  • 651查看
[求助] 环组动力学分析时报错(Ring end shut)
发表于 9-7-2014 20:32:44 | 显示全部楼层 |阅读模式
做环组动力学分析的时候总是报下面两个错误:
1、 FATAL ERROR  (MODULE:  GeomPistonGroove)  RING NO.      2     VOLUME IN PISTON RING GROOVE LOWER ZERO
2、 FATAL ERROR  (MODULE:  RingEndArea)       Ring No.      2    => Ring end shut!
     Check thermal expansion of this ring    or check thermal expansion and   profile of cylinder liner
     Listing of current configuration:
        closed gap (warm in nominal bore)               = -90.965E-03   [mm]
        Liner dev.(pos. increase of Dia )               = 290.180E-03   [mm]
        Ring lift due to oil film                       = 438.648E-03   [mm]
        Please: 1)increase closed gap, current gap      = 557.390E-03   [mm]
                2)Increase Liner dev.(or increase Temp) = 177.423E-03   [mm] (or reduce Temp)
其中第二个我在直接计算例题的时候也报这个错(Gasoline Engine)。
第一个问题我查了一下结果Result Data - Ring Dynamics ~~~~~~Ring and Piston Groove Geometry里面环和环槽的形状都看着挺正常的,而且是在计算几步之后出现这个错误。
第二个直接算例题(Gasoline Engine)在算6000rpm 的时候会报这个错误。
自己的模型把环端闭口间隙加大到8mm都还是报这个错误。
    难过
    3-11-2015 09:09
    发表于 10-7-2014 22:53:54 | 显示全部楼层
    我现在也在做P&R  总觉得教程做的有问题。
    留个QQ交流下  11603963
    GMT+8, 19-11-2025 14:28 , Processed in 0.455462 second(s), 32 queries .
