  • 979查看
汽车英文
发表于 9-12-2014 09:34:23 | 显示全部楼层 |阅读模式
The actions taking place in the engine cylinder can be classified into four stages or strokes. “Stroke” refers to piston movement. A stroke occurs when the piston moves from one limiting piston to the other. The upper limit of piston movement is called TDC (top dead center). The lower limit of piston movement is called BDC (bottom dead center). A stroke is piston movement from TDC or from BDC.
  • 签到天数: 10 天
    发表于 7-8-2016 16:21:34 | 显示全部楼层
    参考下,谢谢楼主了
    GMT+8, 10-5-2026 01:40 , Processed in 0.367957 second(s), 34 queries .
