  • 1349查看
发动机问题引起整车仿真出错
发表于 17-7-2011 18:07:38 | 显示全部楼层 |阅读模式
truck模块自带msc_truck_powertrain.tpl'是用于双后轴驱动的,我将这个发动机装配到两轴货车(单后轴驱动)上,仿真老是出现下面的静平衡问题,在这里请各位高手指点迷津!万分感谢啊!!!!!
   For the last attempted iteration the equation with the largest error
   was GSE QQ_linear_uniform65.msc_truck_powertrain.powertrain_gse  Error = 2.60255E+06
   The variable receiving the largest increment
   was PART QQ_linear_uniform65.msc_truck_powertrain.ges_rear_driveshaft  Delta = 3.90161E+19
GMT+8, 12-10-2025 16:00 , Processed in 0.369861 second(s), 32 queries .
