  • 840查看
VEHICLE ASSEMBLY AND TESTING
发表于 18-5-2013 10:28:11 来自手机 | 显示全部楼层 |阅读模式
Assembly of some 2000-3000 interior and exterior parts as well as major components are fitted on painted body in assembly plant that is generally constituted of : )Trim Line )Chassis Line
)Final Assembly Line
A general listing of major parts and components that are assembled in different lines are as follows:
Trim Assembly
z Harnesses and controls-other electrical z Pedal assembly, insulator z Air duct, heater, head liner
z Weather-strip, horn, stop switch
z Front/rear shock absorber, shift cable z Wiper link, washer tank
z Condenser, rear set belt, radiator insulator
Chassis Line
z Brake tube, filler neck, splash shield z Fuel pipe, fuel tank, canister z Rear axle, stabilizer
z Clutch tube, heat protector, engine z Knuckle, tie rod
z Exhaust, undercover z Tire, front /rear seat z Front/rear bumper
Final Assembly
z Rear pillar trim, trunklid latch z Console bracket, carpet, trunk room trim z License plate lamp, radiator, hose z Seat belt, centre pillar trim z Heat hose, steering shaft z Air-conditioner pipe z Parking brake, garnish z Glove box, battery tray, seatbelt anchor cover z Rear combination lamp, sunvisor z Air cleaner, front/rear seat z Battery cable, silencer z Front grille, drip molding z Front turn signal lamp, console box z Combination meter, A/c gas z Front/rear glass, roof molding
Different parts are handled in different ways. Some require bolting, others are just inserted, still others are fitted together. Sealing, wiring and other processes are also carried out. Basic assembly work consists of compound operations which include grasping, handling,
发表于 10-12-2014 19:23:55 | 显示全部楼层
这个已经有了
不过有中文翻译的吗
  • 签到天数: 4 天
    发表于 22-12-2014 21:45:19 | 显示全部楼层
    可以再详细一点吗
    GMT+8, 10-5-2026 02:02 , Processed in 0.393027 second(s), 36 queries .
