨胀行程expansion stroke动力行程power stroke排气行程exhaust stroke膨胀换气行程expansion-exchange stroke换气压缩行程exchange-compression stroke止点dead center上止点top dead center(upper dead center)下止点lower dead center(bottom dead center)上止点前budc(before upper dead center)上止点后atdc(after top dead cetner)下止点前bbdc(before bottom dead center)下止点后abdc(after bottom dead center)缸径cylinder bore缸径与行程bore and stroke空气室energy chamber气缸余隙容积cylinder clearance volume燃烧室容积combustion chamber volume气缸最大容积maximum cylinder volume压缩室compression chamber排气量displacement发动机排量engine displacement活塞排量piston swept volume气缸容量cylinder capacity单室容量single-chamber capacity容积法volumetry压缩比compression ratio临界压缩比critical compression ratio膨胀比expansion ratio面容比surface to volume ratio行程缸径比stroke-bore ratio混合比mixture ratio压缩压力compression pressure制动平均有效压力brake mean effective pressure(bmep)空燃比air fuel ratio燃空比fuel air ratio燃料当量比fuel equivalence ratio扭矩torque单缸功率power per cylinder升功率power per liter升扭矩torque per liter升质量mass per liter 减额功率derating power输出马力shaft horsepower马力小时,马力时horsepower-hour总马力gross horse power总功率gross power 净功率net power 燃油消耗量fuel consumption 比燃料消耗率specific fuel consumption空气消耗率air consumption机油消耗量oil consumption有效马力net horse power额定马力rated horse power马力重量系数horsepower-weight factor制动功率brake horse power制动热效率brake thermal efficiency 总效率overall efficiency排烟极限功率smoke limiting horsepower功率曲线power curve机械损失mechanical loss机械效率mechanical efficiency有效热效率effective thermal efficiency充气系数volumetric efficiency过量空气系数coefficient of excess air适应性系数adaptive coefficient扭矩适应性系数coefficient of torque adaptibility转速适应性系数speed adaptive coefficient强化系数coefficient of intensification校正系数correction factor换算系数conversion factor活塞平均速度mean piston speed发动机转速engine speed (rotational frequency)怠速转速idling speed经济转速economic speed起动转速starting speed最低稳定工作转速lowest continuous speed with load最大扭矩转速speed at maximum torque最高空转转速maximum no load governed speed调速speed governing 超速overspeed怠速idling转速波动率speed fluctuation rate工况working condition(operating mode)额定工况declared working condition变工况variable working condition稳定工况steady working condition空载no-load全负荷full load超负荷overload部分负荷part load充量(进气)charge旋转方向direction of rotation顺时针clockwise逆时针counter-clockwise左转left-hand rotation右转right-hand rotation外径major diameter中径pitch diameter内径minor diameter径向间隙radial clearance发动机性能engine performance加载性能loading performance起动性能starting performance加速性能acceleration performance动力性能power performance排放性能emission performance空转特性no load characteristics负荷特性part throttle characteristics调速特性governor control characteristics万有特性mapping characteristics稳定调速率steady state speed governing rate气缸体和气缸盖cylinder block and head气缸体cylinder block整体铸造cast inblock (cast enblock)发动机罩engine bonnet气缸体加强筋engine block stiffening rib气缸cylinder(转子机)缸体stator缸径cylinder bore气缸体机架cylinder block frame气缸盖cylinder head配气机构箱valve mechanism casing气缸体隔片cylinder spacer气缸盖密封环cylinder head ring gasket气缸盖垫片cylinder head gasket气缸套cylinder liner(cylinder sleeve)干式缸套dry cylinder liner湿式缸套wet cylinder liner气缸水套water jacket膨胀塞expansion plug防冻塞freeze plug气缸壁cylinder wall环脊ring ridge排气口exhaust port中间隔板intermediate bottum导板guideway创成半径(转子机)generating radius缸体宽度(转子机)operating width机柱column燃烧室combustion chamber主燃烧室main combustion chamber副燃烧室subsidiary combustion chamber预燃室prechamber涡流燃烧室`swirl combustion chamber分开式燃烧室divided combustion chamber涡流式燃烧室turbulence combustion chamber半球形燃烧室hemispherical combustion chamber浴盆形燃烧室bathtub section combustion chamberL形燃烧室L-combustion chamber楔形燃烧室wedge-section combustion chamber开式燃烧室open