  • 5794查看
Adams/car悬架前悬子系统仿真中出现问题,搞不懂,望得到帮助!!!
发表于 12-4-2012 00:56:57 | 显示全部楼层 |阅读模式
C:\Users\Administrator\Desktop\QQ截图20120412005009 估计是与车轮半径有关  望各位给予指导!
 楼主| 发表于 12-4-2012 01:02:00 | 显示全部楼层
不好意思啊  图片没有弄上  把提示文本粘上了
Attempt = 1. No convergence after 25 iterations. Best iteration = 1.
   Trying next attempt with a different set of statics parameters...
   For the last attempted iteration the equation with the largest error
   was PART _parallel_travel.frt_suspe.gel_prod  Error = 1423.5
   The variable receiving the largest increment
   was FIELD _parallel_travel.frt_suspe.bgl_uca_rear.field  Delta = 1.21654E+05
---- ERROR ----
   Static equilibrium analysis has not been successful.
   Restoring the input initial conditions...
---- ERROR ----
   Initial Static Sim. Not Successful
   Terminating Adams/Car usersubs...
      Adams/Solver execution terminated by subprogram ERRMES
   CPU time used = 6.1620 seconds
Loading analysis results...
WARNING: The request file contains no time-dependent data.
Loading results done.
发表于 18-4-2012 16:16:35 | 显示全部楼层
悬架子系统怎么会与轮胎半径扯上关系了,轮胎是试验台自己加的。我以前也遇到过这种情况,是静平衡分析失败,一般是过约束。把一些刚性连接换成村套什么的,有可能可以。还有就是部件质量和转动惯量没调好!IX+Iy》Iz不妨全设为1!
GMT+8, 8-3-2026 09:49 , Processed in 0.404462 second(s), 34 queries .
