  • 1765查看
adam truck拖车仿真问题
发表于 11-9-2013 10:38:10 | 显示全部楼层 |阅读模式
Reading in property files...
Reading of property files completed.
Setting up the vehicle assembly for Driving Machine maneuver...
Setup of vehicle assembly completed.
Simulation is beginning...
Starting analysis #1 of vehicle assembly...
   *                      MSC.Software Corporation                     *
   *                             A d a m s                             *
   *          Automatic Dynamic Analysis of Mechanical Systems         *
   *                      A d a m s / S o l v e r                      *
   *                       (Build: 2010.1.19.37)                       *
   *      2013-09-11 10:15:49              Version MD 2010             *
   *      Customer Entitlement ID:         82F6649A-BB92GDDC           *
   Enter ADAMS model file name or Carriage Return or ? (or STOP):
   No model input file (ADM file) is given.
   Enter Command:
   file/model=truck02_bit
   A new model supplied.  Initialization starts...
   The default input and analysis values will be restored.
   CPU time used = 0.76562 seconds
   Enter ADAMS output file name or ? (default is same as input):
     Adams model file .. truck02_bit.adm
   Default file names for output files
     Tabular output file:
     truck02_bit.out
     Diagnostic file    :
     truck02_bit.msg
     Message Database file    :
     truck02_bit.mdb
     Graphics file      :
     truck02_bit.gra
     Request file       :
     truck02_bit.req
     Results file       :
     truck02_bit.res
   Input Phase - Reading in Model
   Adams/Solver dataset Title:
   Adams/Car Assembly (MD Adams 2010)
   Reading of model complete.
   Adams/Car MD Adams 2010
Processing ENVIRONMENT entries in 'C:\MSC.Software\MD_Adams\2010\acar/acar.cfg'
Processing ENVIRONMENT entries in 'C:\Documents and Settings\Administrator/.acar.cfg'
Processing ENVIRONMENT entries in 'C:\MSC.Software\MD_Adams\2010\atruck/atruck.cfg'
                              Adams/Tire
                         Version MD Adams 2010
   Input Phase - Populating Solver database
   Input Phase Complete.
   CPU time is 2.9531 seconds.
   Input and Input Check Phase complete.
   The system has 603 kinematic degrees of freedom.
   Enter Command:
   string/4, string=truck02_bit.xml
   Enter Command:
   preferences/solver=F77
   Enter Command:
   output/nosep
   Enter Command:
   control/ routine=abgVDM::EventInit, function=user(4,1,9,0,2,7,5,15)
Reading configuration file 'C:\MSC.Software\MD_Adams\2010\acar/acar.cfg'
Reading configuration file 'C:\Documents and Settings\Administrator/.acar.cfg'
Reading configuration file 'C:\MSC.Software\MD_Adams\2010\atruck/atruck.cfg'
   vdm::EvtMonitor::EvtMonitor
      End conditions evaluated in SENSUB.