combustion chamber封闭喷射室closed spray chamber活塞顶内燃烧室piston chamber爆发室explosion chamber燃烧室容积比volume ratio of combustion cahmber燃烧室口径比surface-volume ratio of combustion chamber通道面积比area ratio of combustion chamber passage曲轴箱通气口crankcase breather凸轮轴轴承座camshaft bearing bush seat定时齿轮室罩camshaft drive(gear)cover曲轴箱检查孔盖crankcase door曲轴箱防爆门crankcase explosion proof door主轴承盖main bearing cap气缸盖罩valve mechanism cover飞轮壳flywheel cover扫气储器scavenging air receiver活塞piston裙部开槽活塞split skirt pistonU形槽活塞U-slot piston滚花修复活塞knurled piston圆顶活塞dome head piston平顶活塞flat head piston凸顶活塞crown head piston(convex head piston)凹顶活塞concave head piston阶梯顶活塞step-head piston筒形活塞trunk piston椭圆形活塞oval piston抗热变形活塞autothermic piston不变间隙活塞constant clearance piston镶因瓦钢片活塞invar strut piston直接冷却式活塞direct-cooled piston间接冷却式活塞indirect cooled piston滑裙活塞slipper piston活塞速度piston speed活塞顶部piston head活塞裙部piston skirt整体活塞裙solid skirt活塞裙扩大衬簧piston skirt expander滑履式活塞裙slipper skirt隔热槽heat dam活塞标记piston mark活塞销piston pin活塞销孔piston pin boss活塞销衬套piston pin bushing全浮式活塞销full-floating piston pin半浮式活塞销semifloating piston pin固定螺钉式活塞销set screw piston pin活塞环piston ring组合式活塞环compound piston ring同心活塞环concentric piston ring偏心活塞环eccentric piston ring自由环free ring闭合环closed ring梯形环keystone ring半梯形环half keystone ring矩形环rectangular ring油环oil control ring开槽油环slotted oil control ring螺旋弹簧加载双坡口油环coil spring loaded slotted oil control ring 涨环expander双坡口油环double bevelled oil control ring内上坡口internal bevel top内下坡口internal bevel bottom边缘坡口油环bevelled-ege oil control ring刮油环scrapper ring钩形环napier ring镀铬活塞环chrome plated piston ring活塞衬环piston ring expander活塞环槽piston ring groove活塞环区ring zone活塞环岸piston ring land活塞环内表面back of ring曲柄连杆机构connecting rod中心曲柄连杆机构central-located connecting rod偏心曲柄连杆机构offset connecting rod铰接曲柄边杆机构hinged connecting rod连杆connecting rod连杆小头connecting rod small end连杆大头connnecting rod big end连杆杆身connecting rod shank副连杆slave connecting rod叉形连杆fork-and-blade connecting rod主连杆main connecting rod方形连杆boxed rod绞链式连杆hinged type connecting rod活节式连杆articulated connecting rod连杆盖connecting rod cap连杆轴承connecting rod bearing曲轴crankshaft整体式曲轴one-piece crankshaft组合式曲轴assembled crankshaft右侧曲轴right-hand crankshaft左侧曲轴left-hand crankshaft改变行程的曲轴stroked crankshaft曲轴前端crankshaft front end曲轴主轴颈crankshaft main journal 轴颈重叠度shaft journal overlap圆角fillet主轴承main bearing曲轴止推轴承crankshaft thrust bearing薄臂轴瓦thin wall bearing shell曲轴油道crankshaft oil passage曲柄crank曲柄臂crank arm曲柄销crank pin轴套bush曲柄转角crank angle曲柄半径crank radius抛油圈oil slander角度轮degree wheel 动平衡机dynamic balancer平衡重balancer weight扭振减振器torshional vibration damper扭振平衡器torsion balancer谐振平衡器harmonic balancer振动平衡器vibration balancer曲轴链轮crankshaft sprocket转子轴颈rotor journal 偏心轴eccentric shaft曲轴箱crankcase闭式曲轴箱通风装置closed-crankcase ventilating system飞轮flywheel飞轮齿圈flywheel ring gear飞轮芯棒cantilever飞轮芯轴flywheel spindle飞轮的惯量矩flywheel moment of inertia飞轮标记flywheel mark当量系统equivalent system当量轴长equivalent shaft length一级往复惯性力reciprocating inertia force,1st order二级往复贯性力reciprocating inertia force, 2nd order离心惯性力centrifugal inertia force配气机构valve gear凸轮轴camshaft凸轮cam整体式凸轮轴one-piece camshaft组合式凸轮轴assembled camshaft凸轮轴驱动机构camshaft drive赛车用凸轮轴race camshaft凸轮轴轴颈camshaft bearing journal凸轮轴轴承camshaft bearing 凸轮轴偏心轮camshaft eccentric凸轮轴链轮camshaft sprocket凸轮轴正时齿轮camshaft timing gear凸轮轴齿轮camshaft gear wheel 进口凸轮inlet cam排气凸轮 exhaust cam快升凸轮quick lift cam快升缓降凸轮quick lift gradual clsing cam凸轮轮廓cam contour凸轮包角cam angle凸轮升程cam-lobe lift凸轮尖cam nose凸轮从动件cam follower
