  • 1533查看
PP2000 V23.25 Lexia-3 V46 Citroen/Peugeot Diagnostic
发表于 6-8-2011 12:36:08 | 显示全部楼层 |阅读模式
PP2000/LEXIA-3 Interface works for both Citreon and Peugeot!
Compatible Vehicles:
It compatible with Citreon cars including, C1,C2,C3,C4,C6,C8,C-CROSSER,NEMO,BERLINGO,JUMPY,JUMPER,AX,SAXO,BX and so on.But please pay attention,according to our customer's experience,this item can not works good at C5 new models.
It compatible with  most Peugeot cars from 1995,but it can not work good with Peugeot 307 after 2004 year.
If customer have this two types of cars,please pay attention.please check with us first before purchase.
Diagnostics is performed via OBD-II connector (which is located near steering wheel) or via manufacturer-specific connector (only older cars, pre-2001).
Supported functions
Unlike other universal car scanner tools which only read fault codes, this software performs nearly ALL the functions like the original dealer diagnostic tool. Our diagnostic interface contains K-Line multiplexor, CAN-BUS interfaces and SAE J1850 bus (both PWM and VPW).
The following diagnostic functions are supported:
1.Read identification
Displays complete identification of control unit, e.g. part number, software/hardware version, manufacturer, etc...
2.Read fault codes
Displays all stored and pending fault codes with complete description (e.g. "Rail pressure - too low pressure").
Program supports report printing or copy to clipboard.
3.Clear fault codes
This function clears all stored fault codes and other diagnostic information.
4.Auto-scan (complete car scan/test)
Detects all ECUs (electronic control units) installed in car and reads all diagnostic fault codes.
5.Measured Values
Program displays live Data like Engine Speed, Battery voltage, Oxygen Sensor, Coolant Temperature, etc. Values can be displayed in graph, 9 values at once, or full listing (all measured values). Logging to file is also supported, which allows offline analysis.
6.Actuator test
Actuator test activates particular actuator (e.g. turn on fuel pump, lock/unlock wheel, lock/unlock doors, cut off fuel, etc..)
Hardware and software requirements
Software requires at least Intel Celeron/Pentium III 400 MHz, 128 MB RAM, 50MB free HDD space and USB 1.1 port (USB 2.0 recommended) and Microsoft Windows 98 SR2/2000/XP with the latest service pack installed.
If customer requires, we can prepare ready to work PC.
Package includes:
1pc x Main unit with extension OBD2 cable
1pc x Long 9pin to USB cable
1pc x Short 9pin to USB cable
1pc x OBD2 cable
1pc x 16pin to Clip Cable
1pc x Instruction for Installation and Activation DVD for PP2000
Language Inculding:
English, German, French, Japanese, Russian, Spanish, Portuguese, Swedish, Turkish, Dutch, Polish, Italian, Hungary, Greek, Czech
If you have problems with installation,plz contact with our customer service,we will provide file to teach you how to install it.
发表于 25-4-2025 19:52:32 | 显示全部楼层
根据您所提供的信息,关于PP2000 V2325和Lexia-3 V46针对Citroen/Peugeot的诊断工具,此工具适用于多种Citroen车型,如C1、C2、C3、C4、C6、C8等。然而请注意,具体的兼容车型需视具体的汽车软件和硬件版本而定。建议您在实际操作中查阅详细的技术文档和用户手册以确保正确性和安全性。我们强调确保采用合适的诊断工具及设备能极大保障汽车的正确维修与保护车辆的使用寿命。如有疑问,请进一步咨询专业汽车工程师或相关技术支持团队。
GMT+8, 19-4-2026 09:55 , Processed in 0.481284 second(s), 36 queries .
