  • 2568查看
ansys 接触分析 出错
发表于 3-6-2011 18:54:45 | 显示全部楼层 |阅读模式
*** WARNING ***                         CP =     313.141   TIME= 17:46:23
PRETS179 element maintains its original orientation in a large
deformation analysis.
*** WARNING ***                         CP =     313.203   TIME= 17:46:23
SOLID45 wedges are recommended only in regions of relatively low
stress gradients.
*** WARNING ***                         CP =     313.234   TIME= 17:46:23
Meshes made up of 10 percent or more of SOLID45 tetrahedra are not
recommended.
*** WARNING ***                         CP =     313.594   TIME= 17:46:23
Previous testing revealed that 31 of the 126997 selected elements
violate shape warning limits.  To review warning messages, please see
the output or error file, or issue the CHECK command.
No shape testing has been performed on 1 of the 126997 selected
elements.  To perform shape testing on these elements and see any
warning messages about the others, please issue the CHECK command.
GMT+8, 17-4-2026 07:57 , Processed in 0.365177 second(s), 31 queries .