齿轮传动机构gear drive正时齿轮timing gear链传动机构chain drive链轮sprocket wheel 链轮盘chain sprocket正时链条timing chain带齿皮带toothed timing belt链条张紧轮chain tension gear半速齿轮half speed gear正时齿轮刻印记号timing gear punch mark气门valve进气过程intake process换气过程gas exchange process扫气过程scavenging process给气比delivery ratio分层充气stratified charge充量系数volumetric efficiency涡流比swirl rate进气涡流intake swirl螺旋进气道进气helical duct intake导流屏式气门进气masked valve intake切向进气道进气tangential duct intake进气紊流intake trubulence进气提前角intake advance angle进气持续角intake duration angle进气迟后角intake lag angle进面值time-area value气门升程valve lift气门正时valve timing扫气口面积scavenging port area菌形气门mashroom valve, poppet valve钠冷却气门sodium filled valve(natrium cooled valve)双气门dual valve进气门intake valve (suction valve,inlet valve)排气门exhaust valve顶置气门overhead valve侧置气门side valve倾斜气门inclined overhead valve直立气门vertical overhead valve套筒式滑阀sleeve valve气门机构valve gear直接式气门驱动机构direct valve gear间接式气门驱动机构indirect valve gear气门杆valve stem加大气门杆oversize valve stem气门头valve head气门工作面valve face气门边限valve margin气门弹簧座valve-spring retainer气门锁片valve key气门间隙调节螺钉valve lash adjusting screw气门旋转器valve rotator气门室valve cage气门油封valve oil seal气门口valve port气门座valve seat气门座镶圈(嵌镶式气门座圈)valve seat insert(valve seat ring)气门座锥角valve seat angle气门座宽度valve seat width气门挺杆valve tappet(valve lifter)液力挺杆hydraulic tappet(lifter)无间隙挺杆zero-rush tappet (non-clearance tappet)筒形挺杆barrel type tappet油压挺杆ooil tappet滚轮挺杆roller tappet(lifter)挺杆转位tappet rotation 排气门挺杆exhaust valve lifter气门导管valve guide气门杆导管stem guide气门重叠度stem overlap气门开启持续时间valve duration 气门正时标记valve timing sign气门弹簧valve spring气门内弹簧inner valve spring气门外弹簧outer valve spring刚性缓冲弹簧stiff buffer spring上紧弹簧energizing spring防振气门弹簧non-surging spring弹簧座圈spring retainer蝶形弹簧belleville spring滚柱roller 气门室盖valve chamber cover摇臂rocker arm高升程摇臂high lift rocker arm摇臂轴rocker arm shaft推杆push-rod摇臂支架rocker arm bracket气门摇臂室罩valve rocker chamber cover导向轮guide wheel 导杆slide bar导轨slide rail张紧轮tensioning wheel链条张紧调节装置assembly chain tension adjuster张紧带轮tensioning pulley传动带张紧装置belt tensioner同步驱动皮带synchronous belt同步驱动皮轮synchronous belt pulley供油系fuel system控制燃烧系统controlled combustion system反湿气装置antipercolator电子燃油喷射electronic fuel injection 蒸气回收装置vapor recovery system燃油蒸气回收系统fuel vapor recovery system液体回收装置liquid withdrawal system恒量净化管constant purge line碳罐净化管canister purge line供油量fuel delivery循环供油量fuel delivery per cycle额定供油量rated fuel delivery 怠速供油量idling speed fuel delivery 供油规律fuel supply rate curve油量调节装置fuel control unit供油提前角fuel supply advance angle进油计量inlet metering几何供油行程geometric fuel delivery stroke供油率fuel supply rate燃油通道fuel gallery有效行程effective stroke剩余行程remainder stroke变行程计量variable stroke metering等容卸载constant volume unloading 变容卸载variable volume unloading 收缩容积retraction volume燃油喷油装置fuel injection equipment燃油喷射泵fuel injection pump滚轮式燃油喷射泵roll fuel injection pump凸轮轴式燃油喷射泵camshaft fuel injection pump直列式燃油喷射泵in-line fuel injection pump伺服式燃油喷射泵servo fuel injection pump底部突缘安装燃油喷射泵base flanged mounted fuel injection pump上部安装燃油喷射泵high flanged-mounted fuel injection pump侧向安装燃油喷射泵side-mounted fuel injection pump端部突缘安装式燃油喷射泵end flange-mounted fuel injection pumpV形燃油喷射泵vee fuel injection pump脉动式燃油喷射泵jerk fuel injection pump 螺纹安装燃油喷射泵screw-mounted fuel injection pump蓄能式燃油喷射泵accumulator fuel injection pump往复式燃油喷射泵reciprocating fuel injection pump驱动轴式燃油喷射泵driveshaft fuel injection pump单缸式燃油喷射泵single cylinder fuel injection pump圆柱式燃油喷射泵cylindrical fuel injection pump旋转式燃油喷射泵rotary fuel injection pump分配式燃油喷射泵distributor fuel injection pump多缸燃油喷射泵multicylinder fuel injection pump框架安装式燃油喷射泵cradle mounted injection pump喷油始点fuel injection