  • 5698查看
一些常用的发动机英语词汇
发表于 27-12-2010 15:38:59 | 显示全部楼层 |阅读模式
Block, cylinder
Casting, cylinder block
Liner, cylinder
Head, cylinder
Casting, cylinder head
Gasket, cylinder head
Crankshaft, engine
Camshaft, engine
Rod, engine connecting
Housing, gear
Housing, flywheel
Manifold, exhaust
Piston, engine
Pin, piston
Ring, compression piston
Ring, oil piston
Bearing, connecting rod
Gear, camshaft
Key
气缸体
气缸体毛坯
气缸套
气缸盖
气缸盖毛坯
气缸垫
曲轴
凸轮轴
连杆
齿轮室
飞轮壳
排气管
活塞
活塞销
活塞压缩环
活塞油环
连杆轴瓦
凸轮轴齿轮
半圆键
Support, camshaft thrust
Injector,
Screw, injector
Seal, injector
Clamp, injector
Pump, fuel injection
Pump, bass fuel
Rating, fuel
Accessories, fuel system
Tube, fuel supply
Connector, banjo
Nut, tube
Seal, ferrule
Piece
Screw, banjo connector
Washer, sealing
Screw, hex flange head cap
Pump, fuel transfer
Gasket, cover plate
Control, accelerograph
Board, fixation
Nut, hexagon
凸轮轴止推片
喷油器
喷油器螺栓
喷油器密封垫
喷油器压板
燃油喷射泵
基本燃油泵组
额定供油率
供油系统附件组
燃油输油管
琶形接头
联管螺母
锥形管节
基本件
琶形接头螺栓
密封垫圈
六角法兰面螺栓
输油泵
输油泵密封垫
油门操作组
固定板
六角螺母
Washer, spring
Plumbing, fuel
Seal, banjo connector
Valve, check
Clip,
Tube, fuel injector supply
Brace, tube
Isolator, vibration
Collar, tube support
Piece
Manifold fuel
Valve, fuel shutoff
Screw, hexagon head cap
Washer, plain
Nut, hex flange head cap
Support, shutoff valve
Filter, fuel
Head, fuel filter
Ball,
Insert, filter head
Nut, regular hexagon jam
Seal, rectangular ring
弹簧垫圈
燃油管路组
琶形接头密封圈
检查阀
夹子
高压油管
管路支架
隔振块
油管支架衬套
基本件
燃油回油岐管
燃油断油阀
六角头螺栓
平垫圈
六角法兰面螺母
断油阀支架
燃油滤清器
燃油滤清器座
钢球
滤清器接头
六角锁紧螺母
矩形密封圈
Adapter, filter head
Plumbing, fuel filter
Screw, captive washer cap
Coupling, fuel pump
Stud,
Brace, fuel pump
Nut, weld
Gear, fuel pump
Space,
Pulley, accessory drive
Dataplate,
Screw, drive
Base parts
Follower, cam
Tappet, valve
Lever, rocker
Rod, push
Screw, twelve point cap
Clamp, retaining
Insert, rocker lever
Nut, heavy hexagon
Screw, rocker lever adjusting
滤清器座接头
燃油滤清器连接管组
带密封垫螺栓
燃油泵连接件组
双头螺栓
燃油泵支架
焊接螺母
燃油泵齿轮
垫块
附件驱动皮带轮
参数牌
自攻螺栓
基础件
凸轮从动件组
挺杆体
摇臂
推杆
十二角头螺栓
锁夹
摇臂镶块
六角厚螺母
摇臂调整螺栓
Ring, retaining
Support, rocker lever
Shaft, rocker lever
Rivet,
Manifold, oil
Cover, front gear
Screw, round head cap
Housing, timing pin
Pin, timing
Seal, O ring
Tube, lub oil transfer
Gasket, gear housing
Cover, gear
Seal, oil
Panel, noise
Drain cock,
Plug, pipe
Dowel, pin
Bearing, main
Plug, expansion
Crankshaft, assembly TLA
Gear, crankshaft
挡圈
摇臂轴支座
摇臂轴
铆钉
机油岐管
前端齿轮室组
园头螺栓
正时销座
正时销
O型密封圈
机油输送管
齿轮室密封垫
齿轮室盖
油封
降噪板
放水阀、放汽阀
锥型螺塞
定位销
主轴瓦
碗型塞、塞片
曲轴总成
曲轴齿轮
Nozzle, piston cooling
Bearing, crankshaft thru
Cap, main bearing
Bushing, camshaft
Breather, crankcase
Clamp, spring hose
Tube, breather
Screw, self tapping meta
Clamp, hose
Hose, plain
Connection, vent
Plumbing, CPR coolant
Connector, male
Elbow, male adapter
Tube, CPR water outlet
Seal, grommet
Tag, number
Connection, air CPR inlet
Clamp, hose
Tube, compressor air
Compressor, air
Gear, accessory drive
活塞冷却喷嘴
曲轴止推瓦
主轴承盖
凸轮轴衬套
曲轴箱通风组
钢丝型弹性环箍
通风管
自攻螺栓
管夹
直软管
通风口接头
空压机冷却液管路组
直通接头体
弯管接头体
空压机出水管
密封圈
标签
空压机进气管组
管夹
空压机进气管
空气压缩机
空压机齿轮
Hose, flexible
Gasket, hydraulic pump
Spacer, mounting
Brace, air compressor
Ref. Drawing, accessory of air compressor
Damper, vibration
Drive, Frt Gr Tr accessory
Location, fuel drain
