  • 1673查看
Lexia-3 pps2000 Citroen/Peugeot Plus Lexia-3 30 pin round interface
发表于 15-10-2011 17:31:54 | 显示全部楼层 |阅读模式
Lexia-3 is a diagnostic tool and scanner for Citroen/Peugeot.
Language:
English,German,French,Japanese,Russian,Spanish, Portuguese,Swedish,Turkish,Dutch,Polish,Italian,Hungary,Greek,Czech
Description:
Unlike other universal car scanner tools which only read fault codes;this software performs nearly ALL the functions like the original dealer diagnostic tool.Our diagnostic interface contains K-Line multiplexor,CAN-BUS interfaces and SAE J1850 bus (both PWM and VPW).
1.Read identification
Displays complete identification of control unit, part number,software/hardware version,manufacturer,etc...
2. Read fault codes
Displays all stored and pending fault codes with complete description (e.g. "Rail pressure - too low pressure").
Program supports report printing or copy to clipboard.
3. Clear fault codes
this function clears all stored fault codes and other diagnostic information.
4. Auto-scan (complete car scan/test)
Detects all ECUs (electronic control units) installed in car and reads all diagnostic fault codes.
5. Measured Values
Program displays live Data like Engine Speed,Battery voltage,Oxygen Sensor,Coolant Temperature,etc.Values can be displayed in graph, 9 values at once,or full listing (all measured values).Logging to file is also supported, which allows offline analysis.
6. Actuator test
Actuator test activates particular actuator (e.g. turn on fuel pump,lock/unlock wheel,lock/unlock doors, cut off fuel,etc..)
Hardware and software requirements:
Software requires at least Intel Celeron/Pentium III 400 MHz, 128 MB RAM, 50MB free HDD space and USB 1.1 port (USB 2.0 recommended) and Microsoft Windows 98 SR2/2000/XP with the latest service pack installed.
If customer requires, we can prepare ready to work PC.
Package list:
1pc x Main unit with extension OBD2 cable
1pc x Long 9pin to USB cable
1pc x Short 9pin to USB cable
1pc x OBD2 cable
1pc x 16pin to Clip Cable
1pc x Instruction for Installation and Activation DVD for PP2000
1pc x 30 pin cable
Attention: pls leave your telephone number for shipping arrival when make payment for this product on our website.
发表于 8-9-2012 22:43:01 | 显示全部楼层
都是外文啊,看不懂呀。
GMT+8, 8-5-2026 07:09 , Processed in 0.429615 second(s), 38 queries .
