  • 1529查看
CATIA装配设计命令详解
发表于 22-4-2012 14:52:09 | 显示全部楼层 |阅读模式
1 产品介绍................................................................................................................................................... 4
2 图标功能介绍(基本概念、基本界面介绍) .................................................................................................... 4
2.1 产品结构工具(Product Structure)图标..................................................................................... 4
2.2 移动工具(Move Toolbar)图标.................................................................................................. 5
2.3 装配约束工具(Constraints Toolbar)图标.................................................................................. 5
2.4 更新工具(Update Toolbar)图标............................................................................................... 5
2.5 约束创建模式工具(Constraint Creation Mode Toolbar)图标.......................................................... 6
2.6 注解工具(Annotations Toolbar)图标............................................................................................. 6
2.7 装配特征工具(Assembly Features Toolbar)图标...................................................................... 6
2.8 分析工具(Analyze Tools)图标.................................................................................................. 6
3 软件环境设定(Customizing Settings) .......................................................................................................... 7
3.1 一般环境参数设定(General标签)............................................................................................. 7
3.2 装配约束环境参数设定(Constraints标签)................................................................................. 8
4 功能介绍................................................................................................................................................. 10
4.1 产品结构创建与编辑功能........................................................................................................... 10
4.1.1 在已有的装配中插入新部件(Inserting a New Component).............................................. 10
4.1.2 在已有的装配中插入新装配产品(Inserting a New Product)............................................. 11
4.1.3 在已有的装配中插入新零件(Inserting a New Part).......................................................... 11
4.1.4 在已有的装配中插入已存在的部件(Inserting Existing Components)................................ 12
4.1.5 替换元件(Replacing Components)................................................................................. 12
4.1.6 在结构树上重新安排子装配的位置(Reordering the Tree) .................................................... 13
4.1.7 生成产品子装配的编号(Generating Numbers)..................................................................... 14
4.1.8 产品初始化(Product Initialization)................................................................................... 15
4.1.9 卸载子装配(Unload Components).................................................................................. 16
4.1.10 加载子装配(Load Components)..................................................................................... 17
4.1.11 孤立零件(Isolate Part)................................................................................................... 17
4.1.12 不激活子装配和激活子装配(Deactivate Component/ Activate Component)..................... 19
4.1.13 改变从属关系(Change Context)..................................................................................... 20
4.1.14 管理产品的几何描述(Manage Representations)............................................................. 22
4.1.15 装配显示模式(Visualization Mode)................................................................................. 23
4.1.16 装配设计模式(Design Mode).......................................................................................... 23
4.1.17 不激活一个节点(Deactivate a Node).............................................................................. 23
4.1.18 激活一个节点(Activate a Node)...................................................................................... 23
4.1.19 不激活一串节点(Deactivate a Terminal Node) / 激活一串节点(Activate a Terminal Node) .. 23
4.1.20 产品结构的功能性比较....................................................................................................... 23
4.1.21 定义多重引用(Defining a Multi-Instantiation).................................................................. 24
4.1.22 快速多重引用(Fast Multi-Instantiation)........................................................................... 25
4.1.23 镜像(Symmetry)............................................................................................................ 25
4.2 移动工具(Move Toolbar)详解................................................................................................ 26
4.2.1 偏移或旋转部件(Manipulating a Component)................................................................. 26
4.2.2 快速定位移动(Snap Move)............................................................................................. 26
4.2.3 聪明移动(Smart Mov).................................................................................................... 27
4.2.4 生成装配爆炸图(Exploding an Assembly)....................................................................... 27
4.3 约束工具(Constraints Toolbar)详解....................................................................................... 28
4.3.1 同轴约束(Coincidence Constraint)................................................................................. 29
4.3.2 接触约束(Contact Constraint)........................................................................................ 31
4.3.3 偏移约束(Offset Constraint)........................................................................................... 31
4.3.4 角度约束(Angle Constraint)........................................................................................... 32
4.3.5 固定一个部件(Fixing a Component)............................................................................... 33
4.3.6 部件固定在一起(Fixing Components Together).............................................................. 33
4.3.7 快速约束命令(Quick Constraint Command).................................................................... 34
4.3.8 柔性子装配(Flexible Sub-Assemblies)............................................................................ 34
4.3.9 改变约束类型(Changing Constraints)............................................................................. 34
4.3.10 不激活约束或激活约束(Deactivate Constraints/ Activate Constraints)............................. 34
4.3.11 更新一个装配(Update an Assembly).............................................................................. 35
4.4 注释工具(Annotations Toolbar).................................................................................................. 35
4.4.1 带引出箭头的标注(Text With Leader)............................................................................. 35
4.4.2 超级链接(Flag Notes).................................................................................................... 35
4.5 装配特征工具(Assembly Features Toolbar)详解.................................................................... 35
4.5.1 装配切割(Assembly Split).............................................................................................. 35
4.5.2 装配打孔(Assembly Hole).............................................................................................. 36
4.5.3 装配挖凹坑(Assembly Pocket)....................................................................................... 36
4.6 分析工具(Analyze Tools)详解................................................................................................ 36
4.6.1 产品管理(Product Management).................................................................................... 36
4.6.2 生成零件清单(Bill of Material)........................................................................................ 37
4.6.3 分析装配修改更新状态(Analyze Updates)...................................................................... 38
4.6.4 装配约束的分析(Analyze Constraints)............................................................................ 38
4.6.5 装配自由度分析(Analyze Degrees of Freedom).............................................................. 39
4.6.6 装配依赖性分析(Analyze Dependences)........................................................................ 40
4.6.7 装配干涉计算(Compute Clash)...................................................................................... 40
装配设计.pdf
842.46 KB, 下载次数: 57, 下载积分: 积分 -1
发表于 23-4-2012 16:37:15 | 显示全部楼层
我现在直接用汉化包了。不过依然十分感谢楼主详细的介绍
发表于 14-9-2012 10:00:18 | 显示全部楼层
感谢楼主  问题解决了   资料很不错  能了解装配的功能!!
发表于 14-9-2012 16:02:28 | 显示全部楼层
正好学学这个小卡的装配!
发表于 15-9-2012 00:00:09 | 显示全部楼层
我顶哦;、;‘;
GMT+8, 23-9-2025 10:59 , Processed in 0.366436 second(s), 40 queries .
