  • 1094查看
猎头职位:变速器电子工程师、液压工程师、测试工程师、机械工程师、质量先期策划
发表于 1-4-2011 15:27:16 | 显示全部楼层 |阅读模式
Transmission Electronic Controls Engineer
Key Responsibility:
Responsible for technical aspects of electronic controls of automatic off-highway transmissions within local market;
Liaison with electronic controls engineering departments of Company global transmission technical centers;
Maintenance of software versions, application files and data status at local customers;
Support for transmission test equipment setup in terms of transmission controls.  Procurement and maintenance of tools needed for control unit test and analysis;
Check out at local customers for transmission controls with service engineers;
Cooperating with OEMs and consultation to service centers for trouble shooting in terms of electronic controls, on line or at site;
Recommendation and potential implementation of updating transmission control strategy for local customers depending on OEM requests, field feedback as well as local codes and preference;
Requirements:
Bachelor’s degree or above in control engineering or electronic engineering;
Having been working in field of controls of automatic transmissions for more than 5 years, familiar with the mostly used tools for development of automatic transmission controls such as those by MatLab, dSpace and Vector.  Good command of C++ language;
Experience with industry of construction/mining/material-handling machines, transmissions or TCU is preferred;
Good knowledge of electronics, solenoids and hydraulic control systems.  Good knowledge of TCU;
Fluent in English language, oral and written;
Demonstrated strong computer proficiency using Microsoft Excel, Word, Lotus Notes and other computer applications;
Be able to work extended hours when required.
Transmission Test Engineer
Key Responsibility:
Responsible for testing of off-highway transmissions;
Liaison with testing departments of Company global transmission technical centers in terms of testing of off-highway transmissions and components;
Test equipment specification, technical communication with vendors;
Support in programming of test procedure and updating;
Guidance to technicians for test operation;
Trouble shooting for problems occurring during transmission testing;
Test reports, and analyzing test results with product engineering;
Test equipment maintenance to make sure test equipment is kept in good condition.
Requirements:
Bachelor’s degree or above in mechanical engineering or electronic engineering;
Having been working in field of powertrain testing for more than 5 years, familiar with test equipment, measurement technologies and data acquisition system, familiar with PLC and its programming;
Experience with industry of construction/mining/material-handling machines or their transmissions is preferred;
Knowledge of mechanical, electrical, hydraulic and control systems;
Good command of English language, oral and written;
Be able to work flexible hours when required.
Transmission Hydraulic Controls Engineer
Key Responsibility:
Responsible for technical aspects of hydraulic controls of automatic off-highway transmissions within local market;
Liaison with hydraulic controls engineering departments of Company global off-highway transmission technical centers;
Establishment of hydraulic test stand for hydraulic components and maintenance;
Support for transmission test equipment setup in terms of hydraulic controls of automatic transmissions;
Technical communication with suppliers for components of hydraulic system and solenoids;
Cooperating with OEMs and consultation to service centers for trouble shooting in terms of hydraulic control system, on line or at site;
Understanding of local transmission oil grades and quality levels, providing assessment and recommendation when required;
Requirements:
Bachelor’s degree or above in hydraulic control engineering or mechanical engineering;
Having been working in field of hydraulic control systems of automatic transmissions for more than 5 years, familiar with the mostly used tools for development of hydraulic system including computational fluid dynamics;
Experience with industry of construction/mining/material-handling machines, transmissions or control valve is preferred;
Good knowledge of hydromechanics, hydraulic control systems and major  hydraulic components including control valve, solenoids, pumps etc;
Transmission Mechanical Engineer
Key Responsibility:
Responsible for mechanical components including friction system of automatic off-highway transmissions within local market;
Liaison with transmission engineering departments of Company global off-highway transmission technical centers;
Support for transmission test equipment setup;
Technical communication with suppliers for mechanical components and friction components;
Cooperating with OEMs and consultation to service centers for trouble shooting in terms of mechanical components and friction system;
Understanding of local codes and practices for transmission components and materials, providing assessment and recommendation when required;
Requirements:
Bachelor’s degree or above in mechanical engineering;
Having been working in field of development of transmissions for more than 5 years, familiar with the commonly used design tools and simulation tools for transmissions;
Good knowledge of transmission components including gears, shafts and cases, as well as torque converters.  Knowledge of gear manufacturing process;
Good knowledge of tribology is a plus;
Quality Advanced Engineer
Responsibility:
? Project work within APQP process, comprehensive quality work within the project.
Cooperation in transferring customer-specific requirements into target specifications, with particular regard to manufacturing and inspection capability
?.Compilation and monitoring of a project-specific quality plan on the basis of APQP in agreement with the Project Manager.
? Monitoring implementation of product, process and project-related quality requirements. Involving in design review, participate in the stipulation of critical and specific characteristics
? Implement the quality tool, lessons learned from predecessor projects and best practice of Company in project developmen
? Assessment / agreement of product / process FMEAs as regards their formally correct application.
? Compile new product control plan/test plan/validation plan, based on process FMEA (prototype, pilot series and series).
? Compile of inspection work instruction and control sheet base on control plan.
? Analysis of dimensional measurement results for the achievement of dimensional stability.
? Compilation of reports, analyses and statistics initial sample report, PSW, PPAP, IMDS in accordance with customer requirements. Submission of PPAP,PAW for customer approval.
? Creating of gages concept, planning the required measuring and monitoring equipment for Quality Assurance including its validation and release.
? Further development of measuring and monitoring technology in production processes.
? Plan and execute approval for new suppliers parts PPAP. Process audits on suppliers’ premises.
? Lead and organize customer audits/internal process audit/ product audit etc.
? Plan and conduct training programs for quality employees
? Participate in project meeting, APQP status report and share information within project team timely.
? Problem solving engagement, Drive and manage product quality improvement.
? Other tasks as assigned by the superior leader
Competence:
- Bachelor degree majored in Mechanical related Engineering.
- Rich knowledge and experience in gear manufacturing, casting, forging, and machining.
- Minimum 3 years professional experience in relevant position in multinational manufacturing Industry.
Automotive industry is preferred.
- 3+ years experience of quality or design (technical) function.
- Master APQP, PPAP, FMEA, SPC, MSA. Process audit and product audit
- Familiar with ISO9001, ISO/TS16949 system.
-Excellent communication skills with the ability to influence others.
- Able to work with minimal supervision yet deliver business objectives
- Fluent English both in oral and written.
简历请发送至:neo.cao@live.cn  neo.cao@reachsino.com
全球汽车零部件行业知名企业,销售额90亿美元。产品为非公路车辆及工程机械车辆的变速器、传动轴及车轴。在建的中国研发中心及实验室投资近6亿人民币,可完成上述产品的耐久测试、功能测试等多项试验。技术中心建成后将大大提升公司的产能和在亚太区乃至全球的技术领先地位。
发表于 15-5-2011 00:27:48 | 显示全部楼层
木看见有A/C呀
        其实我是来刷积分的
GMT+8, 2-5-2026 16:46 , Processed in 0.371736 second(s), 33 queries .