                           Adams/Smartdriver
   Enter Command:
   control/ routine=abgVDM::EventRunAll, function=user(0)
   fdm::ActJoiMot
       Setting function on: steering::steering_wheel_angle
   MOTION/4, FUNCTION=0.0
   SFORCE/1, FUNCTION=0.0
   fdm::ActVar
       Connecting: steering::steering_wheel_angle
       To        : driver_demand::steering
   fdm::ActVar
       Setting function on: driver_demand::steering
   VARIABLE/79, FUNCTION=AZ(1644,1641)
   DEACTIVATE/SFORCE, ID=4
   DEACTIVATE/SFORCE, ID=5
   DEACTIVATE/MOTION, ID=3
   DEACTIVATE/MOTION, ID=4
   fdm::ActJoiFor
       Setting function on: steering::steering_wheel_torque
   SFORCE/2, FUNCTION=DIF(4)
   fdm::ActVar
       Setting function on: driver_demand::throttle
   VARIABLE/81, FUNCTION=MIN(100.0,MAX(0.0,DIF(3)))
   fdm::ActVar
       Setting function on: driver_demand::brake
   VARIABLE/83, FUNCTION=MIN(0.0,DIF(3))*IF(MODE-4:-1.0,1.0,-1.0)
   fdm::ActVar
       Setting function on: driver_demand::gear
   VARIABLE/85, FUNCTION=(3.0)
   fdm::ActVar
       Setting function on: driver_demand::clutch
   VARIABLE/87, FUNCTION=0.0
   vdm::SteadyState::MiniInfo
   Static Task       :  'Skidpad'
   Turn Direction    :  'Right'
   Radius            :  10.000 [m]
   Lat. Acceleration :  0.981 [m/s^2]
   Lon. Acceleration :  0.000 [m/s^2]
   Initial Velocity  :  3.132 [m/s]
   Use Brake         :  No
   Perform Linear    :  No
   Include Damping   :  Yes
   Halt on Failure   :  Yes
   fdm::ActVar
   VARIABLE/87, FUNCTION=1.0
    ACTIVATE/MOTION,ID=4
    SIM/STAT
   The system has 604 kinematic degrees of freedom.
   Current Adams model successfully verified.
   Entering the static equilibrium analysis phase...
   Displacement initial condition analysis...
   Jacobian Matrix Statistics for the Initial Conditions
   Number of equations ............. = 1616
   Number of non-zero entries ...... = 8136
   Percentage of matrix non-zero ... = 0.31155
   Total space used in MD array .... = 1030580
       TIRE ID:  1
       TYR902 -> Fiala Tire Model
       Using 2D Handling Road Contact v1.0
       TIRE ID:  2
       TIRE ID:  3
       TIRE ID:  4
       TIRE ID:  5
       TIRE ID:  6
       TIRE ID:  7
       TIRE ID:  8
       TIRE ID: 10
       TIRE ID: 11
       TIRE ID: 12
       TIRE ID: 13
       TIRE ID: 14
       TIRE ID: 15
       TIRE ID: 16
       TIRE ID: 17
       TIRE ID: 18
       TIRE ID: 19
   Performing Static analysis...
   Generating the Jacobian matrix for the statics or quasi-statics problem.
   Jacobian Matrix Statistics for Statics
   Number of equations ............. = 5505
   Number of non-zero entries ...... = 52101
   Percentage of matrix non-zero ... = 0.17192
   Total space used in MD array .... = 2041388
   Static equilibrium was found after 6 iterations.
   The maximum error is 4.60801E-05 with a maximum imbalance of 1.23129E-07.
    DEACTIVATE/JPRIM,ID=2
    DEACTIVATE/JPRIM,ID=3
    DEACTIVATE/SFORCE,ID=1
    DEACTIVATE/JPRIM,ID=10
    DEACTIVATE/JPRIM,ID=11
    DEACTIVATE/JPRIM,ID=12
    DEACTIVATE/JPRIM,ID=13
    DEACTIVATE/JPRIM,ID=15
    DEACTIVATE/JPRIM,ID=16
    DEACTIVATE/JPRIM,ID=17
    DEACTIVATE/JPRIM,ID=18
    DEACTIVATE/JPRIM,ID=19
    DEACTIVATE/JPRIM,ID=20
   fdm::ActVar
    ACTIVATE/JPRIM,ID=2
    DEACTIVATE/MOTION,ID=4
   acar_2010.1.0/vdm_gra_mod
       Setting gravity vector in g's to:   0.00000E+00  0.00000E+00 -1.00000E+00
   accgrav/igrav= 0.00000E+00,jgrav= 0.00000E+00,kgrav=-9.81000E+03
   sim/stat
   The system has 606 kinematic degrees of freedom.