beginning喷油终点fuel injection end喷油持续角fuel injection duration angle喷油延迟injection delay引燃喷射pilot injection 启喷压力injection starting pressure峰值喷油扭矩peak injection torque峰值喷油压力peak injection pressure喷油泵油缸数目number of cylinders of an injection pump无气喷射solid injection 喷射正时injection timing集中喷射group injection 喷油器injector整体式喷油器unit injector喷嘴nozzle轴针式喷嘴pintle type nozzle环槽式喷嘴annular slot nozzle孔式喷嘴hole type nozzle长杆喷嘴long stem nozzle孔板式喷嘴orifice plate nozzle开式喷嘴open nozzle闭式喷嘴closed nozzle喷油提前器timing advance unit喷射泵壳体injection pump housing针阀needle芯轴central spindle喷嘴壳体nozzle body针阀升程needle lift喷嘴盖形螺母nozzle cap nut喷油器壳体nozzle holder突缘安装喷油器壳体flanged-mounted injection nozzle holder燃油喷射泵传动装置transmision of an injection pump喷嘴锥体nozzle hole cone柱塞plunger柱塞套barrel柱塞行程plunger stroke喷孔spray orifice海拔控制器altitude control提前器飞锤flyweight喷孔长径比ratio of nozzle hole length nozzle diameter喷嘴液动力特性nozzle hydrokinetic characteristics动态相位dynamic phase喷孔面积nozzle hole area喷嘴流通特性nozzle flow characteristic喷油背压injection back pressure高压油管high pressure pipe平均喷油扭矩mean injection torque喷油总效率overall pumping efficiency峰值喷油压力injection peak pressure预行程prestroke收缩行程retraction stroke燃油箱fuel tank油箱盖fuel tank油位表fuel level gauge注油控制装置fill control system汽油箱gasoline tank( petrol tank)汽油供给管gasoline feed pipe加油管filler tube放油螺塞drain plug吸油管suction pipe刚性燃油管rigid fuel pipe进油孔fuel feed hole供油管supply pipe通气管bleeding pipe通气管bleeding pipe泄油阀spill valve泄油孔口spill port进油阀inlet valve最大油量限制器maximum fuel stop滴油dribble燃油表fuel gauge输油泵feed pump燃油泵fuel pump附装燃油箱中的电动燃油泵tank-mounted eletric fuel pump机械式燃油泵mechanical fuel pump膜片式燃油泵diaphragm fuel supply pump叶片式供油泵vane fuel supply pump活塞式输油泵piston type fuel supply pump齿轮式输油泵gear fuel supply pump电动燃油泵eletric fuel pump带真空泵的汽油泵vacuum pump with fuel pump起动加油器primer起动给油杆primer lever燃油泵上体fuel pump body燃油泵下体fuel pump base燃油泵盖bowl cover进油口接头fuel inlet neck出油口接头fuel discharge port输出阀delivery valve泵油元件pump element回油阀部件fuel return valve assembly化油器carburetor化油器系统carburetor circuit简单化油器elementary carburetor单腔化油器single-barrel carburetor双腔并动化油器two-barrel dual carburetor双腔分动化油器two-barrel duplex carburetor四腔化油器four-barrel carburetor上吸式化油器updaught carburetor下吸式化油器downdraught carburetor平吸式化油器horizontal carburetor侧吸式化油器side-draft-carburetor高海拔补偿式化油器altitude compensating carburetor化油器附加器adaptor carburetor双腔式化油器twin-choke carburetor固定喉管式化油器fixed venturi carburetor可变喉管化油器variable venturi carburetor化油器接头carburetor adaptor阻风门choke valve阻风活塞choke piston阻风板choke plate自动阻风门automatic choke阻风门拉钮choke button电控自动阻风门electric-assisted choke阻风管choke tube喉管venturi双重或三重喉管double & triple venturi阻风门拉线choke cable化油器小喉管booster venturi浮子系float system浮子float环形浮子annular float 同心式浮子concentric float浮子支销float hinge pin浮子针阀float needle valve阀针valve needle浮子油面float level浮子臂float arm侧置浮子室式side float type怠速阀idle valve怠速针阀idle needle省油器economizer省油器阀economizer valve辅助空气阀auxiliary air-valve加速油井accelerating well加速泵accelerating pump加速泵喷嘴accelerating pump nozzle油门throttle手油门hand throttle节气门操纵手柄throttle control lever真空加浓器vacuum booster加浓器excess fuel device量孔体jet block怠速量孔idle metering jet主量孔main metering jet剂量阀活塞dosage valve piston空气量孔air jet燃油滤清器fuel filter沉淀杯sediment bowl串联过滤器in-line filter燃油箱内装过滤器in-tank filter调速器governor飞球式调速器flyball governor调速器governor飞球式调速器flyball governor液压调速器hydraulic governor真空转速调速器vacuum speed governor惯性调速器inertia governor离心调速器centrifugal governor调速器重锤governor weight空气滤清器及进排气系统air cleaner and intake and exhaust sytem空气滤清器air filter冲压式空气滤清器ram air clearner恒温控制式空气滤清器thermostatic controlled air cleaner油浴式空气滤清器oil bath air cleaner纸质空气滤 清器paper air clearner旋流管式空气滤清器swirl tube air filter滤清器滤芯filter element空气滤清器壳体air filter housing空气滤清器盖air filter cover滤清器密封圈filter seal ring滤网sieve
