  • 2098查看
日产维修手册上的SRT代码指的是什么啊
发表于 4-6-2011 12:48:30 | 显示全部楼层 |阅读模式
日产维修手册上的SRT代码指的是什么啊
那位高人知道啊
发表于 29-9-2011 21:26:18 | 显示全部楼层
SRT:SYSTEM READINESS TEST (SRT) CODE
System Readiness Test (SRT) code is specified in Service $01 of SAE J1979.
As part of an enhanced emissions test for Inspection & Maintenance (I/M), certain states require the status of
SRT be used to indicate whether the ECM has completed self-diagnosis of major emission systems and components.
Completion must be verified in order for the emissions inspection to proceed.
If a vehicle is rejected for a State emissions inspection due to one or more SRT items indicating “INCMP”, use
the information in this Service Manual to set the SRT to “CMPLT”.
In most cases the ECM will automatically complete its self-diagnosis cycle during normal usage, and the SRT
status will indicate “CMPLT” for each application system. Once set as “CMPLT”, the SRT status remains
“CMPLT” until the self-diagnosis memory is erased.
Occasionally, certain portions of the self-diagnostic test may not be completed as a result of the customer's
normal driving pattern; the SRT will indicate “INCMP” for these items.
NOTE:
The SRT will also indicate “INCMP” if the self-diagnosis memory is erased for any reason or if the ECM memory
power supply is interrupted for several hours.
Revision: May 2007 2008 Altima
ON BOARD DIAGNOSTIC (OBD) SYSTEM
EC-115
< FUNCTION DIAGNOSIS > [QR25DE FOR CALIFORNIA]
C
D
E
F
G
H
I
J
K
L
M
A
EC
N
P
O
If, during the state emissions inspection, the SRT indicates “CMPLT” for all test items, the inspector will continue
with the emissions test. However, if the SRT indicates “INCMP” for one or more of the SRT items the
vehicle is returned to the customer untested.
NOTE:
If MIL is ON during the state emissions inspection, the vehicle is also returned to the customer untested even
though the SRT indicates “CMPLT” for all test items. Therefore, it is important to check SRT (“CMPLT”) and
DTC (No DTCs) before the inspection.
发表于 29-9-2011 21:57:22 | 显示全部楼层
NOTE:
NOTE:
清雅轩 + 3 热心人士【论坛口号→知无不言,言无不尽】
发表于 26-12-2011 00:28:10 | 显示全部楼层
主动测试吧应该是
GMT+8, 5-5-2026 20:13 , Processed in 1.003074 second(s), 40 queries .
