  • 3929查看
[AVL软件] 请教avl fire 计算发散的问题
发表于 14-3-2013 16:11:26 | 显示全部楼层 |阅读模式
                            *         93. Time Step   Time = 0.1100000000E-01         dt = 0.1667E-03  *
                            *                        Angle =    492.000             dphi = 0.2000E+01  *
      ITER I***************** Relative Residual Source Sums  *************I   I******** Field Values at Monitoring Location       1 *******I
        NO.     RESU     RESV     RESW     RESM     RESK    RESD     RESH       U        V        W        P       TKIN     DISP     TEMP
          1  1.00E+00 1.00E+00 1.00E+00 1.00E+00 1.00E+00 1.00E+00 1.00E+00   1.15E+01-4.93E+00 9.16E+00 1.60E+04 9.40E+01 6.93E+04 3.47E+02
          2  1.09E+00 1.17E+00 1.15E+00 5.95E-01 1.02E+00 1.24E+00 6.22E-01   1.15E+01-4.78E+00 9.24E+00 1.59E+04 9.42E+01 6.94E+04 3.47E+02
          3  8.94E-01 9.64E-01 9.35E-01 4.75E-01 1.07E+00 1.63E+00 4.77E-01   1.15E+01-4.69E+00 9.28E+00 1.58E+04 9.45E+01 6.96E+04 3.47E+02
          4  6.87E-01 7.11E-01 6.75E-01 3.66E-01 1.16E+00 2.26E+00 4.02E-01   1.15E+01-4.64E+00 9.30E+00 1.58E+04 9.47E+01 6.98E+04 3.47E+02
          5  5.57E-01 5.59E-01 5.14E-01 2.78E-01 1.31E+00 3.17E+00 3.44E-01   1.14E+01-4.61E+00 9.31E+00 1.58E+04 9.50E+01 7.00E+04 3.47E+02
          6  4.74E-01 4.72E-01 4.32E-01 2.20E-01 1.53E+00 4.29E+00 2.94E-01   1.14E+01-4.60E+00 9.30E+00 1.58E+04 9.52E+01 7.02E+04 3.47E+02
          7  4.07E-01 4.00E-01 3.74E-01 1.80E-01 1.85E+00 5.57E+00 2.49E-01   1.14E+01-4.58E+00 9.30E+00 1.57E+04 9.54E+01 7.03E+04 3.47E+02
          8  3.49E-01 3.35E-01 3.23E-01 1.50E-01 2.29E+00 6.97E+00 2.11E-01   1.14E+01-4.57E+00 9.29E+00 1.57E+04 9.57E+01 7.05E+04 3.47E+02
          9  3.01E-01 2.81E-01 2.79E-01 1.26E-01 2.95E+00 8.62E+00 1.78E-01   1.14E+01-4.55E+00 9.29E+00 1.57E+04 9.59E+01 7.07E+04 3.47E+02
         10  2.62E-01 2.40E-01 2.41E-01 1.09E-01 4.01E+00 1.07E+01 1.51E-01   1.14E+01-4.54E+00 9.28E+00 1.57E+04 9.61E+01 7.08E+04 3.47E+02
         11  2.32E-01 2.08E-01 2.10E-01 9.74E-02 5.74E+00 1.31E+01 1.29E-01   1.14E+01-4.53E+00 9.28E+00 1.57E+04 9.63E+01 7.10E+04 3.47E+02
         12  2.08E-01 1.85E-01 1.86E-01 9.06E-02 8.48E+00 1.58E+01 1.12E-01   1.14E+01-4.52E+00 9.28E+00 1.57E+04 9.65E+01 7.11E+04 3.47E+02
         13  1.88E-01 1.67E-01 1.68E-01 8.79E-02 1.22E+01 1.81E+01 9.83E-02   1.14E+01-4.51E+00 9.27E+00 1.57E+04 9.68E+01 7.13E+04 3.47E+02
         14  1.72E-01 1.53E-01 1.55E-01 8.86E-02 1.66E+01 1.98E+01 8.82E-02   1.14E+01-4.51E+00 9.27E+00 1.57E+04 9.70E+01 7.14E+04 3.47E+02
         15  1.57E-01 1.42E-01 1.44E-01 9.13E-02 2.16E+01 2.10E+01 8.23E-02   1.14E+01-4.50E+00 9.27E+00 1.57E+04 9.72E+01 7.16E+04 3.47E+02
         16  1.47E-01 1.36E-01 1.38E-01 9.56E-02 2.72E+01 2.29E+01 8.27E-02   1.14E+01-4.50E+00 9.27E+00 1.57E+04 9.74E+01 7.17E+04 3.47E+02
         17  1.39E-01 1.39E-01 1.33E-01 1.21E-01 2.83E+01 1.32E+01 8.16E-02   1.14E+01-4.49E+00 9.27E+00 1.57E+04 9.76E+01 7.18E+04 3.47E+02
Problem diverges: Momentum transport equation, variable: X-velocity, material:        1
         18  NaN      NaN      NaN      NaN      NaN      NaN      NaN        NaN      NaN      NaN      NaN      NaN      NaN      3.47E+02
                    *   Runtime Analysis for Timestep           Count       CPU Time          Wallclock Time            MPI *
                    *   Timestep                                   93         113.23                  113.53              1 *
                    *   Timestep Accum.                            93       17713.58                17836.72              1 *
%fire-I-CMAIN,  CALCULATION  DIVERGED.
以上是计算发散处的说明,不知是什么原因引起的计算发散,还望高手们给瞅瞅是啥子问题,先谢过了!
 楼主| 发表于 14-3-2013 16:31:45 | 显示全部楼层
自我消灭0回复-_-!
发表于 31-1-2015 09:42:49 | 显示全部楼层
a823100136 发表于 14-3-2013 16:31
自我消灭0回复-_-!
请问,你这个问题解决了吗??到底是网格问题,还是参数问题??能不能告诉我下
GMT+8, 22-4-2026 22:09 , Processed in 0.346467 second(s), 36 queries .