   Number of equations ............. = 1614
   Number of non-zero entries ...... = 8118
   Percentage of matrix non-zero ... = 0.31163
   Total space used in MD array .... = 1031190
   Number of equations ............. = 5503
   Number of non-zero entries ...... = 52303
   Percentage of matrix non-zero ... = 0.17271
   Total space used in MD array .... = 2062208
   The maximum error is 1.26104E-06 with a maximum imbalance of 2.53160E-10.
    MOTION/4,FUNC=-0.164628162342024
   ***** Setting velocity of part ID =   191
   ***** Setting velocity of part ID =   192
   ***** Setting velocity of part ID =   197
   ***** Setting velocity of part ID =   198
   ***** Setting velocity of part ID =   200
   ***** Setting velocity of part ID =   201
   ***** Setting velocity of part ID =   206
   ***** Setting velocity of part ID =   207
   ***** Setting velocity of part ID =   249
   ***** Setting velocity of part ID =   250
   ***** Setting velocity of part ID =   319
   ***** Setting velocity of part ID =   320
   ***** Setting velocity of part ID =   325
   ***** Setting velocity of part ID =   326
   ***** Setting velocity of part ID =   328
   ***** Setting velocity of part ID =   329
   ***** Setting velocity of part ID =   334
   ***** Setting velocity of part ID =   335
    ACTIVATE/JPRIM,ID=2
       Setting gravity vector in g's to:   0.00000E+00 -9.99694E-02 -1.00000E+00
   accgrav/igrav= 0.00000E+00,jgrav=-9.80700E+02,kgrav=-9.81000E+03
   sim/stat
   Number of non-zero entries ...... = 52966
   Percentage of matrix non-zero ... = 0.17490
   Total space used in MD array .... = 2071492
   Symbolic refactorization attempted at time = 0.0.
---- WARNING ----
   The symbolic refactorization failed.  The matrix is structurally singular
   at time = 0.0.
---- ERROR ----
   Static equilibrium analysis has not been successful.
   Restoring the input initial conditions...
       Setting gravity vector in g's to:   0.00000E+00 -9.99694E-03 -1.00000E+00
   accgrav/igrav= 0.00000E+00,jgrav=-9.80700E+01,kgrav=-9.81000E+03
   Total space used in MD array .... = 1036676
   Total space used in MD array .... = 2094868
---- WARNING ----
   at time = 0.0.
---- ERROR ----
       Setting gravity vector in g's to:   0.00000E+00 -9.99694E-04 -1.00000E+00
   accgrav/igrav= 0.00000E+00,jgrav=-9.80700E+00,kgrav=-9.81000E+03
---- WARNING ----
   at time = 0.0.
---- ERROR ----
       Setting gravity vector in g's to:   0.00000E+00 -9.99694E-05 -1.00000E+00
   accgrav/igrav= 0.00000E+00,jgrav=-9.80700E-01,kgrav=-9.81000E+03
   Total space used in MD array .... = 2093822
---- WARNING ----
   at time = 0.0.
---- ERROR ----
   <apre_sscsta> Final Lateral Acceleration limit (G`s) =  0.00000E+00
---- ERROR ----
   Given Lateral Accel. Level cannot be Reached...
   Terminating Adams/Car usersubs...
      Adams/Solver execution terminated by subprogram ERRMES
   CPU time used = 23.734 seconds
ERROR:   ---------------------------------------------------------------------
ERROR:   Error detected on line number 732, character 111 of the macro '.ACAR.macros.mac_ana_ful_sub'.
ERROR:   The object 'road_filedata_memory' already exists.
ERROR:   The command was not executed.
ERROR:   +5&>           new_entity=(eval(".msc_tractor_semitrailer."//.sim_preferences.file_prefix//".road_filedata_memory"))
Simulation is complete.
侧向加速度的临界值我已经设置到了0.1g,还是报错,请哪位高手指点一下!谢谢!
GMT+8, 21-6-2026 02:55 , Processed in 0.535614 second(s), 34 queries .