滤纸盘或膜filter paper disc or membrane进气和排气系统intake and exhaust system排气管exhaust pipe排气抽气管exhaust extraction duct扫气泵scavenging pump进气预热装置intake preheater进气歧管intake manifold进气歧管真空度intake manifold vacuum冷式进气歧管cold manifold冲压式进气歧管ram intake manifold排气歧管exhaust manifold脉冲式排气歧管pulse exhaust manifold等压排气歧管constant pressrue exhaust manifold排气歧管热量控制阀exhaust manifold heat control valve超高度歧管high-rise manifold升温横跨管道heat crossover排气横跨管道exhaust crossover预热点hot spot阻风门加热器choke heater热空气导流管hot air duct隔热板heat shield排气再循环阀exhaust -gas-recirculation 消声器silencer进气消声器intake silencer排气消声器exhaust silencer金属垫片式消声器steel pack muffler玻璃丝消声器glass pack muffler空洞消声器gutted muffler前排气管front exhaust pipe尾管tail pipe消声器联接管intermediate pipe热空气管hot air pipe曲轴箱通风管crankcase bleed pipe隔声罩acoustic hood进气消声器元件silencer element真空泵vacuum pump指示功率indicated power指示热效率indicated thermal efficiency指示油耗率indicated specific energy consumption示功图indicator diagram冷却系cooling system风冷air cooling水冷water-cooling循环流冷却系cooling recovery system自然循环液冷却系统natural circulation type cooling system热流循环液冷却系统thermo-siphon circulation type cooling system温差循环液冷却系统gravity circulation water cooling system压力式水冷却系统positive circulation cooling system加压式冷却法pressure type cooling 水泵循环冷却系统pump circulation cooling system强制循环式化冷系统forced-feed water circulation system封闭式液冷系统sealed cooling system散热器radiator片式散热器finned radiator管式散热器tubular radiator蜂窝式散热器cellular radiator哈里逊式散热器Harrison type radiator带板式散热器ribbon type radiator上水箱upper tank下水箱lower tank涨溢箱expansion tank散热器芯radiator core之字形管散热器芯film core管-片式散热器芯fin and tube core散热器加水口盖radiator filter cap压力式水箱盖radiator-pressure cap蒸气-空气泄放阀vapor-air release valve散热器护罩radiator cowl散热器百叶窗radiator shutter散热器保温帘radiator roller blind散热片cooling fin缸盖散热片cylinder head fin缸体散热片cylinder block fin控温装置temperature regulating device恒温器thermostat恒温器主阀thermostat main valve恒温器旁通阀thermostat by-pass valve恒温器挠性波纹筒thermostat flexible bellows液体冷却设备liquid cooling equipment水泵water pump水泵体pump casing 水泵叶轮water pump impeller旁通进水口water by-pass inlet neck循环泵circulating pump主进水口water main inlet port出水口water outlet port自调式水封self-adjusting seal unit溢流管overflow pipe导流板deflector风扇fan(blower)轴流式风扇axial flow fan离心式风扇centrifugal fan风扇壳体blower casing风扇导流罩fan cowl风扇毂fan hub 风扇叶片fan blade风扇叶轮blower impeller风扇导流定子blower stator风扇皮带轮fan pulley三角皮带v-belt风扇护罩fan shroud风扇叶轮叶片impeller vane冷却用空气cooling air风扇导流叶片stator vane强制风冷forced-air cooling自然风冷natural air cooling风道air ducting润滑系lubrication system润滑lubrication气缸上部润滑upper cylinder lubrication 压力润滑pressure-feed lubrication 压力润滑法forced lubrication 自动润滑automatic lubrication 飞溅润滑splash lubrication 润滑周期lubrication interval 边界润滑borderline lubrication 曲轴箱机油油盘crankcase oil pan油底壳oil pan机油盘放油塞sump plug集油器oil collector机油泵oil pump计量式机油泵metering oil pump齿轮式机油泵gear type oil pump转子式机油泵rotor-type oil pump机油泵出油管oil pump outlet pipe放油口oil drain hole油道oil duct断油开关cut-off cock机油散热器oil cooler机油滤清器oil filter机油粗滤器primary oil filter机油精滤器secondary oil filter全流式机油滤清器full-flow oil filter分流式机油滤清器by-pass oil filter离心式机油滤清器centrifugal oil filter整体式滤芯integral filtering element细滤器滤芯filter element滤清器壳filter box滤片filtering disc机油减压器oil pressure relief valve旁通阀by-pass oil filter机油滤网oil strainer加机油孔oil filter cap滤芯轴filter shaft刮片组件cleaning edge机油量尺dipstick机油滤网oil strainer增压器supercharger增压和扫气装置pressure-charging and scavenging unit增压装置supercharging