宝马诊断座调表系统BMW scanner 是bwm车系诊断处理仪表的软件,可以直接通过诊断座更改仪表,LCM灯光电脑数据!可以支持E38,E39,E46,E53!支持车型:E38 - 7 seriesE39 - 5 seriesE46 - 3 seriesE53 - X5 series支持功能:READ EEPROM 读取存储器WRITE EEPROM 写入存储器COPY CODING 复制codingREAD KEY 读取钥匙ADAPTER EWS-DME 匹配防盗和发动机READ FLASH MEMORY 读取flsah数据ODOMETER CORRECT 公里数修改READ/CLEAR ERRORS 读取/清除故障强大的诊断功能和仪表更改功能使你轻松应对BMW! The program reads out the identification data of the found modules, defines quantity of mistakes, dumps them, and then repeats reading.The status of each module is deduced in two columns where in the first the quantity of mistakes kept in memory of the module while in service is shown, and in the second - quantity of mistakes after dump, i.e. a real condition of the module at present.Thus the program does not decipher codes of the found mistakes, and only defines their quantity. It is necessary to pay attention to it, as it excludes its use as diagnostic software. On the other hand, such programs are optimum from the point of view of pre-selling preparation of the car.As the greatest interest is represented with such electronic modules as IKE, LCM, EWS, DME and EGS, and opportunities of the program are defined on these modules; it is meaningful to consider the list of accessible functions in more detail, on concrete examples.?FACTORY DEFAULTS - dump on factory installations?SERVICE RESET - dump of service intervals?COPY CODING - copying coding dates of the automobile from IKE in EWS?READ KEY - data reading from a key |
