  • 1841查看
NTN公司的球笼等速万向节动态分析
发表于 28-7-2010 17:01:20 | 显示全部楼层 |阅读模式
Analysis of Ball-Type Constant-Velocity Joints Based on Dynamics
Abstract;Universal joints, which transmit torque through the balls guided in such a manner that they always lie in the plane bisecting the angle between the driving and driven axes, are called ball-type constant-velocity joints. The authors presented the papers on the analysis of this type of universal joints based on statics taking account of no friction force between their components. To obtain more precise estimations of the internal forces and the moments, it seems to be important to evaluate the effect of the friction between the parts. Furthermore, in grasping the relative motions of the parts, such as rolling of the balls on the tracks, the static analysis is beyond its power. In this paper the authors analyze the motions of each parts based on dynamics, taking account of the frictions between the parts. The analysis results in simultaneous differential equations, which can be solved numerically using an electronic computer
Analysis of Ball-Type Constant-Velocity Joints Based on Dynamics.pdf
825.54 KB, 下载次数: 24, 下载积分: 积分 -1
发表于 20-2-2012 08:24:23 | 显示全部楼层
也来学习了,谢谢!
    慵懒
    31-3-2017 14:22
  • 签到天数: 6 天
    发表于 4-9-2015 20:59:54 | 显示全部楼层
    也来学习了,谢谢!
    GMT+8, 16-5-2026 07:10 , Processed in 0.570573 second(s), 38 queries .
