  • 1828查看
世界顶级动力电池公司招聘--AME & process engineering manager
    发表于 14-7-2011 23:30:13 | 显示全部楼层
    but i have no experience ,could you please give me a hand?
     楼主| 发表于 13-5-2011 14:51:46 | 显示全部楼层 |阅读模式
    职位: AME & process engineering manager
    工作职责:
    1.        Lead and supervise AME & process engineering function/team, develop AME & Process engineering staffs
    2.        Work with R&D team to flawlessly launch new products, new process and new production line, in the meanwhile, support R&D prototype development
    3.        Ensure process robustness, and provide effective solutions on process & quality issue
    4.        Establish and sustain robust database and document management for all new products, new projects to meet both APQP/quality system and operation execution requests
    5.        Setup team KPI by aligning with organization goals
    6.        Define CI approaches by considering right ROI analysis and budgeting control
    7.        Provide monthly capacity analysis against all CCs/SCs to TOP management team
    Continuously optimize production floor layout to support efficient material flow, safety environment, and reliable process.
    任职要求:
    Bachelor degree or above in electrical-chemical engineering, or related battery majors
    5  years management experience in battery engineering or Process Engineering field, with Industrial Engineering knowledge preferred
    1.        Six sigma knowledge (Green Belt above)
    2.        Be detail oriented, analytical and demonstrated supervisory skills
    3.        Strong interpersonal skills and problem solving ability
    4.        Strong communication skills both in English and Chinese
    5.        Good people management skills
    6.        To be able to work under pressure
    职位:Process Engineer (Chemical)
    Responsibilities:
    1.Responsible for Manufacturing Process design and Process continuous improvement;
    2. Participate in the new product Development Process.
    3. Establish Corrective Action Plans to address Root cause of top Line failures.
    4. Improve line overall yield rate;
    5. New production line setup;
    6. Train operators and technicians
    7. Develop/update or be part of team to Develop/update Product Documents such as SPC,Flow Chart, PFMEA and Control Plan and Work Instructions.
    8. Coordinate implementation of related Engineering Changes.
    9.Define process sequence, Work methods, manpower required, time studies, etc. to
    insure efficient use of manpower.
    Requirements:
    1.BS or above in Chemical engineering or equivalent/Mechanical
    2.Minimum 4 years experience, out of which 1 year should be in managerial position in foreign enterprises.
    3.Have actual experience to design process layout, process flow  chart, process control plan;
    4.Familiar with PFMEA,SPC
    5.Have some background in ISO/TS16949 quality system skills.
    6.Proficiency in English and Mandarin.
    7.Good at  analyse and solve issue with 6 sigma methodology.
    职位:Process Engineer
    Responsibilities:
    1.Design or improve cell structure to make cell performance robust
    2.Design or working with equipment engineer to modify machines or jigs to let
    equipment proper for new structure
    3.sustain product though providing timely manufacturing support to ensure
    delivery of qualified product
    4.lead or take part in CI actions though process or machine to get better process
    control and quality
    5.create working instruction and assist in training manufacturing people
    6.support pilot building activities from R&D
    Requirements:
    1.Bachelor or above on electrical chemistry or material
    2.More than 2 years experience,Experience on cylindrical cells structure is prefer
    3.Good in English reading and writing
    4.Common sense, social confidence and industrial maturity
    5.Good team player
    职位:Quality Engineer
    Responsibilities:
    1.Monitor and support to solve the process quality issue
    2.Take analysis and support to solve the customer complaint quality issue
    3.Set up the quality control system standard base on global quality system
    4.Set up the process quality control standard and give coaching
    5.Confirm and verify the process change under control
    6.Familiar with quality tools and data statistics method
    7.Take lead or cooperation with related dept. for disposal of non-confirming issues
    8.Regular quality issue report and progress update
    Requirements:
    1.Chemical or electro-mechanical, bachelor prefer
    2.3 years or more work experience about quality control management.Better in Lithium ion battery manufacture
    3.Good knowledge in ISO9001 or TS16949
    4.Good communication and problem solving skills
    5.Good knowledge of use of quality control tools such as SPC, DOE, FMEA, 8D, APQP, PPAP, etc.
    6.Familiar with 6-sigma methodology
    7.Activity and team-work spirit
    职位:Assistant quality engineer
    Responsibilities:
    1. Document control according to quality system requirement (release, distribution, recall.etc.)
    2.    Maintain all the documents used inside the factory shall be latest revision.
    3.    Calibration control for all measuring instrument,
    4.    Take charge of routine quality data collection and preparation.
    5.    Sample and experiment follow up.
    Requirements:
    1.College in mechanical engineering or related
    2. At least 2 years document control experience.
    3. Skilled in TS16949 system
    4. Good English speaking and writing.
    5. Qualified TS16949 internal audit.
    特邀有才华、敢于挑战的您加盟,我们将为您提供有竞争力的薪资,优厚的福利待遇和良好的发展空间!
    有意者请速与我联系:
    中英文简历以word附件形式发至:zptime@gmail.com ,邮件主题格式请设为:应聘姓名-职位.
    更多职位请浏览我们的网站:http;//www.zptime.com
    我们承诺,对来自于客户及候选人的任何资料,都将仅在招聘范围内进行交流。
     楼主| 发表于 17-5-2011 09:02:04 | 显示全部楼层
    有的请联系我zptime@gmail.com
     楼主| 发表于 20-5-2011 16:58:34 | 显示全部楼层
    信息的时代最缺什么.
     楼主| 发表于 30-5-2011 12:45:23 | 显示全部楼层
    急聘:急聘:急聘:
    GMT+8, 30-7-2025 01:40 , Processed in 0.458130 second(s), 35 queries .
