TA的每日心情 | 郁闷 10-9-2020 09:19 |
签到天数: 2 天 [LV.1]初来乍到
发表于 13-3-2014 12:49:43
显示全部楼层
热线式的,ABB生产的。原理英文如下: The gas passes two temperature-sensitive resistors RS and RT, which are part of an electrical bridge circuit. In the case of the mass flow meter, specially developed and sturdy platinum thin-film resistors are used. Due to the selected resistance ratio RS « RT, RS is heated by the current IS and RT adapts the temperature of the gas.
The current IS is set by an electronic control circuit (symbolically represented by an amplifier) in such a way that a constant temperature difference is established between the heated resistor RS and the temperature of the gas.
The electric power generated in the resistor RS exactly compensates its heat loss to the flow. Since this heat loss depends on the number of particles striking the surface of the resistor RS, IS represents a measurement of mass flow.
| 参与人数 1 | 贡献值 +1 |
积分 +6 |
收起
理由
清雅轩
| + 1 |
+ 6 |
回帖有奖【论坛口号→知无不言,言无不尽】 |