device涡轮增压器turbo-charger气波增压器comprex pressure wave supercharger增压器阻风阀supercharger blast gate增压器调节容气量的旁通阀supercharger control bypass增压器叶轮supercharger impeller惯性增压inertia supercharging机械增压mechanical supercharging涡轮增压turbo-charging增压比supercharge ratio增压压力boost pressure增压中冷inter-cooling中冷度inter-cooling level增压度supercharging level喘振surge喘振线surge line轴流式涡轮axial-flow turbine脉冲进气ram charging发动机试验engine test发动机试验规程engine test procedure发动机技术要求engine technical requirements标准大气状况standard atmospheric conditions大气压力atmospheric pressure进气温度inlet air temperature进气温度inlet air temperature功率校正power correction 功率标定power rating 功率换算power conversion 校正系数correction factor换算系数performance test性能试验performance test起动性能试验starting ability test怠速试验idle running test道路负荷试验road load test各缸工作均匀性试验cylinder variation test背压试验back pressure test最低稳定工作转速试验lowest continuous speed test with load背部泄漏试验back-leakage test调整试验adjustment test热平衡试验heat balance test快速磨损试验accelerated wear test热冲击试验thermo-shock test空载特性试验no-load characteristic test模拟增压试验simulated supercharging test停缸试验cylinder fuel-cut test增压机匹配试验turbo-charger matching test排气分析试验exhaust analysis test突变负荷试验sudden load change test稳定性试验stability test单缸熄火试验one cylinder shut off test例行检查试验routine inspection test验证试验verification test鉴定试验approval test可靠性试验reliability test耐久性试验durability test定型试验type approval test验收试验acceptance test现场试验field test出厂试验delivery test抽查试验spot check test复查试验re-check test台架试验bench test强化试验hop-up test发动机试验台engine test bed底盘测功机chassis dynamometer测功机dynamometer水力测功机hydraulic dynamometer电涡流测功机eddy current dynamometer电力测功机electric dynamometer扭矩仪torque meter转速表tachometer温度测量thermometry温度测量仪器thermometric instruments空气流量测量air flow measurement热线风速仪hot wire anemometer电子示功仪electronic indicator燃烧分析仪combustion analyzer压力传感器pressure transducer精密声级计precision sound level meter排放emission 排放物emission 排气污染物gaseous pollutant蒸发排放物evaporative emission曲轴箱排放物crankcase emission 漏气blowby gas氨氧化物oxids of nitrogen一气化碳carbon monoxide碳氢化合物hydrocarbon甲烷methane无甲烷碳氢化合物non-methane hydrocarbons光化学活性碳氢化合物photochemically reactive hydrocarbons微粒物particulated matter黑烟black smoke蓝烟blue smoke白烟white smoke碳烟soot光化学烟雾smog臭味odor丙烷propane排放浓度concentration of emission 排气烟度exhaust smoke先期排气initial exhaust亚临界排气subcritical exhaust超临界排气supercritical exhaust强制排气forced exhaust自由排气free exhaust排气提前角exhaust advance angle排气迟后角exhaust lag angle排气热损失exhaust heat loss排气净化exhaust purification 排气背压exhaust back pressure残余废气residual gas排气有害成分poisonous exhaust composition柴油机排烟diesel smoke综合排放浓度composite concentration of exhaust emission 综合排放质量composite mass of exhaust emission 排放系数emission factor排放率emission index质量排放量mass emission 比排放量brake specific emission 排放物控制系统emission control system排气排放物控制系统exhaust emission control system二次空气secondary air二次空气分配歧管secondary air distribution 二次空气控制阀secondary air control valve二次空气转换阀secondary air switching valve二次空气转流阀secondary air diverter valve二次空气喷射装置secondary air injection system二次空气喷射管secondary air injection tube二次空气喷射减速压阀secondary air injection relief valve脉动空气装置pulsating air system二次空气泵secondary air pump曲轴箱排放物控制系统crankcase emission control system曲轴箱双通风系统crankcase closed system曲轴箱单通风系统crankcase sealed system曲轴箱强制通风装置positive crankcase ventilationPCV阀PCV valve蒸发排放物控制系统evaporative emission control system活性碳罐贮存装置charcoal canister storage system活性碳罐charcoal canister曲轴箱贮存装置crankcase storage system空气滤清器贮存装置air filter storage system燃油箱止回阀fuel tank check valve油气分离器fuel and vapor separator清除阀furge valve催化转化系统catalytic converting system催化燃烧分析仪catalytic