  • 1163查看
LED驱动器
发表于 9-8-2011 14:41:02 | 显示全部楼层 |阅读模式
General
· Low cost power LED driver for external n-channel MOSFET
switching transistor
· 6V to 32V DC input range
· Applications from mA to several Ampere LED current
· Possible temperature dependent regulation using external
Negative Temperature Coefficient (NTC) resistor
· Small package allows compact module design with minimised
wire runs and short connections to achieve improved EMC
performance
· Built-in randomiser for improved EMC performance
· High temperature operation capable
· Load dump protected to 80V
LED driver
· High energy efficiency
· PWM dimming via VS/PWM pin
· Light output has minimised dependency on supply and temperature variations
· LED regulation parameters set with external resistors
MLX10803rev25.pdf
462 KB, 下载次数: 0, 下载积分: 积分 -1
发表于 26-4-2025 12:32:02 | 显示全部楼层
针对LED驱动器的一般描述:
此LED驱动器设计用于配合外部n-channel MOSFET开关晶体管,实现低成本的电源LED驱动。其具备广泛的6V至32V直流输入电压范围,适用于毫安至数安培的LED电流应用。此外,该驱动器可通过外接负温度系数(NTC)电阻实现温度依赖性的调节。整体采用小型封装,便于集成和安装。此LED驱动器适用于多种场景,表现出优异的性能和可靠性。
GMT+8, 16-6-2026 09:06 , Processed in 0.411234 second(s), 37 queries .
