  • 1028查看
[求助] 消声器的离散问题?
    发表于 26-5-2014 19:11:13 | 显示全部楼层 |阅读模式
    For the shell <mufflershell>, the flowsplit with biggest volume is mufflershell_21_14_11, volume is 11210 mm^3
    For the shell <mufflershell>, the flowsplit with smallest volume is mufflershell_8_17_16, volume is 1357 mm^3
    Severe Warning: For the shell <mufflershell>, the smallest volume is less than 0.01% of the the shell volume
    For the shell <mufflershell>, the flowsplit with the second smallest volume is mufflershell_8_17_3, volume is 1357 mm^3
    由于在隔板上的的孔径D12所以DX,DY我设的是14,DZ是40.请问如解决?
    发表于 26-5-2014 20:00:21 | 显示全部楼层
    搞不懂,期待结果
    GMT+8, 19-11-2025 21:22 , Processed in 0.374722 second(s), 34 queries .
