  • 1465查看
[GT-Suite] gt-suite与fluent耦合
    发表于 11-6-2014 15:18:21 | 显示全部楼层 |阅读模式
    在fluent倒数第二步初始化中遇到下面的错误,求指导
    Retreiving zero temperature from gt library
    If this is a restart of the run, make sure to use the corresponding restart gt file
     楼主| 发表于 11-6-2014 15:58:24 | 显示全部楼层
    在运行gt时还有个错误,
    *FAIL:Run>Run Setup>TimeControl>Maximum Simulation Duration is greater than
            the uncoupled ('CFDComponent'>Engine Cycles Before CFD Started)
          + the one-way coupled ('CFDComponent'>One-Way Coupled Cycles)
          + the cfdreload phase of this simulation, which is not allowed when
          running GT-SUITE directly.
          35 + 0 + 0 cycles < 38 total requested cycles.
     楼主| 发表于 11-6-2014 22:06:36 | 显示全部楼层
    问题终于解决了,结果是我见DOS 窗口没反应就给关了,其实不能关。但还有一点没有明白,就是耦合计算完成后,为什么没有产生tutorial所说的 .gx 文件,而是 .gp 文件?
     楼主| 发表于 13-6-2014 10:01:38 | 显示全部楼层
    在做Restarting/Continuing a GT-SUITE CFD Coupling Simulation时,运行fluent时总有The solution must be initialized before the calculation can be started.
    Do you want to proceed after initializing the case now?但它说Be sure NOT to re-initialize the FLUENT model.求指点
    发表于 2-7-2014 22:43:07 | 显示全部楼层
    楼主GT和fluent耦合能计算了吗?能不能私下教教我,我按照教程弄还是不行
    19-9-2016 14:08
    发表于 21-9-2014 18:34:03 来自手机 | 显示全部楼层
    寡头裨将 发表于 11-6-2014 15:58
    在运行gt时还有个错误,
    耦合算完了,关闭fluent,会自动生成gt后处理文件的
    GMT+8, 25-4-2026 10:40 , Processed in 0.345061 second(s), 37 queries .
