  • 4097查看
[求助] GT7.3与Simulink联合仿真问题,高手进
发表于 7-8-2013 09:39:43 | 显示全部楼层 |阅读模式
Error reported by S-function 'gtsuitesl73_dp' in 'ch061simulink/GT-SUITE Model':
FAIL* Unable to generate the model (.dat) file.
Please examine the output (*.out) file for error messages.
Then open the model in GT-SUITE and correct the problem.
怎样解决,求大侠指教
 楼主| 发表于 7-8-2013 11:37:57 | 显示全部楼层
Dynamics Free Cluster with no speed-setting part !
      A FREE cluster of kinematically linked mechanical
      parts was identified, without an initial speed input in
      any of its components.
      The cluster contains the following components:
         EngineState_engines-1:Engine/Inertia_auxt:2
         EngineState_engines-1:Engine/Inertia_shaft:1
         Shaft_EM2Intertia:EM2Intertia-1/Inertia_iner:1
这个问题怎么解决 啊
  • 签到天数: 5 天
    发表于 9-5-2017 16:53:57 | 显示全部楼层
    同求,高手解答,我也是和楼主一样的问题。
  • 签到天数: 15 天
    [LV.4]偶尔看看III
    发表于 9-3-2018 15:40:28 | 显示全部楼层
    挖个坟吧,网上一直在找这个问题的解决办法,没人回答。终于自己搞定啦。很简单,检查一下电脑上是否安装vs2005,教程明确写的,千万不能忽略。我装了vs2005之后,完美运行。
    GMT+8, 27-4-2026 09:35 , Processed in 0.374607 second(s), 34 queries .