combustion analyzer催化剂catalyst转化器converter催化转化器catalytic converter轴流式转化器AXIAL FLOW TYPE CONVERTER径流式转化器RADIAL FLOW TYPE CONVERTER下流式转化器down flow type converter上流式转化器up flow type converter双床式转化器dual bed converter单床式转化器single bed converter氧化型催化剂oxidation catalyst还原型催化剂reduction catalyst三元催化剂three-way catalyst贵金属催化剂noble metal catalyst普通金属催化剂base metal catalyst稀土催化剂rare earth catalyst催化剂耗损catalyst attrition 催化剂收缩catalyst shrinkage催化剂中毒catalyst poisoning比表面积specific surface area空速space velocity载体涂料washcoat双重催化系统dual -catalyst system催化箱catalyst container载体substrate整体式载体monolithic substrate颗粒式载体pelleted substrate转化效率conversion efficiency熄灯温度light-off temperature热态反应系统thermal reacting system热反应器thermal reactor反应式歧管reactive manifold 过热保护装置over heating protection system过热警报装置over heating warning system排气口衬套exhaust port liner后燃器after burner排气再循环系EGR system排气再循环exhaust gas recirculation 节气门前EGR系统above throttle valve EGR system节气门后EGR 系统below throttle valve EGR system空气比例式EGR系统air proportional EGR system负荷比例式EGR系统load proportional EGR system孔口真空控制式EGR 系统ported vacuum controlled EGR system喉管真空控制式EGR系统venturi vacuum controlled EGR system排气压力控制式EGR系统exhaust pressure controlled EGR system声速控制式EGR系统sonic controlled EGR system电子控制式EGR系统electronic controlled EGR system EGR冷却器EGR cooler EGR 过滤器GER filterEGR 控制阀EGR control valveEGR调压阀EGR pressure regulator再循环排气EGR gas再循环排气率
EGR rate点火和喷油时刻控制系统ignition and injection timing control system点火时刻控制系统ignition timing control system减速点火提前控制装置deceleration spark advance control推迟喷油时刻控制系统retarded injection timing control system转速控制的推迟喷油时刻retarded injection timing with speed负荷控制的推迟喷油时刻retarded injection timing with load燃油控制系统fuel control system反馈控制feedback control空燃比反馈控制系统air-fuel ratio feedback control system理论配比stoichiometric高效带window氧传感器oxygen sensor稀混合气lean mixture浓混合气rich mixture分层充气stratified charge温度补偿temperature compensating海拔补偿altitude compensating气压补偿atmospheric pressure compensating电子控制化油器electronic controlled carburetor电子燃油喷射系统electronic fuel injection system怠速限制器idle limiter阻风门开启器choke opener减速控制装置deceleration control system补气阀gulp valve节气门定位器throttle positioner节气门缓冲器throttle dash pot节气门开启器throttle opener强制怠速加浓装置coasting richer发动机电子集中控制系统electronic concentrated engine control system温度传感器temperature sensor压力传感器pressure sensor位置传感器position sensor转速传感器speed sensor爆震传感器knock sensor进气流量传感器intake flow sensor温度开关temperature switch 节气门位置开关throttle position switch其他控制装置other control systems除水系统water removal system喷水装置water injection system调温式空气滤清器temperature controlled (modulated )air cleaner微粒物捕集装置particulate trap system捕集装置氧化器trap oxidizer一氧化碳容积百分率carbon monoxide percent by volume一氧化碳分析仪co analyzer湿度moisture量距和零点span and zero补偿compensation标定气体calibration gas样气处理系统sample handling system凝水分离器condensate trap密封垫gasket玷污contaminate防漏leakproof稀释dilution 算术平均值arithmetic average精度accuracy 全量程full scale漂移drift预热时间warm-up time抗腐蚀性corrosion -resistance流量计flowmeter热交换器heat exchanger不透气收集袋gas-tight collection bag分析测定方法和仪器analysis measuring method and instrument不分光红外线分析法nondispersive infrared不分光紫外线分析法nondispersive ultraviolet氢火焰离子化检测器flame ionization ditector总碳氢化合物分析仪total hydrocarbon analyzer气相色谱仪gas chromatograph化学发光检测器chemiluminescent detector臭氧发生器ozonator底盘测功机chassis dynamometer惯性模拟系统inertia simulation system功率吸收装置device for power absorption 转鼓roller空气阻力aerodynamic resistance滚动阻力rolling resistance当量惯量equivalent inertia滤纸式测试仪filter-type measuring apparatus转速表tachometer成套分析设备analytical train组合气室stacked cell参比室reference cell滤光室filter