TA的每日心情 | 无聊 10-1-2016 13:38 |
签到天数: 2 天 [LV.1]初来乍到
VAS 5054A VW AUDI SKODA SEAT diagnostic Tool
•Bluetooth version
VAS 5054A Software Version:V15/V16/V17V18V19
VAS 5054A Language: English/Chinese/Spanish/Germany
The VAS 5054A is a universal diagnostic interface for the vehicles of the Volkswagen Group and all OBD vehicle systems from other manufacturers.
The integrated Bluetooth interface connects the vehicle with a notebook, desktop PC or test system.
No cables are needed for vehicle diagnostics using the VAS 5054A.
The range of the wireless Bluetooth connection is 5 to 10 meters, depending on the environment and the type of Bluetooth adapter used on the PC side.
The Serial Port Profile (SPP) is used for data transfer via Bluetooth. Different Bluetooth security levels are supported.
The following vehicle bus systems are supported:
K line (ISO9141-2)
High-speed CAN (ISO 11898-2)
Low-speed CAN (ISO 11898-3)
J1850 (SAE J1850)
The vehicle protocols are handled directly in the VAS 5054A.
This ensures fast response times and a reliable real-time behavior independently of the PC operating system. Every time a connection is established, the VAS 5054A software is synchonized with the version installed on the application PC. The VAS 5054A thus automatically adopts any new features provided after a new software version has been installed on the application PC.
The diagnostic application and the associated Diagnostic Base System are installed on the application PC.
The Diagnostic Base System can access the VAS 5054A via Bluetooth or USB.
Access via Bluetooth: After a connection to the VAS 5054A has been set up, the Bluetooth software provides a virtual serial COM port (Bluetooth Serial Port Profile). The Diagnostic Base System uses this COM port to communicate with the VAS 5054A.You need to specify this port when you install the diagnostic application.
Access via USB: You can also connect the VAS 5054A to the application PC by using the supplied USB cable. Windows detects the VAS 5054A through Plug and Play, and automatically installs the drivers copied when you installed the diagnostic application. Setup of the VAS 5054A is then complete and the device is ready for use
by the diagnostic application.
Please tell us what language of software and what version of software you want when place an order on our website.
Delivery Scope:
The Diagnosis head is supplied in a carrying case containing the following components:
1x VAS5054A Diagnosis Head.
1x USB cable (VAS5054/1).
1x Bluetooth
1x Optional CD with diagnostic application.
FAQ:
how to install the software of 5054A?
For the installation of 5054A, it is active version, does not need enter key.
When you have installed the software on the CD from us, you may encounter this case: after you run VAS-PC, it would say Hardware-ID and want enter key. in fact it is no need enter key ,don’t worry about it. You can activate your software with the 8number that appeared when you installed the software .or if you can not do this, you just give us a 8 number. and our technician will activate your software for you.
Shipping Terms:
Items will be sent to all the countries over the world.
This package will be sent by Hongkong Airmail Post,EMS,UPS or DHL.
Items will be checked carefully before sent out.
We will use air bubbles to wrap the items carefully.
Shipping Time:
1 business days for order processing after received the payment.
The shipping time is about 2 to 5 days via UPS DHL and EMS,15-30days via HK POST AIR to Worldwide
Note: We hope it arrive on time but since this is an international delivery, shipping time will be highly depended on the courier company and local customs/duties. Thank you for your understanding.
Return Policies:
If you are not satisfied with your purchase .please contact us quickly, we can exchange one to you,but buyers is responsible for the returning shiping cost .
If you have any item proplem, just email us quickly, we will do our best to slove it in 24 hours, please don’t leave bad feedback before contacting us, it is not the best way to slove proplem. thank you!
If you want more items we can give you a little discout,thank you!