Control, engine brake
Thermostat,
Alternator
Wire, tapping
Location, alternator
Brace, alternator
Support, alternator
Drive, alternator
Belt, V ribbed
Tensioner, belt
Screw, flat head cap
Drive, mech tach
Support, left engine
组合软管
液压泵密封垫
隔块
空压机支架
空压机附件参考图
扭振减振器
前端齿轮系附件驱动组
回油接头组
发动机排气制动组
调(节)温器
发电机
搭铁线
发电机安装件组
发电机支撑
发电机支架
发电机驱动件组
多楔带
皮带张紧轮
沉头螺钉
机械转速表驱动组
发动机左悬置支架
Support, right engine
Drive, fan
Pulley, fan
Support, fan
Bearing, ball
Hub, fan
Retainer, fan hub
Plumbing, air fuel control
Tube, air fuel control
Bushing, reducing pipe
Cover, rear
Gasket, rear cover
Cover, plate
Plug, O ring
Flywheel,
Gear, flywheel ring
Pump, hydraulic
Bracket, lifting
Label,
Decal,
Cooler, engine oil
Spring, compression
发动机右悬置支架
风扇驱动件组
风扇皮带轮
风扇支架
滚珠轴承
风扇轮毂
风扇轮毂座圈
增压补充器连接管组
增压补充器连接管
异径管套
后油封座
后油封座密封垫
盖板
O型塑料堵塞
飞轮
飞轮齿环
液压泵
发动机吊耳
标签
警示牌
发动机机油冷却器组
压缩弹簧
Element, Lub oil filter
Gasket, oil cooler core
Core, cooler
Plunger, Prs regulator
Valve, bypass
Gasket, Lub oil cooler cover
Plug, threaded
Head, Lub oil filter
Gasket, filter head
Valve, pressure relief
Cover, Lub oil cooler
Gauge, oil level
Tube, oil gauge
Dipstick,
Pump, lubricating oil
Cover, cylinder block
Cap, filler
Connection, oil filler
Pan, oil
Boss,
Gasket, oil suction connection
Connection, oil suction
机油滤清器
机油冷却器芯密封垫
机油冷却器芯
机油调压阀柱塞
旁通阀
机油冷却器座密封垫
螺塞
机油滤清器座
滤清器座密封垫
减压阀
机油冷却器座
机油标尺组
机油标尺管
机油标尺
机油泵
气缸体加油附件组
加机油口盖
加机油接管
油底壳
隔块
机油吸油管密封垫
机油吸油管
Flange, weld
Screen, oil suction
Gasket, oil pan
Turbocharger, bypass
Gasket, turbocharger
Performance parts
Collect, valve
Spring, valve
Retainer, valve spring
Valve, exhaust
Valve, intake
Seal, valve stem
Insert, valve
Guide, valve stem
Shield, debris
Paint,
Nameplate,
Motor, starting
Location, turbocharger
Lock-plate
Tube, air
Clamp, T bolt
焊接法兰
机油收集器滤网
油底壳密封垫
旁通式增压器
增压器密封垫
性能件组
气门锁块
气门弹簧
气门弹簧座
排气门
进气门
气门杆油封
气门座
气门导管
防尘罩
油漆
名牌(厂标)
起动机
增压器安装件组
防松片
空气进气管
T型螺栓卡箍
Aftercooler, jacket water
Aftercooler,
Gasket, exhaust
Housing, thermostat
Shaft, shutoff valve
Gasket, thermostat housing
Pin, roll
Plumbing, turbocharger
Connector, female
Connection, Tur oil drain
Gasket, oil drain
Cover, valve
Seal, rocker lever cover
Connector, vent
Plumbing, aftercooler
Tube, water inlet
Plate, clamping
Tube, water outlet
Connection, water transfer
Resistor, corrosion
Plumbing, block vent
水套式中冷器组
中冷器
排气管密封垫
节温器座
滤清器座接头
开关阀轴
节温器座密封垫
圆环销
增压器管路组
内螺纹接头
增压器回油管
回油管密封垫
气门室罩盖
气门室盖密封垫
除汽接头
中冷器管路组
进水管
固定片
出水管
水管连接接头
防锈器
气缸体除汽管路组
Tube, vent
Connection, water inlet
Tab, tube weld
Hose, elbow
Connection, water outlet
Pump, water
除汽管
进水连接管
焊接支管
弯管
出水连接管
水泵
发表于 21-4-2025 17:38:00 | 显示全部楼层
以下是对您提供的发动机英语词汇的专业回复:
关于发动机中的常用词汇:
1. Block 和 Casting 通常指的是发动机的主体结构,即发动机缸体。
2. Cylinder(气缸)是发动机中的重要部分,用于容纳活塞的运动。
3. Liner 是气缸内部的保护层,确保气缸的耐磨性。
4. Head 通常指气缸盖,封闭气缸顶部,与活塞顶面形成燃烧室。
5. Casting, cylinder head 的意思是气缸盖的铸造工艺。
6. Gasket(垫片)用于密封气缸盖与缸体之间的连接。
7. Crankshaft(曲轴)是发动机的动力输出部分,将活塞的上下运动转化为旋转运动。
8. Camshaft(凸轮轴)控制气门的开关。
9. Rod(连杆)连接曲轴和活塞,传递动力。
10. Housing(外壳)用于固定齿轮和飞轮。
11. Manifold(歧管)用于引导气体流动,如排气歧管。
12. Piston(活塞)在气缸内往复运动,实现发动机的压缩和膨胀过程。
13. Pin(销钉)用于固定活塞和连杆的连接。
14. Ring(活塞环)用于密封气缸,防止气体泄漏。
这些词汇是发动机领域的基础术语,对于汽车工程师来说非常重要。
GMT+8, 29-4-2026 10:30 , Processed in 0.330461 second(s), 34 queries .