cell干扰滤光器interferential filter加热式氢火焰离子化检测器heated flame ionization detector氮氧化合物转化器Nox converter(No2-NO)反应室reactive cell (chamber)催化燃烧分析仪catalytic combustion analyzer碳氢化合物响应度hydrocarbon response碳数当量carbon equivalent百万分率碳parts per million carbon (ppmC)氧干扰oxygen interference氧校正oxygen correction 湿度较正系数humidity correction (kh)factor拖尾tailing五氧化二碘法iodine penta-oxide method平衡气balance gas零点气zero grade gas (air zero gas)校正气calibrating gas 量距气span gas 拉格朗日拟合lagrangian fit 二氧化碳干扰校正corrected for CO2 extraction 袋式分析bag analysis柴油机排烟测定仪器diesel smoke measuring instrument排气烟度opacity of exhaust gas烟度计opacimeter全流式烟度计full flow opacimeter取样烟度计sampling opacimeter光线有效通过长度effective path length of light ray吸光系数light absorption coefficient 峰值储存器peak hold device烟室smoke chamber引进气体incoming gas排出气体outgoing gas 色温color temperature人眼的感光曲线photoptic curve of human eye光谱反应曲线spectral response curve光源light source光束light beam 直接光线direct light ray反射光线reflected light rays散射光diffused light光通量light lux 中性滤波仪neutral optical filter烟度计物理反应时间physical response time of opacimeter电气响应时间electrical response time倍频程octave热时常数thermal time-constant 烟柱smoke column标定用遮光片calibrating screen 示踪气体tracer gas扫气scavenge air冷却装置cooling device膨涨箱expansion tank暗度刻度obscuration scale光学试验台optical bench热电偶thermocouple气密性gas tightness阻尼室dampling chamber烟度计smokemeter光学式烟度计optical smokemeter不透光式烟度计smoke opacimeter比尔-朗伯定律beer-lambert law不透光度opacity (lgiht obscuration )(N)透光度transmittance(t)光吸收系数coefficient of light absorption (k)光通道有效长度effective optical path length(L)滤纸式烟度计filter type smokemeter有效长度effective length抽气量swept volume滤纸有效面积effective filter area死区容积dead volume烟度单位smoke unit(index)滤纸式烟度单位filter smoke number (FSN)内装式烟度计built-in (in-line)smokemeter外装式烟度计mounted(end-of line) smokemeter全流式烟度计full-flow smokemeter部分流式烟度计part-flow smokemeter取样探头probe排气收集系统exhaust gas collection equipment稀释空气样气收集袋sample collection bag for dilution air稀释空气取样探头sample probe for dilution air稀释排气混合气收集袋sample collection bag for dilute exhaust mixture取样方法和设备sampling method and device全流取样法full flow sampling部分流取样法partial flow sampling 定容取样法constant volume sampling (CVS)全量袋式取样法total bag sampling 比例取样法proportional smapling直接取样法direct sampling method 动态或连续取样法dynamic or continuous sampling容积式泵positive displacement pump临界流量文杜里管critical flow venturi稀释系数dilution factor稀释用空气dilution air稀释排气diluted exhaust稀释风道dilution ratio取样探管dilution tunnel取样袋sampling bag逆向清洗back flush试验方法和限值testing method and limits试验循环test cycle行驶循环driving cycle工况mode行驶监视仪driver aid中间转速intermediate speed加权系数weighting coefficient美国烟排放物试验循环US EPA smoke emission test cycle全负荷法full load method自由加速法free acceleraton method加载减速法lug down method稳定单速法single steady speed method道路试验法road test method滑行法coastdown密闭室测定蒸发排放物法(SHED)sealed housing ofr evaporative emission determination (SHED)运转损失running losses热浸损失hot soak losses昼间换气损失diurnal breathing losses美国LA-4C法USEQP A-4CH test procedure美国LA-4CH法US EPA 4CH test procedure美国九工况法US EPA 9 -mode test cycle美国十三工况法US EPA 13-mde test cycle美国重型柴油机瞬态法US EPA heavy duty diesel engine transient test cycle日本四工况法Japanese 4-mode test cycle日本十工况法Japanese 10/11-mode test cycle日本六工况法Japanese 6-mode test cycle欧洲ECE十五工况法ECE 15-mode test cycle排放限值emission limits怠速排放限值idle speed emission limits浓度排放限值emission concentration limits质量排放限值mass rate of emission limits净化purifying净化率purifying rate在用车in-use vehicle无铅汽油unleaded gasoline劣化系数(DF)deterioration factor(DF)车辆类型vehicle type道路车辆road vehicle 商用车辆commercial vehicle机动车辆motor vehicle电动车辆electric vehicle 摩托车motorcycle轻便摩托车moped |
