  • 1641查看
[结构原理] ADVANCED HIGH STRENGTH STEEL (AHSS) APPLICATION GUIDELINES (需要的进!)
发表于 21-8-2012 19:57:11 | 显示全部楼层 |阅读模式
先进高强钢使用指南,包括AHSS种类介绍、AHSS成型(冲压成型,成型极限、回弹、模具设计等)、AHSS焊接等。
目录如下:
Preface ..................................................................................................................... iii
Executive Overview .................................................................................................. v
Section 1 - General Description of AHSS ............................................................... 1-1
1a - Definitions ............................................................................................ 1-1
1b - Metallurgy of AHSS ............................................................................. 1-3
Dual Phase (DP) Steel ................................................................... 1-3
Transformation-Induced Plasticity (TRIP) Steel............................ 1-4
Complex Phase (CP) Steel ............................................................ 1-5
Martensitic (Mart) Steel.................................................................. 1-5
AHSS Processing........................................................................... 1-6
1c - Common Steel Types and Evolving AHSS Types ............................... 1-7
Common Steel Types ..................................................................... 1-7
Evolving AHSS Types .................................................................... 1-8
Section 2 - Forming .................................................................................................. 2-1
2a - General Comments.............................................................................. 2-1
2b - Computerized Forming-Process Development .................................. 2-2
2c - Sheet Forming ..................................................................................... 2-4
Mechanical Properties ................................................................... 2-4
Forming Limits................................................................................ 2-12
Forming Modes .............................................................................. 2-18
Tool Design .................................................................................... 2-24
Springback ..................................................................................... 2-29
Blanking, Shearing, and Trim Operations ..................................... 2-48
Press Requirements ...................................................................... 2-49
Multiple Stage Forming .................................................................. 2-56
In-service Requirements................................................................ 2-58
2d - Tube Forming....................................................................................... 2-61
High Frequency Welded Tubes..................................................... 2-61
Laser Welded Tailored Tubes ....................................................... 2-65
Section 3 - Joining.................................................................................................... 3-1
3a - General Comments.............................................................................. 3-1
3b - Welding Procedures ............................................................................ 3-2
Resistance Welding ....................................................................... 3-2
High Frequency Induction Welding ............................................... 3-8
Laser Welding - Fusion ................................................................. 3-10
Arc Welding – Fusion .................................................................... 3-12
Weld Integrity: Test Method and Joint Performance..................... 3-14
3c - Brazing ................................................................................................. 3-18
3d - Adhesive Bonding ................................................................................ 3-19
3e - Mechanical Joining .............................................................................. 3-20
3f - Hybrid Joining ....................................................................................... 3-22
3g - Material Issues For Weld Repair ........................................................ 3-23
Section 4 – Glossary ................................................................................................ 4-1
Section 5 – References............................................................................................ 5-1
AHSSGuidelinesV23_2.haozip01.zip
1 MB, 阅读权限: 1, 下载次数: 7, 下载积分: 积分 -1
AHSSGuidelinesV23_2.haozip02.zip
1 MB, 阅读权限: 1, 下载次数: 6, 下载积分: 积分 -1
AHSSGuidelinesV23_2.haozip03.zip
AHSSGuidelinesV23_2.haozip04.zip
856.49 KB, 阅读权限: 1, 下载次数: 2, 下载积分: 积分 -1
发表于 24-12-2012 22:18:58 | 显示全部楼层
我研究高强板!所以想看看!
发表于 24-12-2012 22:19:53 | 显示全部楼层
我之前看过一个worldsteel的报告,不知是不是这个!
GMT+8, 12-5-2026 03:14 , Processed in 0.525964 second(s), 42 queries .
