  • 1049查看
哪位朋友有车身冲压件的中英文词汇
发表于 21-6-2012 09:13:44 | 显示全部楼层
FRONT PART OF REAR LONG
RR PART OF REAR LONG LH
RR PART OF REAR LONG RH
LONG REINF RR FLOOR LH
LONG REINF RR FLOOR RH
CLOSING PANEL FOR D PILLAR LH
CLOSING PANEL FOR D PILLAR RH
COUPLING MEMBER OF RR FURTHEST X MEMBER
SUPPORT FOR RR RECOVERY EYE
REINF OF RR RECOVERY EYE
REAR JACKING POINT
FRT GUSSET OF RR FLOOR X MEMBER
CONNECTING SUPPORT BRKT WITH GUSSET LH
X MEMBER SUPPORT BEARING OF RR AXLE
INNER GUSSET OF RR AXLE BEARING LHS
INNER GUSSET OF RR AXLE BEARING RHS
CONNECTING SUPPORT BRKT WITH GUSSET RH
OUTER GUSSET BEARING OF RR AXLE RHS
LONG COUPLING REINF. RHS
REINF OF JACKING PAD
GUSSET OF PANHARD ANTI ROLL BAR FIX
REINF OF UPPER REAR AXLE CUP RHS
FIXING SPACER OF RR SHOCK ABS.
REAR SIDE MEMBER RHS
REAR SUPPORT EXHAUST FIX
FRT REINF OF RR LONG MEMBER
FIX PLATE
CENTRAL GUSSET OF RR FLOOR X MEMBER
FRT SUPPORT EXHAUST FIX
PANHARD BAR FIX GUSSET SUPP BRKT
CENTRAL SUPPORT EXHAUST FIX
ANGLE BRKT OF SPARE WHEEL CARRIER
RR GUSSET OF RR FLOOR X MEMBER
FIXATION PAD
SPARE WHEEL FLOOR X MEMBER GUSSET
REAR SIDE MEMBER LHS
REINF OF UPPER REAR AXLE CUP LHS
RR BRAKE JUMP HOSE STOP
LONG COUPLING REINF. LHS
 楼主| 发表于 21-6-2012 09:12:58 | 显示全部楼层 |阅读模式
如题,焊装冲压件的中英词汇,老外给的英文竟缩写看不懂啊。
FRT PART OF FRT LONG LHS
FRT PART OF FRT LONG RHS
FRT CLOSING PNL OF FRT LONG LHS
FRT CLOSING PNL OF FRT LONG RHS
RR CLOSING PNL OF FRT LONG LHS
RR CLOSING PNL OF FRT LONG RHS
RR PNL OF FRT SIDEMEMBER LHS
RR PART OF FRT LONG RHS
SUPPORT X MEMBER RAD
CLOSING PNL SUPP X MEMBER RAD LHS
FRT SUSPEN HOUSING LHS
RR INNER SUPP SUBFRAME
RR OUTER SUPP FOR SUBFRAME LHS
UPPER REINF FRT SIDE MEM LHS RR
FRT SIDE SEAT FIXING
ANGLE BRKT FRT WHEELARCH LHS
STRIP FIX 20X50 M10
STRIP FIX 20X50 M8
FIX SPACER FRT SUBFRAME
BRAKE HOSE BRKT
STRIP FIX 20X50 NUT PLATE
WELD STRIP SUBFRAME FIX
CLOSING PNL SUPP X MEMBER RAD RHS
ANGLE BRKT FRT WHEELARCH RHS
HEIGHTENER ENG MOUNT SUPPORT
FRONT LONG MEMBER REINF
RR OUTER SUPP FOR SUBFRAME RHS
UPPER REINF FRT SIDE MEM RHS RR
ENG MOUNT SUPPORT
ENG MOUNT BRKT REINF
GMT+8, 18-5-2026 08:00 , Processed in 0.342946 second(s), 35 queries .
