  • 1287查看
[悬挂] pancake bushing 翻译成中文是什么衬套啊?
发表于 18-5-2010 15:36:14 | 显示全部楼层 |阅读模式
Same as a double mold bonded bushing except that the inner sleeve is oriented vertically in the vehicle.  Also the height of the outer sleeve is typically shallow.   A pancake bushing provides packaging advantages over a typical bushing.
请牛人帮忙翻译下。
发表于 18-5-2010 20:47:33 | 显示全部楼层
pancake shaped..
一种副车架衬套用的附属结构,像个塑料圈,雅阁副车架有这个。也叫Cross-Member bushings stoper  。
不知道理解对不对,呵呵
 楼主| 发表于 12-8-2010 10:44:17 | 显示全部楼层
楼上哥哥做什么的?汽车减震的吗?
GMT+8, 20-6-2026 20:11 , Processed in 0.389526 second(s), 36 queries .
