  • 1692查看
[AVL软件] 请教关于Excite多体动力学计算问题
发表于 14-6-2010 11:18:27 | 显示全部楼层 |阅读模式
我在做Excite多体动力学计算,运行Simulation时,提示如下错误:
$ Error (Code 871001)
The iteration in this time step is diverging and a reduction of the
time step size is not possible.
The calculation must be stopped.
User action: (1) Decrease the minimum (and maximum if necessary) time step size.
              (2) Decrease the accuracy parameters for the calculation
                  to increase the stability of the solution procedure.
                  (I.e. decrease RESCTR EPSU ... EPSR ... EPSE ...)
              (3) Check your calculation model.
              (4) If this occurs near the calculation start,
                  check the initial conditions of your model.
              (5) Check the Finte Element models of the bodies for
                  - small masses and moments of inertia
                    (esp. at reference points)
                  - small stiffness coefficients
                  - errors in the definitions of the degrees of freedom
                    (e.g. displacements in local coordinate systems)
请问这里的Code 871001和RESCTR EPSU ... EPSR ... EPSE ...分别是指什么?我又该做如何调整?谢谢!
发表于 24-4-2025 06:40:38 | 显示全部楼层
您好!针对您提到的关于Excite多体动力学计算问题,我很高兴为您提供帮助。请问您遇到了哪些问题?请简要描述一下您的问题现象,包括具体步骤、表现等。Excite在多体动力学计算领域具有广泛的应用,通常涉及复杂系统的建模和分析。为了更好地解决您的问题,我需要了解更详细的信息,如问题类型、错误消息等。期待您的回复,以便我能提供更专业的指导和建议。谢谢!
GMT+8, 13-4-2026 10:13 , Processed in 0.477900 second(s), 33 queries .
